[SOLVED] Debian 9 - postconf
keeper
Registration: January 26, 2019 - 6:10 PM
January 26, 2019 - 6:17 PM
Hello, I installed WAPT on a Debian 9 system, specifying "stretch" as the repository. The installation went smoothly, but during postconf I get this error: Traceback (most recent call last): File "/opt/wapt/waptserver/scripts/postconf.py", line 42, in import jinja2 File "/opt/wapt/lib/python2.7/site-packages/jinja2/__init__.py", line 33, in from jinja2.environment import Environment, Template File "/opt/wapt/lib/python2.7/site-packages/jinja2/environment.py", line 13, in import weakref File "/usr/lib/python2.7/weakref.py", line 14, in I'm lost because I'm successfully running the postconf.sh script. Thanks in advance for your help .
April 15, 2019 - 9:19 PM
Could you try with the latest version?
http://wapt.tranquil.it/wapt/nightly/wa ... -7158724f/
had69
Registration: July 11, 2019 - 10:41
July 11, 2019 - 10:46
I'm updating this thread because I'm getting the exact same message when running the post-conf script.
I have Wapt version 1.7 and I'm using Debian version 10 (Buster).
Thanks.
July 11, 2019 - 11:16
Hello had69,
had69 wrote: July 11, 2019 - 10:46 AM Hello,
I'm reviving this thread because I get the exact same message when running the post-conf script.
Thank you.
We haven't yet tested and validated the Debian Buster environment. Could you please open a new thread? The problem is probably related to the version change.
had69
July 11, 2019 - 3:31 PM
So I reinstalled the server with Debian 9.9 and the script works much better,
which goes to show that following recommendations sometimes helps...
anyway, thanks for the quick response!
slena
Registration: Oct 16, 2019 - 1:10 p.m.
October 16, 2019 - 1:12 PM
have you had time to test the WAPT server on Debian 10?
Thank you.
October 16, 2019 - 2:16 PM
Hello Slena,
slena wrote: Oct 16, 2019 - 1:12 PM Hello,
Have you had time to test the WAPT server on Debian 10?
Thank you,
Please start a new thread if this one has been closed [RESOLVED]. Otherwise, it becomes difficult to follow the topics :-)
