[SOLVED] Number of workstations to which a packet group is assigned
Share your SQL query ideas for reporting in the WAPT Enterprise console here
Renaud Villet
Registration: January 23, 2020 - 2:12 PM
January 23, 2020 - 2:17 PM
I'd like to create a query that will give me the number of machines on which a package group is installed...is that possible?
Thanks
Mathieu
Registration: August 18, 2016 - 10:24
February 3, 2020 - 10:08 AM
There is this script that you can modify according to what you want to display.
select package,version,architecture,description,section,package_uuid,count(*)
from hostpackagesstatus s
where section not in ('host','unit','group')
group by 1,2,3,4,5,6
You replace 'group' with 'base' to display only package groups
- WAPT 2.2.3.12463 Enterprise
- Debian 9.9
- Windows 10 21H2 & Windows 11 22h2
Renaud Villet
February 4, 2020 - 4:58 PM
Yes, it works, thank you!
Now for the trickier part: is it possible to get the number of computers to which a particular package group has been assigned, sorted by domain?
Thank you.
Mathieu
February 5, 2020 - 9:44 AM
I don't have that one in my list that I got through Tranquil IT, sorry
- Debian 9.9
eblaudy
Registration: August 5, 2019 - 2:15 PM
February 17, 2020 - 4:50 PM
Here's what you're looking for:
SELECT hosts.dnsdomain, COUNT(hosts.uuid)
FROM hosts, hostpackagesstatus
WHERE hosts.uuid = hostpackagesstatus.host_id AND hostpackagesstatus.package = 'tis-wsl-debian'
GROUP BY hosts.dnsdomain
ORDER BY 2 DESC
Simply replace "tis-wsl-debian" with the name of your package group.
This works for any package name ;) Group or not!
Have a good rest of the day
WAPT Developer at TRANQUIL IT
