[SOLVED] DELL bios setup package
seb b
Registration: Oct 26, 2017 - 3:12 p.m.
December 17, 2019 - 3:35 PM
Hello everyone,
I am trying to create a configuration package for DELL UEFI BIOS using their cctk tool.
Some computers have a BIOS password, others do not. We also don't want BIOS passwords to be transmitted in plain text, so I generated executables using CCT, one that removes the password and one that resets it.
I would like to follow these steps in my WAPT package:
  • Check if the password is set
  • If so, run the executable that deletes it
  • make the scripted changes
  • launch the executable that resets the password
The only way I've found to check if the password is set is to cause an error in cctk with a bad password; it then gives me a return code that tells me whether a password is set or not.
My problem is that I can't capture this return code.
When I place my order:
run (r'"C:\Program Files (x86)\Dell\Command Configure\X86_64\cctk.exe" --numlock=enabled --valsetuppwd=impossiblepasswd'")
I have a CalledProcessErrorOutput (normal) which displays this return code
  File "C:\Program Files (x86)\wapt\common.py", line 3851, in install_wapt
  File "C:\waptdev\iut-dell-bios-configuration-wapt\setup.py", line 39, in install
    run (r'"C:\Program Files (x86)\Dell\Command Configure\X86_64\cctk.exe" --numlock=enabled --valsetuppwd=impossiblepasswd', return_stderr=errlist, accept_returncodes=[0,3])
  File "C:\Program Files (x86)\wapt\common.py", line 3630, in run
    return ensure_unicode(setuphelpers.run(*arg,pidlist=self.pidlist,**args))
  File "C:\Program Files (x86)\wapt\setuphelpers.py", line 1066, in run
    raise CalledProcessErrorOutput(proc.returncode,cmd,''.join(output+return_stderr))
CalledProcessErrorOutput: Command '"C:\\Program Files (x86)\\Dell\\Command Configure\\X86_64\\cctk.exe" --numlock=enabled --valsetuppwd=impossiblepasswd' returned non-zero exit status 58.
Output:
The setup password provided is incorrect. Please try again.
I would like to be able to retrieve this exit code (58 and 106 in my specific case) in order to be able to verify my first condition.
I tried a try/except on the command to capture the return code, it works great in pyscripter but impossible to launch a package on the clients.
import subprocess
def ispwddefined():
    try:
        print (subprocess.check_output(["C:\Program Files (x86)\Dell\Command Configure\X86_64\cctk.exe", "--numlock=enabled", "--valsetuppwd=impossiblepasswd "]).decode())
    except subprocess.CalledProcessError, e:
        cctkerrorcode = e.returncode
        print cctkerrorcode
    if (cctkerrorcode == 58):
        print "password configured"
        return True;
    elif(cctkerrorcode == 106):
        print ("no password configured")
        return False
    print ispwddefined()
In the PyScripter environment, launching the execution configuration "install" correctly displays the True or False value as well as the relevant return code.
Ligne de Commande : install "C:\waptdev\iut-dell-bios-configuration-wapt\WAPT\.."
Installing WAPT files C:\waptdev\iut-dell-bios-configuration-wapt
58
password configured
True
Once the package is in the repository and deployed to a test machine, I get this error:
UnboundLocalError: local variable 'cctkerrorcode' referenced before assignment
I tried defining the cctkerrorcode variable at the beginning of the ispwddefined() function, and here's something even more curious: the package is successful, and the result is:
NumLock=Enabled
None
I have the impression that in this case, he doesn't see the cctk error...
I must admit that I'm starting to fall short of what I know how to do...
Does anyone know how to capture return codes in a more basic way?
Seb.
seb b
December 17, 2019 - 3:46 PM
Hello again,
I'm adding fuel to the fire, and I apologize in advance...
I just tested it by running the command that should throw an error, specifying that it should accept return code 58 (a password is defined, you didn't provide the correct one), and there was no error. The return code I'm trying to retrieve is indeed returned to the 'run' command. Is it possible to retrieve this code (easily) into a variable?
run (r'"C:\Program Files (x86)\Dell\Command Configure\X86_64\cctk.exe" --numlock=enabled --valsetuppwd=impossiblepasswd', accept_returncodes=[0,58])
December 17, 2019 - 3:54 PM
The `run` command returns a slightly enriched string...
a returncode attribute gives the return code.
result = run (r'"C:\Program Files (x86)\Dell\Command Configure\X86_64\cctk.exe" --numlock=enabled --valsetuppwd=impossiblepasswd'")
if result.returncode == 58:
    print('Probleme mot de passe')
seb b
December 17, 2019 - 4:12 PM
THANKS!
Unfortunately, it seems that the result of `run` is not an object but Unicode (I'm not sure of my terminology, I admit) :oops: ).
