Deploy printer drivers
Jonathan
Registration: Oct 06, 2015 - 12:59
November 3, 2015 - 4:55 PM
I'm contacting you because I'm trying to install a WAPT package to set up three Konica printers. It seems I'm missing something during the installation process.
I'm sending you screenshots in case you can help me find the errors.
Thank you in advance.
Jonathan LPC2E
Jonathan
November 3, 2015 - 4:57 PM
Here's the rest... :)
Best regards,
Jonathan LPC2E
November 3, 2015 - 10:42 PM
Is there an error message or is nothing happening at all?
November 4, 2015 - 8:00 AM
Apparently, the VBS script uses functions that cannot be "silent" (dialog box, message box...) so the script will remain waiting for user action in the background.
Jonathan
November 4, 2015 - 10:12
Yes, there is a timeout issue. It might be due to the user waiting for an action in the background.
I'll look for a solution.
Thank you.
Cédric
Registration: January 12, 2016 - 10:16
January 12, 2016 - 10:24
take a look at the PnPUtil function (https://technet.microsoft.com/fr-fr/lib ... s.10).aspx) which is native to Windows 7... You can use PnPUtil to add driver packages, remove driver packages, and list driver packages in the store...
Then, here's the script to add the printer: http://www.badministrateur.com/fr/node/92
Cédric
