I have this Jessie Linux server:
WAPT Server version: 1.6.2.7
WAPT Agent version: 1.6.2.7
WAPT Setup version: 1.6.2.7
WAPT Deploy version: 1.6.2.7
Database status: OK (1.6.2.4)
which I would like to upgrade to 1.7 by following this procedure:
https://www.wapt.fr/fr/doc/waptserver-u ... ade-debian
but I get this error:
root@srv-wapt:/etc/apt/sources.list.d# wget -O - https://wapt.tranquil.it/debian/tiswapt-pub.gpg | apt-key add -echo "deb https://wapt.tranquil.it/debian/wapt-1.7/ $(lsb_release -c -s) main" > /etc/apt/sources.list.d/wapt.list
--2019-10-23 11:31:24-- https://wapt.tranquil.it/debian/tiswapt-pub.gpg
Resolving wapt.tranquil.it (wapt.tranquil.it)… 185.16.48.72
Connecting to wapt.tranquil.it (wapt.tranquil.it)|185.16.48.72|:443… connected.
HTTP request sent, awaiting response… 200 OK
Saving to: "STDOUT"
- 100%[==================================================================================================================================================================>] 3.75K --.-KB/s in 0s
2019-10-23 11:31:24 (21.3 MB/s) — Sending to standard output [3839/3839]
gpg: conflicting commands
, does anyone have any idea?
Thanks
[RESOLVED] Update 1.6.2.7 to 1.7 gpg: conflicting commands
- WAPT Expert
Hello bruno67,
You can also upgrade your Jessie. We're still compiling the deb packages, but we might drop Jessie support when we switch to Python 3.
The two command lines `wget` and `echo` must be run on two different lines...bruno67 wrote: ↑Oct 23, 2019 - 11:37 AM I would like to upgrade to version 1.7 by following this procedure:
Everything is good, the stretching went smoothly.
WAPT Server version: 1.7.4
WAPT Agent version: 1.7.4.6229
WAPT Setup version: 1.7.4.6229
WAPT Deploy version: 1.7.4.6229
Database status: OK (1.7.4.0)
Everything seems to be working,
thanks for the advice.
- WAPT Expert
Hello Bruno67,
Thanks for the feedback, I'm marking the thread as [RESOLVED].
