on a fresh installation of WAPT 1.8.1 Community
, I launch the console from the WAPT Tray after the initial installation via waptsetup-tis.exe on Windows 10.
Unlike version 1.7.4, there is no privilege elevation request.
This is clearly causing a problem because the permissions to copy the generated admin certificate to C:\Program Files (x86)\wapt\ssl are missing.
If I launch waptconsole manually as administrator, I don't encounter this issue.
Is this normal?
Thank you in advance.
wapt console permissions problem
- WAPT Expert
Hello
, yes, that's intentional; the console doesn't need to be run as administrator on a daily basis.
Copy the certificate manually, or install the agent you just generated.
Thanks for the quick reply.
If I understand the documentation correctly, the certificate needs to be located in C:\Program Files (x86)\wapt\ssl
to be included in the agent installer?
So, in my case, if I haven't copied the file manually, the generated installer is incorrect.
Am I wrong?
Am I wrong?
- WAPT Expert
Not anymore; now the integrated certificates are displayed during agent generation
Yes, it will be correct, but your own machine will not have the certificate in wapt/ssl/
