[SOLVED] Accents and PyScripter
marcolefo
Registration: Oct 02, 2018 - 11:13
November 15, 2019 - 11:11
We are experiencing a problem with accents.
Indeed, they are not recognized correctly when using PyScripter. There is no problem with the Python console.
In the console:
Python 2.7.15 (v2.7.15:ca079a3ea3, Apr 30 2018, 16:22:17) [MSC v.1500 32 bit (Intel)] on win32
>>> var = u"éè"
>>> type(var)
<type 'unicode'>
>>> print var
éè
In the setup.py file via PyScripter:
    var = u"éè"
    print type(var)
    print var
And when uninstalling:
*** Console de processus distant Réinitialisée ***
Ligne de Commande : install "C:\TEMP\test-accents_18.7.2-5\WAPT\.."
Installing WAPT files C:\TEMP\test-accents_18.7.2-5
<type 'unicode'>
‚Š
Results :
 === install packages ===
  C:\TEMP\test-accents_18.7.2-5 | test-accents (18.7.2-5)
[Bad joke] It's enough to make you lose your UTF-8 [/Bad joke]
The setup.py file is saved in UTF-8 (No BOM) / UNIX.
Do you see where the problem might be coming from?
WAPT Enterprise Server: 2.6.0.17343 / Server OS: Debian bookworm /
Administration/package creation machine OS: macOS 15
November 15, 2019 - 12:27
It's an old problem... that no longer shocks us, we get used to it ;)
In fact, the output of the print statements is redirected to store the result in the Wapt log database, or to the console.
This redirection is managed in waptutils.py by the LogOutput class.
One solution is to replace (around line 1455)
    def write(self,txt):
        with self.lock:
            txt = ensure_unicode(txt)
            self.output.append(txt)
            if self.update_status_hook and threading.current_thread() == self.threadid and (time.time()-self.last_update_time>=self.update_buffer_time):
                # wait update_buffer_time before sending data to update_hook to avoid high frequency I/O
                self._send_tail_to_updatehook()
            if self.console:
                try:
                    self.console.write(txt)
                except:
                    self.console.write(repr(txt))
by (self.console.write by self.console.stream.write):
        with self.lock:
            if self.console:
                try:
                    self.console.stream.write(txt)
                except:
marcolefo
November 15, 2019 - 1:06 PM
That solves the problem...
One quick question. If the problem has been known for a long time, why not fix it?
The code I provided was a test. In reality, we want to delete a file if it exists.
So the starting code is rather
# coding: utf-8
    licencemanagerfile = ur'C:\TEMP\test_éè\file.txt'
    if (isfile(licencemanagerfile)):
        remove_file(licencemanagerfile)
It now works perfectly, with the proposed modification.
But it would have to be applied to all customers, wouldn't it?
November 15, 2019 - 1:16 PM
Because nobody had focused on that, and we found the solution just before replying to you...
The fix will be in the next version of Wapt... obviously.
marcolefo
November 18, 2019 - 3:20 PM
Great! Thank you :)
November 18, 2019 - 3:40 PM
There is a build that includes this accent fix:
https://wapt.tranquil.it/wapt/nightly/w ... -1c00cefd/
Changelog:
WAPT-1.7.4-6237 (2019-11-18) (not released)
(hash 1c00cefd)
* waptserver: add fix to workaround flask-socketio bug https://github.com/miguelgrinberg/Flask ... ssues/1054 (AttributeError: 'Request' object has no attribute 'sid')
* waptserver: be sure db is closed before trying to open it (for dev mode)
* waptserver: add logs messages when an exception message is sent back to the user.
WAPT-1.7.4-6234 (2019-11-14) (not released)
(hash ad237eee)
* waptserver: upgrade peewee DB python module to 3.11.2. explicit connection handling to DB to track potential limbo connections (which could lead to db pool exhaustion)
* waptwua: Trap exception when pushing WU to Windows cache to allow valid updates to be installed even if some could not be verified properly.
WAPT-1.7.4-6232 (2019-10-31)
(hash2090b0e6d52cecfb04f8fa4c279e7c0a0252d6e2
* wapt-get session-setupp: fix bad print in session_setup. regression introduced in b30b1b1a550a4 (1.7.4.6229)
WAPT-1.7.4-6230 (2019-10-23) (not released)
(hash 391d382f)
* return server git hash version and edition in ping and usage_statistics
* be sure to have server_uuid on windows when during setup
* fix for .git partially included in built package manifest
Patrice_minagri
Registration: Oct 21, 2016 - 4:56 p.m.
November 27, 2019 - 5:01 PM
if I understand correctly, this involves applying the fix to all computers with the WAPT agent installed? Like replacing the original waptutils.py file with its corrected version (via another package, GPO, etc.)?
WAPT 2.6.1.17787
