[SOLVED] Renaming a package already in PROD
Gaetan
Registration: August 8, 2019 - 10:16
October 18, 2019 - 5:02 PM
a package was created and we continued to develop it.
However, we are not satisfied with the naming convention, including the version number.
Is there a way to change the name without having to create a new package?
This would ensure the change is transparent to users.
Thank you.
October 20, 2019 - 11:28 PM
Since everything revolves around the name, no, it's not possible to rename a package.
However, you can create a transition package with a dependency—a group that bears the name of the old package but has the new package as a dependency. `tis-libreoffice` is an example.
Gaetan
October 21, 2019 - 10:27
Great, thank you.
I'll take a look at LibreOffice.
Have a good day.
