Chrome Update Problem
Theo
Registration: January 20, 2020 - 3:43 PM
January 20, 2020 - 5:36 PM
WAPT console in version 1.7.4
Server running Windows Server 2016
Windows 10 Clients
I need to update Chrome to version 79.0.3945.130-2 on all PCs in my infrastructure, so I downloaded this package: https://store.wapt.fr/store/tis-chrome
However, when installing on some PCs (not all, only a small minority), I get the following error message:
Installing dep-chrome
Exception: Erreur lors de l'installation de dep-chrome (=79.0.3945.130-2): erreurs dans les paquets [[u'dep-chrome (=79.0.3945.130-2)', PackageEntry('dep-chrome','79.0.3945.130-2') architecture=x64]]
  File "C:\Program Files (x86)\wapt\waptservice\waptservice.py", line 1151, in run
    self.running_task.run()
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 405, in pwrapper
    return func(*arg, **kwargs)
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 464, in run
    self._run()
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 884, in _run
And when I go to the list of packages installed on the PC and click on the Chrome package that's causing the error, the following message appears below:
installing dep-chrome (=79.0.3945.130-2)
File C:\Program Files (x86)\Google\Chrome\Application\chrome.exe version is : 79.0.3945.130
Paquet version is : 79.0.3945.130
NameError: global name 'force' is not defined
On other PCs (again, only a few), I get this error:
installing dep-chrome(=79.0.3945.130-2)
  File "C:\Program Files (x86)\wapt\common.py", line 3851, in install_wapt
  File "c:\windows\temp\waptiffwaa\setup.py", line 37, in install
  File "C:\Program Files (x86)\wapt\common.py", line 3807, in new_func
    return func(*args,**kwargs)
  File "C:\Program Files (x86)\wapt\setuphelpers.py", line 4255, in install_msi_if_needed
    error('MSI %s has been installed and the uninstall key %s found but version is not good' % (msi,key))
  File "C:\Program Files (x86)\wapt\setuphelpers.py", line 4676, in error
    raise EWaptSetupException(u'Fatal error : %s' % reason)
EWaptSetupException: Fatal error : MSI googlechromestandaloneenterprise64.msi has been installed and the uninstall key {0F488B35-59E5-3DA0-80FA-55F3BE746A68} found but version is not good
Could you help me deal with these two problems?
Thanks in advance
Mathieu
Registration: August 18, 2016 - 10:24
December 2, 2020 - 6:25 PM
Currently, I'm also getting the error
EWaptSetupException: Fatal error: MSI googlechromestandaloneenterprise64_87.0.4280.66.msi has been installed and the uninstall key {27AC56BA-489B-3BDF-98B8-AA1CE49ABB9F} was found, but the version is not good,
but not on all machines.
- WAPT 2.2.3.12463 Enterprise
- Debian 9.9
- Windows 10 21H2 & Windows 11 22h2
jpele
Registration: March 4, 2019 - 12:01
December 3, 2020 - 10:07 AM
We are not experiencing any similar issues with this version across our entire network.
Could you please provide more details about the affected workstations?
Jimmy
Mathieu
December 3, 2020 - 10:24 AM
It's affecting machines running Windows 10 version 1909 and it impacts any type of desktop or laptop computer
When I look at a post where the problem is present, the registry is fine.
Reg_mathieu
Reg_mathieu
- Debian 9.9
avondra
Registration: Nov 9, 2016 - 12:02
January 18, 2021 - 1:22 PM
have you found a solution? I'm also experiencing this kind of problem on some computers, with no real hardware or software differences, about ten out of 120 computers.
Thank you.
MathieuL
Registration: January 12, 2021 - 1:14 PM
January 18, 2021 - 1:28 PM
judging from the error message in the first post, it seems that the posts with the errors are 32-bit and not 64-bit...
could that be the reason?
Wapt 1.8.7334 Enterprise - Windows Server 2016 Datacenter
Admin Console on the server itself
jpele
January 19, 2021 - 2:10 PM
Hello everyone,
Could you please try a complete uninstallation, manually verifying on an affected machine that Chrome is indeed uninstalled, followed by an installation via WAPT?
I look forward to your feedback,
Best regards,
Jimmy
Mathieu
March 10, 2021 - 08:49
Sorry for the delay.
I just uninstalled manually and then reinstalled via WAPT; the error is gone.
- Debian 9.9
Mathieu
June 1, 2021 - 12:07
I'm still having the same problem. What's happening is that during installation, it keeps traces of the old executable.
As a result, I keep getting the error in the console
: EWaptSetupException: Fatal error: MSI googlechromestandaloneenterprise64_91.0.4472.77.msi has been installed and the uninstall key {B6E20433-9CA8-39D7-93CD-7191D79C0A6C} found but version is not good.
Regardless of the version, I get this error, whether I force the installation or reboot.
In Windows, the latest version is installed, but since the executable hasn't changed, it's still using the old one.
Am I the only one experiencing this?
- Debian 9.9
June 1, 2021 - 5:41 PM
Hi Mathieu,
there's a new_chrome.exe file nearby. It seems to be a replacement for an .exe file on reboot. If the .exe is launched during package installation, the installer might create a separate .exe and update the registry to swap the .exe files on the next reboot.
If the computer has rebooted and the .exe files haven't swapped, that's quite odd. Could you try installing the MSI manually to see if the same problem occurs?
Best regards,