AttributeError: 'unicode' object has no attribute 'returncode'
I tried directly printing the run command with exactly the same result.
print (run (r'"C:\Program Files (x86)\Dell\Command Configure\X86_64\cctk.exe" --numlock=enabled --valsetuppwd=impossiblepasswd', accept_returncodes=[0,58]).returncode)
December 17, 2019 - 7:04 PM
With wapt 1.7.4, it's Unicode enriched with the attribute...
Which version do you have?
seb b
December 18, 2019 - 8:10 AM
we are on version 1.7.4.6229.
December 18, 2019 - 09:32
I see the problem...
The `run` command in the Wapt class (the one available in the package's `install` function) is patched to return Unicode (for obscure backward compatibility reasons)
But the setuphelpers.run command returns either unicode or bytes (raw string output from the launched command) with the returncode attribute depending on whether the launched command is in unicode or bytes.
https://github.com/tranquilit/WAPT/blob ... rs.py#L949
https://github.com/tranquilit/WAPT/blob ... s.py#L1075
In your case, you should therefore use the direct run function of setuphelpers:
import setuphelpers
    result = setuphelpers.run (r'"C:\Program Files (x86)\Dell\Command Configure\X86_64\cctk.exe" --numlock=enabled --valsetuppwd=impossiblepasswd'")
seb b
December 18, 2019 - 10:07 AM
Great!
It works, thank you so much.
Now I just have to do the rest of the package.
Thanks again!
Gaelds
Registration: Nov 22, 2015 - 08:37
November 29, 2023 - 4:21 PM
I'm trying to do the same thing as "Seb b" but I can't retrieve the return code with `result.returncode`. I think the installation crashes on the first run with the errors below. When the provided password matches the BIOS password, the script displays "Return code = 0.".
Dell BIOS setup with pass
Error installing ['dst-Bios_DELL_Update-wapt']: errors in packages [[PackageRequest(package='dst-Bios_DELL_Update-wapt',architectures=['x64'],locales=['fr'],maturities=['PROD', 'DEV'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'], min_os_version=Version('10.0.22621'), max_os_version=Version('10.0.22621')), PackageEntry('dst-Bios_DELL_Update-wapt','1.0.0-62' maturity='DEV'), 'Traceback (most recent call last):\n File "C:\\Program Files (x86)\\wapt\\common.py", line 5192, in install\n result = self.install_wapt(p.localpath,\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4176, in install_wapt\n raise e\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4083, in install_wapt\n exitstatus = setup.install()\n File "C:\\Windows\\TEMP\\waptpzh4plq3\\setup.py", line 16, in install\n File "C:\\Program Files (x86)\\wapt\\common.py", line 3860, in run\n return ensure_unicode(run(*arg, pidlist=self.pidlist,**args))\n File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 2118, in run\n raise CalledProcessErrorOutput(proc.returncode, cmd, \'\'.join(output))\nwaptutils.CalledProcessErrorOutput: Command \'"C:\\\\Program Files (x86)\\\\Dell\\\\Command Configure\\\\X86_64\\\\cctk.exe" -i cctk.ini --valsetuppwd=password -lc:\\\\dell_cctk.log\' returned non-zero exit status 58.\nOutput:CCTKAppEngVer=4.10.1.11\r\n\r\nThe setup password provided is incorrect. Please try again.\r\n\n']]
File "C:\Program Files (x86)\wapt\waptservice\service.py", line 1910, in run
self.running_task.run()
File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 716, in run
self._run()
File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 1288, in _run
Exception: Error during installation of ['dst-Bios_DELL_Update-wapt']: errors in packages [[PackageRequest(package='dst-Bios_DELL_Update-wapt',architectures=['x64'],locales=['fr'],maturities=['PROD', 'DEV'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.22621'),max_os_version=Version('10.0.22621')), PackageEntry('dst-Bios_DELL_Update-wapt','1.0.0-62' maturity='DEV'), 'Traceback (most recent call last):\n File "C:\\Program Files (x86)\wapt\common.py", line 5192, in install\n result = self.install_wapt(p.localpath,\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4176, in install_wapt\n raise e\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4083, in install_wapt\n exitstatus = setup.install()\n File "C:\\Windows\\TEMP\\waptpzh4plq3\\setup.py", line 16, in install\n File "C:\\Program Files (x86)\\wapt\\common.py", line 3860, in run\n return ensure_unicode(run(*arg, pidlist=self.pidlist,**args))\n File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 2118, in run\n raise CalledProcessErrorOutput(proc.returncode, cmd, \'\'.join(output))\nwaptutils.CalledProcessErrorOutput: Command \'"C:\\\\Program Files (x86)\\\\Dell\\\\Command Configure\\\\X86_64\\\\cctk.exe" -i cctk.ini --valsetuppwd=password -lc:\\\\dell_cctk.log\' returned non-zero exit status 58.\nOutput:CCTKAppEngVer=4.10.1.11\r\n\r\nThe setup password provided is incorrect. Please try again.\r\n\n']]
