I had to migrate my WAPT console to another computer.
Since then, I haven't been able to complete the installations. I get the following error:
Installing 724B117C-76F4-4BD3-94CA-CCB43094EC59(=4)
File "C:\Program Files (x86)\wapt\waptservice\service.py", line 1711, in run
self.running_task.run()
File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 559, in run
self._run()
File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 1017, in _run
Exception: Erreur lors de l'installation de [u'724B117C-76F4-4BD3-94CA-CCB43094EC59(=4)']: erreurs dans les paquets [[PackageRequest(package=u'724B117C-76F4-4BD3-94CA-CCB43094EC59',version=(Version('4.0.0.0'), None),architectures=[u'x64'],locales=['fr'],maturities=[u'PROD'],min_os_version=Version('10.0.18362'),max_os_version=Version('10.0.18362')), PackageEntry(u'724B117C-76F4-4BD3-94CA-CCB43094EC59',u'4' ), u'Traceback (most recent call last):\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4855, in install\n force=force\n File "C:\\Program Files (x86)\\wapt\\common.py", line 3934, in install_wapt\n raise e\nEWaptUnavailablePackage: Missing dependencies: xxxx-7zip\n']]
self._run()
Exception: Erreur lors de l'installation de [u'724B117C-76F4-4BD3-94CA-CCB43094EC59(=4)']: erreurs dans les paquets [[PackageRequest(package=u'724B117C-76F4-4BD3-94CA-CCB43094EC59',version=(Version('4.0.0.0'), None),architectures=[u'x64'],locales=['fr'],maturities=[u'PROD'],min_os_version=Version('10.0.18362'),max_os_version=Version('10.0.18362')), PackageEntry(u'724B117C-76F4-4BD3-94CA-CCB43094EC59',u'4' ), u'Traceback (most recent call last):\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4855, in install\n force=force\n File "C:\\Program Files (x86)\\wapt\\common.py", line 3934, in install_wapt\n raise e\nEWaptUnavailablePackage: Missing dependencies: xxxx-7zip\n']]I regenerated a new agent, etc... but it doesn't work.
I missed something but I don't know what.
Thank you in advance
