[RESOLVED] URL Packet
Smart
Registration: July 2, 2018 - 11:11
November 5, 2019 - 1:35 PM
WAPT 1.7.4 - CentOS Server - OS Machine Admin under Windows Server 2016.
Good morning, gentlemen
I want to create a package that creates a website shortcut on the desktop and adds a specific icon. Currently, I have this:
destdir = makepath(programfiles32,'ELI')
    print('installing test-eli')
    mkdirs(destdir)
    filecopyto('icone.ico',makepath(programfiles32,'ELI'))
    create_desktop_shortcut('ELI', target = "http://*******, wDir="C:\Program Files (x86)\ELI", icon="C:\Program Files (x86)\EVA\icone.ico")
    print('Removing ELI')
    remove_desktop_shortcut('ELI')
    remove_tree(destdir)
Problem: it doesn't accept the icon.
Do you have a solution?
Sincerely
Smart
November 6, 2019 - 11:15
Okay, I've figured out the installation:
    print("installing test-eli")
    filecopyto(ur"icone.ico",makepath("C:","Windows"))
    create_shortcut(makepath(common_desktop(),ur"ELI.URL"),target=r'http://****', icon=makepath('C:','Windows','icone.ico'))
I don't know how to "uninstall" it yet, but I'll figure it out :)
Gaetan
Registration: August 8, 2019 - 10:16
November 6, 2019 - 11:42
Smart
November 6, 2019 - 2:26 PM
    remove_user_desktop_shortcut('ELI')
Thanks, but it doesn't work...
Gaetan
November 6, 2019 - 3:09 PM
Try creating the shortcut with this function:
https://wapt.tranquil.it/wapt/nightly/a ... p_shortcut
I think it's missing the label ;)
Smart
November 6, 2019 - 3:53 PM
create_user_desktop_shortcut('ELI',target=r'http://****', icon=makepath('C:','Windows','icone.ico'))
I tried that, but it doesn't recognize the specified path...
Gaetan
November 6, 2019 - 3:57 PM
Try it like this instead:
create_user_desktop_shortcut(r'ELI',target='http://****', icon=makepath('C:','Windows','icone.ico'))
The 'r' is not used for the target.
Smart
November 6, 2019 - 4:09 PM
Still nothing, it's showing me the following error:
com_error: (-2147024894, 'Le fichier sp\xe9cifi\xe9 est introuvable.', None, None)
0x80070002 : Le fichier spÚcifiÚ est introuvable.
Gaetan
November 6, 2019 - 4:19 PM
Smart
November 7, 2019 - 7:33 AM
