[SOLVED] NGINX - 403 Client Error: Forbidden
Kavinus
March 4, 2020 - 01:28
When installing agents on new workstations, they are not automatically displayed in the console.
Using "wapt-get register xxxxx" I get the following error:
HTTPError: 403 Client Error: Forbidden for url: https://srvwapt.domain.lan/add_host_kerberos
It doesn't work from the browser either.
Same error for the address: https://srvwapt.domain.lan/wapt
For workstations already registered, there are no problems installing packages.
Thank you for your help.
- Installed WAPT version: 1.8.1.6742 (Enterprise)
- Server OS (Debian 10 Buster)
- Administration/package creation machine OS (Windows 10 v19.09)
agauvrit
Registration: Nov 17, 2016 - 10:25
March 4, 2020 - 09:48
Your problem is related to Kerberos agent registration.
If you have enabled Kerberos registration for workstations, there are additional configuration steps to follow: https://www.wapt.fr/fr/doc/wapt-securit ... beros.html
If you do not want this functionality, repeat the post-configuration step on the server to revert to registration without Kerberos or a password, for example: https://www.wapt.fr/fr/doc/waptserver-i ... onfiguring
Alexandre
Kavinus
March 4, 2020 - 11:03 PM
I followed the steps at https://www.wapt.fr/fr/doc/wapt-securit ... beros.html.
I just reconfigured the server following these steps: https://www.wapt.fr/fr/doc/waptserver-i ... onfiguring.
Unfortunately, the problem still persists.
Thank you.
March 5, 2020 - 09:14
In that case, I invite you to follow this thread:
viewtopic.php?f=13&t=2198
