[SOLVED] Windows machine with 4 GB RAM or less
Share your SQL query ideas for reporting in the WAPT Enterprise console here
chris60fr
Registration: March 1, 2018 - 2:02 PM
April 20, 2020 - 12:48
Hello
WAPT 1.7
Debian Stretch.
I'm trying to run a query that lists all PCs running Windows with 4 GB of RAM or less.
Thank you for your help.
April 24, 2020 - 10:28
Good morning
Replace the value 4286169088 with the value you want
select host_metrics->'physical_memory' as RAM , host_metrics->'last_logged_on_user' as User, host_info->'computer_fqdn'  as Name from hosts WHERE host_metrics->'physical_memory'<'4286169088'
chris60fr
April 28, 2020 - 6:08 PM
Thank you so much :D
