Wapt package - Program files location
Sam Nang
Registration: Apr 03, 2015 - 12:51
April 3, 2015 - 12:56
I would like to know if, when deploying a package, the installation correctly takes place in "Program Files" on the C drive, it's possible to change the shortcut? For example, to have the installation take place in a different drive.
Thank you for your help.
rezidu
Registration: March 16, 2015 - 10:21
April 3, 2015 - 1:43 PM
it all depends on the options offered by your package installer. It varies from case to case depending on the software you are deploying.
