I have WAPT Community on a Debian server with the following specifications:
WAPT Server version: 1.7.3.5 (Debian Stretch)
WAPT Agent version: 1.7.3.5
WAPT Setup version: 1.7.3.5
WAPT Deploy version: 1.7.3.5
Database status: OK (1.7.3.2)
The goal is to perform an update to version 1.8
in /etc/apt/sources.list.d/wapt.list
deb https://wapt.tranquil.it/debian/wapt-1.8/ stretch main.
During the update step (apt-get update)
, it loops at 18% and I get
: Ign:8 https://wapt.tranquil.it/debian/wapt-1.8 stretch/main all Packages
Err:9 https://wapt.tranquil.it/debian/wapt-1.8 stretch/main amd64 Packages
Received HTTP code 502 from proxy after CONNECT
Ign:10 https://wapt.tranquil.it/debian/wapt-1.8 stretch/main Translation-en_US
Ign:11 https://wapt.tranquil.it/debian/wapt-1.8 stretch/main Translation-en
Reading package lists... Done
W: The repository 'https://wapt.tranquil.it/debian/wapt-1.8 stretch Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: Failed to fetch https://wapt.tranquil.it/debian/wapt-1. ... 4/Packages Received HTTP code 502 from proxy after CONNECT
E: Some index files failed to download. They have been ignored, or old ones used instead.
With
curl -k https://wapt.tranquil.it/debian/wapt-1. ... /InRelease | gpg --keyring /etc/apt/trusted.gpg --verify
gpg: directory '/root/.gnupg' created
gpg: keybox '/root/.gnupg/pubring.kbx' created
% Total %
Received
% --:--:-- --:--:-- --:--:-- 10891
gpg: Signature made Wed 23 Oct 2019 03:07:22 PM CEST
gpg: using RSA key 8F41DAF53DBC098A9AB916000022908B0C0E47AD
gpg: /root/.gnupg/trustdb.gpg: trustdb created
gpg: Good signature from "Tranquil IT Systems <contact@tranquil.it>" [unknown]
gpg: WARNING: This key is not certified with a trusted signature!
gpg: There is no indication that the signature belongs to the owner.
Primary key fingerprint: 8F41 DAF5 3DBC 098A 9AB9 1600 0022 908B 0C0E 47AD
command
wget -O https://wapt.tranquil.it/debian/tiswapt-pub.gpg | apt-key add -
--2020-02-04 15:23:07-- https://wapt.tranquil.it/debian/tiswapt-pub.gpg
Resolving wapt.tranquil.it (wapt.tranquil.it)... 195.154.18.13
Connecting to wapt.tranquil.it (wapt.tranquil.it)|195.154.18.13|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 3839 (3.7K)
Saving to: 'STDOUT'
- 100%[===================>] 3.75K --.-KB/s in 0s
2020-02-04 15:23:08 (47.4 MB/s) - written to stdout [3839/3839]
OK
Thank you for help...
[RESOLVED] Update from 1.7 to 1.8
- WAPT Expert
it seems there's a proxy configuration error in the apt settings... The GPG key is downloaded correctly, so the internet connection/DNS configuration appears to be working, but the proxy seems to be the problem.
Regards,
Regards,
