wapt-signpackages md5 sum
aflorent
Registration: Apr 23, 2020 - 5:03 p.m.
May 11, 2020 - 7:38 PM
Good morning
When I re-sign a package on the WAPT server (version 1.8.1 community), the MD5 hash used to rename the file is incorrect
e.g. I download from your repository
wget https://wapt.tranquil.it/wapt/tis-dnsutils_9.9.6-6_557a981985944927c5a819589e2bb51f.wapt
The file has the md5 hash 557a981985944927c5a819589e2bb51f, which is found in the file name
root@wapt:/home/waptrepo/wapt# md5sum tis-dnsutils_9.9.6-6_557a981985944927c5a819589e2bb51f.wapt
557a981985944927c5a819589e2bb51f  tis-dnsutils_9.9.6-6_557a981985944927c5a819589e2bb51f.wapt
I sign this package with my private key
root@wapt:/home/waptrepo/wapt# wapt-signpackages -c /tmp/key.crt tis-dnsutils_9.9.6-6_557a981985944927c5a819589e2bb51f.wapt -l debug
2020-05-11 19:26:20,379 DEBUG SUCCESS key /tmp/key.pem match certificate /tmp/key.crt
Processing tis-dnsutils_9.9.6-6_557a981985944927c5a819589e2bb51f.wapt
2020-05-11 19:26:20,381 DEBUG Signing /home/waptrepo/wapt/tis-dnsutils_9.9.6-6_557a981985944927c5a819589e2bb51f.wapt with key <SSLPrivateKey u'/tmp/key.pem'>, and certificate CN "afl0423"
Done
Don't forget to rescan your repository with wapt-scanpackages
but the file name does not contain the new md5 checksum, but the old one
root@wapt :/home/waptrepo/wapt# md5sum tis-dnsutils_9.9.6-6_557a981985944927c5a819589e2bb51f.wapt
db9dd60b5d040fbc38b4debea67e1ab6  tis-dnsutils_9.9.6-6_557a981985944927c5a819589e2bb51f.wapt
Is this normal?
I have the impression that this prevents the package from being installed on the agent because the calculated MD5 checksum does not match either the one in the file name or in the Packages file...
May 12, 2020 - 1:58 PM
No, there is indeed a bug, I'll look into fixing it
aflorent
May 12, 2020 - 2:07 PM
I managed to fix it by adding
`pe.md5sum=md5_for_file(pe.localpath)`
between the calls to `pe.sign_package` and `newfn = pe.make_package_filename()`
, but perhaps it's better to do it within the `sign_package` function.
aflorent
May 12, 2020 - 2:08 PM
Anyway, thank you
May 19, 2020 - 3:56 PM
Unable to reproduce the problem using the following procedure:
PYTHONPATH=/opt/wapt PYTHONHOME=/opt/wapt python /opt/wapt/wapt-signpackages.py -s --message-digest=sha256,sha1 -c /private/sfonteneau.crt /var/www/wapt/*.wapt
wapt-scanpackages -r -f -ldebug /var/www/wapt/
I'm going to update the documentation
aflorent
May 19, 2020 - 4:57 PM
Hello and thank you for your tests.
I just tested it as you did,
adding the call to wapt-scanpackages, but nothing is fixed.
The Packages file contains
: filename: tis-dnsutils_9.9.6-6_557a981985944927c5a819589e2bb51f.wapt
md5sum: 557a981985944927c5a819589e2bb51f,
while the MD5 sum is different:
md5sum tis-dnsutils*.wapt
5233389ccb2e3d90175902452ce79e94 tis-dnsutils_9.9.6-6_557a981985944927c5a819589e2bb51f.wapt.
As a reminder, I Download the Wapt file directly from https://wapt.tranquil.it/wapt without using WaptConsole.
Thank you.
May 19, 2020 - 5:18 PM
I tested it in the latest version; the problem must have been fixed in this one
aflorent
May 19, 2020 - 5:55 PM
For my part, it's version 1.8.1.6756-ubuntu-18-43394f3b
What do you mean by the latest version?
another way of looking at the problem
if we rename the downloaded file before signing the package
mv tis-dnsutils_9.9.6-6_557a981985944927c5a819589e2bb51f.wapt tis-dnsutils.wapt
 wapt-signpackages -c /tmp/key.crt -l debug --message-digest=sha256,sha1  -s tis-dnsutils*.wapt
2020-05-19 17:53:38,551 DEBUG SUCCESS key /tmp/key.pem match certificate /tmp/key.crt
Processing tis-dnsutils.wapt
2020-05-19 17:53:38,561 DEBUG Signing /home/kwartz/waptrepo/tmp/tis-dnsutils.wapt with key <SSLPrivateKey u'/tmp/key.pem'>, and certificate CN "afl0423"
Renaming file from tis-dnsutils.wapt to tis-dnsutils_9.9.6-6_557a981985944927c5a819589e2bb51f.wapt to match new package's properties
Done
but the md5 checksum in the filename does not match the calculated one
9620e3834870274b53b084319ace1f00 tis-dnsutils_9.9.6-6_557a981985944927c5a819589e2bb51f.wapt
May 19, 2020 - 8:52 PM
I'm testing with an unreleased nightly build ;) but which will be published soon
The renaming is indeed intentional; you can name your package as you wish.
To force a renaming, use the -r option:
wapt-scanpackages -r -f /var/www/wapt/