Exception: Error installing ['dst-Bios_DELL_Update-wapt']: errors in packages [[PackageRequest(package='dst-Bios_DELL_Update-wapt',architectures=['x64'],locales=['fr'],maturities=['PROD', 'DEV'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'], min_os_version=Version('10.0.22621'), max_os_version=Version('10.0.22621')), PackageEntry('dst-Bios_DELL_Update-wapt','1.0.0-62' maturity='DEV'), 'Traceback (most recent call last):\n File "C:\\Program Files (x86)\\wapt\\common.py", line 5192, in install\n result = self.install_wapt(p.localpath,\n File "C:\\Program Files (x86)\wapt\common.py", line 4176, in install_wapt\n raise e\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4083, in install_wapt\n exitstatus = setup.install()\n File "C:\\Windows\\TEMP\\waptpzh4plq3\\setup.py", line 16, in install\n File "C:\\Program Files (x86)\\wapt\\common.py", line 3860, in run\n return ensure_unicode(run(*arg, pidlist=self.pidlist,**args))\n File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 2118, in run\n raise CalledProcessErrorOutput(proc.returncode, cmd, \'\'.join(output))\nwaptutils.CalledProcessErrorOutput: Command \'"C:\\\\Program Files (x86)\\\\Dell\\\\Command Configure\\\\X86_64\\\\cctk.exe" -i cctk.ini --valsetuppwd=password -lc:\\\\dell_cctk.log\' returned non-zero exit status 58.\nOutput:CCTKAppEngVer=4.10.1.11\r\n\r\nThe setup password provided is incorrect. Please try again.\r\n\n']]
self._run()
Exception: Error during installation of ['dst-Bios_DELL_Update-wapt']: errors in packages [[PackageRequest(package='dst-Bios_DELL_Update-wapt',architectures=['x64'],locales=['fr'],maturities=['PROD', 'DEV'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.22621'),max_os_version=Version('10.0.22621')), PackageEntry('dst-Bios_DELL_Update-wapt','1.0.0-62' maturity='DEV'), 'Traceback (most recent call last):\n File "C:\\Program Files (x86)\\wapt\\common.py", line 5192, in install\n result = self.install_wapt(p.localpath,\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4176, in install_wapt\n raise e\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4083, in install_wapt\n exitstatus = setup.install()\n File "C:\\Windows\\TEMP\\waptpzh4plq3\\setup.py", line 16, in install\n File "C:\\Program Files (x86)\\wapt\\common.py", line 3860, in run\n return ensure_unicode(run(*arg, pidlist=self.pidlist,**args))\n File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 2118, in run\n raise CalledProcessErrorOutput(proc.returncode, cmd, \'\'.join(output))\nwaptutils.CalledProcessErrorOutput: Command \'"C:\\\\Program Files (x86)\\\\Dell\\\\Command Configure\\\\X86_64\\\\cctk.exe" -i cctk.ini --valsetuppwd=password -lc:\\\\dell_cctk.log\' returned non-zero exit status 58.\nOutput:CCTKAppEngVer=4.10.1.11\r\n\r\nThe setup password provided is incorrect. Please try again.
cctk_binaries = makepath(programfiles32,'Dell','Command Configure','X86_64','cctk.exe')
    import wmi
    c = wmi.WMI()
    for computersystem in c.Win32_ComputerSystem():
        if(computersystem.Manufacturer == "Dell Inc."):
            if(isfile(cctk_binaries)):
                print(r'Configuration BIOS Dell avec pass')
                result = run (r'"%s" -i cctk.ini --valsetuppwd=password -l c:\dell_cctk.log' %cctk_binaries)
                print(f"Code retour = {result.returncode}.")
                    print(r"Le mot de passe BIOS n'est pas le pass habituel !")
                if result.returncode == 106:
                    print(r"Le mot de passe BIOS est vide, tentative d'ajout du mot de passe")
                    run (r'"%s" -i cctk.ini --setuppwd=password  ' %cctk_binaries)
                    print(r"Resultat de la config CCTK ok")
November 29, 2023 - 10:45 PM
The message in your case is: The setup password provided is incorrect. Please try again with exit code 58
So if you want to catch code 58, I recommend using accept_returncodes:
result = run (r'"%s" -i cctk.ini --valsetuppwd=password -l c:\dell_cctk.log' %cctk_binaries,accept_returncodes=[0, 3010,58])
if result.returncode = 58:
    print(r"Le mot de passe de configuration fourni est incorrect")
or to switch it to error:
    error(r"Le mot de passe de configuration fourni est incorrect")
