setup.py
#import time
config_path = makepath(programfiles,'Immunet','local.xml')
print('installing %s' % control.asrequirement())
install_exe_if_needed("ImmunetSetup.exe",'/S',key='',min_version='7.0.0',accept_returncodes=[0,1638])
print('uninstalling %s' % control.asrequirement())
#not a silent uninstaller => manual command
run(r'"C:\Program Files\Immunet\7.0.0\uninstall.exe" /S /remove 1')
def session_setup():
print('Session setup for %s' % control.asrequirement())
#can be run under session setup cause user has permission to write
update_config()
def update_package():
print('Update package content from upstream binary sources')
def audit():
print('Auditing %s' % control.asrequirement())
def update_config():
import xml.etree.ElementTree as etree
config = etree.parse(config_path)
<config>
<exclusions>
<info>
<item>256|3|0|1|.dwg</item>
<item>256|3|0|1|.dxf</item>
<item>256|2|1|0|C:\Program Files (x86)\wapt\</item>
<item>256|2|1|0|C:\powerplan</item>
<item>256|1|0|0|toolbox.exe</item>
</info>
</exclusions>
exclusions = config.find('exclusions/info')
items = []
dwg = dxf = wapt = need_write = False
for item in exclusions.iter():
#list all items
if item.text:
if len(item.text.split()) > 0:
items.append(item.text)
if item.text.find('.dwg') > 0: #dwg is found
dwg = True
if item.text.find('.dxf') > 0:
dxf = True
if item.text.find('wapt') > 0:
wapt = True
#print(items)
if dwg == False :
dwg = etree.SubElement(exclusions, 'item')
dwg.text = '256|3|0|1|.dwg'
print('add .dwg exclusion')
need_write = True
if dxf == False :
dxf = etree.SubElement(exclusions, 'item')
dxf.text = '256|3|0|1|.dxf'
print('add .dxf exclusion')
need_write = True
if wapt == False :
wapt = etree.SubElement(exclusions, 'item')
wapt.text = '256|2|1|0|C:\\Program Files (x86)\\wapt\\'
print('add wapt exclusion')
need_write = True
if need_write == True:
config.write(config_path)
<scansettings>
<clamav>
<options>
<ondemand>
<scanarchives>1</scanarchives>
<scanpacked>1</scanpacked>
</ondemand>
</options>
</clamav>
<tetra>
<options>
<ondemand>
</ondemand>
</options>
</tetra>
</scansettings>
