[SOLVED] How to create shortcuts in "Quick Access"?
nixxax
Registration: August 28, 2019 - 10:30
September 3, 2019 - 9:05 AM
How can I create a package that adds a list of shortcuts inside "quick access"?
I would like to send the network addresses of surrounding workstations to it for sharing. For example:
  • Quick access
    • \\192.168.31.1
    • \\192.168.31.2
    • \\192.168.31.3
    • etc.
    Thank you for your feedback.
Christophe0110
Registration: June 11, 2019 - 12:04
October 21, 2019 - 11:33
Hi nixxax,
You can use the run_powershell command to execute a powershell command in the session_setup:
    print('Rien à faire en install')
def session_setup():
    run_powershell(r'(new-object -com shell.application).Namespace("\\192.168.31.1").Self.InvokeVerb("pintohome")')
A+
October 22, 2019 - 8:58 AM
Hello Nixxax,
nixxax wrote: ↑September 3, 2019 - 9:05 AM Good morning,
  • Quick access
    • \\192.168.31.1
    • \\192.168.31.2
    • \\192.168.31.3
    • etc.
While not directly related to your problem, I would add that it's preferable to use DNS names instead of IP addresses; otherwise, the workstations will use NTLM authentication instead of strong Kerberos authentication :-)
