I'm currently using the free version 1.8.
As stated in the documentation:
"Since the packages in the local repository are signed with the old key, all packages must be re-signed with the new key.
To re-sign all WAPT packages with the new key (software and machine packages), use the command:
wapt-get sign-packages C:\\waptdev\\*
I ran this command:
C:\WINDOWS\system32>wapt-get sign-packages C:\\waptdev\\*
Unknown action sign-packages
But it didn't solve my problem.
I'm actually testing WAPT; my server is running CentOS 7.5, and the console is on Windows 10.
Perhaps the simplest solution is to start over. Is there a procedure to start from scratch, avoiding reinstalling the server and the console?
Thank you.
re-sign all packages with the new key
(Question: Why do you need to resign the packages?)
It is faster to resign the packages directly on the server(Otherwise you will need to download all the packages to your computer, re-sign them and re-upload them)
To do this, you must temporarily copy your private key (.pem) and your certificate to the server (using winscp3 for example) and then launch the wapt-signpackages command in an ssh session on the server.
For example...
Do not leave your key (.pem) on the server.
Help :
For example...
wapt-signpackages -i -s -c /root/moi.crt -k /root/moi.pem /var/www/wapt/*.waptHelp :
]# wapt-signpackages --help
Usage: wapt-signpackages -c crtfile package1 package2
Resign a list of packages
Options:
-h, --help show this help message and exit
-c PUBLIC_KEY, --certificate=PUBLIC_KEY
Path to the PEM RSA certificate to embed identitiy in
control. (default: )
-k PRIVATE_KEY, --private-key=PRIVATE_KEY
Path to the PEM RSA private key to sign packages.
(default: )
-l LOGLEVEL, --loglevel=LOGLEVEL
Loglevel (default: warning)
-m MD, --message-digest=MD
Message digest type for signatures. (default: sha256)
-s, --scan-packages Rescan packages and update local Packages index after
signing. (default: False)
-r, --remove-setup Remove setup.py. (default: False)
-i, --inc-release Increase release number when building package
(default: False)
--maturity=SET_MATURITY
Set/change package maturity when signing package.
(default: None)
--keep-signature-date
Keep the current package signature date, and file
changetime (default: False)
--if-needed Re-sign package only if needed
I think it's impossible without reinstalling the server and the consolemouka wrote: ↑Jan 29, 2020 - 11:03 AM Hello,
I'm currently using version 1.8 free:
I ran this:
But my problem is still not resolved.
I'm actually testing WAPT; my server is running CentOS 7.5 and the console is on Windows 10.
Perhaps the simplest solution is to start over. Is there a procedure to begin from scratch, avoiding reinstalling the server and console?
Thank you.
If you find another solution, please write it here
THANKS
As soon as I know it's about technology or spying, like locating a cell phone, I lose interest. I want to know what's going on in people's minds.
- WAPT Expert
wapt-signpackages -s --message-digest=sha256,sha1 -c C:\private\wapt-private-20180312-1522.crt C:\wapt\waptserver\repository\wapt\*.wapt
