Specify installed WAPT version (1.8.0)
* Specify server OS (Linux / Windows) and version (Debian Buster)
* Specify OS of the administration/package creation machine (Windows 10)
I just finished upgrading to 1.8, however, my entire network is no longer visible. When I say visible, I mean that they detect all of my networks as disconnected (reachable) (except for about fifteen machines)...
I've reset the WebSockets and cleared my console cache, but still nothing.
Thank you for your help.
[RESOLVED] No machine reachable after update 1.8
- WAPT Expert
Hello
, could you give us more details?
Which version are you using?
- WAPT Expert
Has the waptupgrade package been delivered?
On an agent you can launch:
To understand the problem
"C:\Program Files (x86)\wapt\runwaptservice.bat" -ldebugHello,
the package is showing as TO-UPDATE, but it doesn't indicate that the machine is reachable. This morning most PCs were reachable, so I think the daily reboot was enough for the console to "see" them again. There's nothing alarming in the debug logs, at least no errors at first glance.
I'm marking this as resolved.
Thanks
Thanks
jeancharles
- Registration: June 11, 2019 - 10:02
I have the same problem: two newly installed agents (version 1.8.0), and the status isn't showing up.
I've rebooted both the client and the server without success.
We'll see if sleeping on it helps!
jeancharles
I've updated Windows on both the server and the client, disabled the firewall, and reinstalled the WAPT agent, but nothing has worked.
In the performance monitor, I can see the connections to the WAPT server via TCP/443 and TCP/80, but they aren't showing up in the console.
I also can't see the self-service packages.
Where should I look? I can create a new thread if needed. Thank you for your help.
jeancharles
Result of wapt-get update-status:
waptserver is not available or error in inventory. Update of status not properly sent.
I can ping the wapt server, and testing with Edge shows access to the local wapt site is OK.
jeancharles
C:\Users\> wapt-get update
Update package list from https://svwapt01/wapt, https://srvwapt01/wapt-host
2020-01-30 10:51:30,392 CRITICAL Error merging Packages from https://srvwapt01/wapt into db: HTTPError: 400 Client Error: Bad Request for url: https://srvwapt01/wapt/Packages
Total packages: 0
Added packages:
Removed packages:
Discarded packages count: 0
Pending operations:
upgrade:
additional:
install:
remove:
Repositories URL:
Total packages: 0
Added packages:
Removed packages:
Pending operations:
upgrade:
additional:
install:
remove:
Repositories URL:
