2020-05-15 21:58:18,490 [waptserver ] INFO Using config file c:\wapt\conf\waptserver.ini
2020-05-15 21:58:19,315 [waptws ] INFO Server initialized for eventlet.
2020-05-15 21:58:19,316 [waptserver ] INFO Load database configuration
2020-05-15 21:58:19,316 [waptdb ] INFO Initializing a DB connection pool for db host None:5432 db_name:wapt. Size:90
2020-05-15 21:58:19,318 [waptdb ] INFO Connecting to waptdb explicitely. Count: 0
2020-05-15 21:58:19,318 [peewee.pool ] DEBUG No connection available in pool.
2020-05-15 21:58:19,374 [peewee.pool ] DEBUG Created new connection 44181024.
2020-05-15 21:58:19,434 [peewee ] DEBUG ('SELECT "t1"."key", "t1"."value" FROM "serverattribs" AS "t1" WHERE ("t1"."key" = %s) LIMIT %s OFFSET %s', [u'db_version', 1, 0])
2020-05-15 21:58:19,460 [waptdb ] INFO Current DB: {'host': None, 'password': None, 'port': 5432, 'user': 'wapt'} version: 1.8.1.0
2020-05-15 21:58:19,460 [peewee ] DEBUG ('SELECT "t1"."key", "t1"."value" FROM "serverattribs" AS "t1" WHERE ("t1"."key" = %s) LIMIT %s OFFSET %s', [u'db_version', 1, 0])
2020-05-15 21:58:19,463 [peewee ] DEBUG ('SELECT "t1"."key", "t1"."value" FROM "serverattribs" AS "t1" WHERE ("t1"."key" = %s) LIMIT %s OFFSET %s', [u'db_version', 1, 0])
2020-05-15 21:58:19,466 [peewee ] DEBUG ('SELECT "t1"."key", "t1"."value" FROM "serverattribs" AS "t1" WHERE ("t1"."key" = %s) LIMIT %s OFFSET %s', [u'db_version', 1, 0])
2020-05-15 21:58:19,469 [peewee ] DEBUG ('SELECT "t1"."key", "t1"."value" FROM "serverattribas" AS "t1" WHERE ("t1"."key" = %s) LIMIT %s OFFSET %s', [u'db_version', 1, 0])
2020-05-15 21:58:19,470 [peewee ] DEBUG ('SELECT "t1"."key", "t1"."value" FROM "serverattribs" AS "t1" WHERE ("t1"."key" = %s) LIMIT %s OFFSET %s', [u'db_version', 1, 0])
2020-05-15 21:58:19,473 [peewee ] DEBUG ('SELECT "t1"."key", "t1"."value" FROM "serverattribs" AS "t1" WHERE ("t1"."key" = %s) LIMIT %s OFFSET %s', [u'db_version', 1, 0])
2020-05-15 21:58:19,476 [peewee ] DEBUG ('SELECT "t1"."key", "t1"."value" FROM "serverattribs" AS "t1" WHERE ("t1"."key" = %s) LIMIT %s OFFSET %s', [u'db_version', 1, 0])
2020-05-15 21:58:19,477 [peewee ] DEBUG ('SELECT "t1"."key", "t1"."value" FROM "serverattribs" AS "t1" WHERE ("t1"."key" = %s) LIMIT %s OFFSET %s', [u'db_version', 1, 0])
2020-05-15 21:58:19,480 [peewee ] DEBUG ('SELECT "t1"."key", "t1"."value" FROM "serverattribs" AS "t1" WHERE ("t1"."key" = %s) LIMIT %s OFFSET %s', [u'db_version', 1, 0])
2020-05-15 21:58:19,483 [peewee ] DEBUG ('SELECT "t1"."key", "t1"."value" FROM "serverattribs" AS "t1" WHERE ("t1"."key" = %s) LIMIT %s OFFSET %s', [u'db_version', 1, 0])
2020-05-15 21:58:19,486 [peewee ] DEBUG ('SELECT "t1"."key", "t1"."value" FROM "serverattribs" AS "t1" WHERE ("t1"."key" = %s) LIMIT %s OFFSET %s', [u'db_version', 1, 0])
2020-05-15 21:58:19,487 [peewee ] DEBUG ('SELECT "t1"."key", "t1"."value" FROM "serverattribs" AS "t1" WHERE ("t1"."key" = %s) LIMIT %s OFFSET %s', [u'db_version', 1, 0])
2020-05-15 21:58:19,490 [peewee ] DEBUG ('SELECT "t1"."key", "t1"."value" FROM "serverattribs" AS "t1" WHERE ("t1"."key" = %s) LIMIT %s OFFSET %s', [u'db_version', 1, 0])
2020-05-15 21:58:19,493 [peewee ] DEBUG ('SELECT "t1"."key", "t1"."value" FROM "serverattribs" AS "t1" WHERE ("t1"."key" = %s) LIMIT %s OFFSET %s', [u'db_version', 1, 0])
2020-05-15 21:58:19,494 [peewee ] DEBUG ('SELECT "t1"."key", "t1"."value" FROM "serverattribs" AS "t1" WHERE ("t1"."key" = %s) LIMIT %s OFFSET %s', [u'db_version', 1, 0])
2020-05-15 21:58:19,496 [peewee ] DEBUG ('SELECT "t1"."key", "t1"."value" FROM "serverattribs" AS "t1" WHERE ("t1"."key" = %s) LIMIT %s OFFSET %s', [u'db_version', 1, 0])
2020-05-15 21:58:19,499 [peewee ] DEBUG ('SELECT "t1"."key", "t1"."value" FROM "serverattribs" AS "t1" WHERE ("t1"."key" = %s) LIMIT %s OFFSET %s', [u'db_version', 1, 0])
2020-05-15 21:58:19,500 [peewee ] DEBUG ('SELECT "t1"."key", "t1"."value" FROM "serverattribs" AS "t1" WHERE ("t1"."key" = %s) LIMIT %s OFFSET %s', [u'db_version', 1, 0])
2020-05-15 21:58:19,503 [peewee ] DEBUG ('SELECT "t1"."key", "t1"."value" FROM "serverattribs" AS "t1" WHERE ("t1"."key" = %s) LIMIT %s OFFSET %s', [u'db_version', 1, 0])
2020-05-15 21:58:19,505 [peewee ] DEBUG ('SELECT "t1"."key", "t1"."value" FROM "serverattribs" AS "t1" WHERE ("t1"."key" = %s) LIMIT %s OFFSET %s', [u'db_version', 1, 0])
2020-05-15 21:58:19,506 [peewee ] DEBUG ('SELECT "t1"."key", "t1"."value" FROM "serverattribs" AS "t1" WHERE ("t1"."key" = %s) LIMIT %s OFFSET %s', [u'db_version', 1, 0])
2020-05-15 21:58:19,509 [peewee ] DEBUG ('SELECT "t1"."key", "t1"."value" FROM "serverattribs" AS "t1" WHERE ("t1"."key" = %s) LIMIT %s OFFSET %s', [u'db_version', 1, 0])
2020-05-15 21:58:19,510 [peewee ] DEBUG ('SELECT "t1"."key", "t1"."value" FROM "serverattribs" AS "t1" WHERE ("t1"."key" = %s) LIMIT %s OFFSET %s', [u'db_version', 1, 0])
2020-05-15 21:58:19,513 [peewee ] DEBUG ('SELECT "t1"."key", "t1"."value" FROM "serverattribs" AS "t1" WHERE ("t1"."key" = %s) LIMIT %s OFFSET %s', [u'db_version', 1, 0])
2020-05-15 21:58:19,515 [peewee ] DEBUG ('SELECT "t1"."key", "t1"."value" FROM "serverattribs" AS "t1" WHERE ("t1"."key" = %s) LIMIT %s OFFSET %s', [u'db_version', 1, 0])
2020-05-15 21:58:19,517 [peewee ] DEBUG ('SELECT "t1"."key", "t1"."value" FROM "serverattribs" AS "t1" WHERE ("t1"."key" = %s) LIMIT %s OFFSET %s', [u'db_version', 1, 0])
2020-05-15 21:58:19,519 [peewee ] DEBUG ('SELECT "t1"."key", "t1"."value" FROM "serverattribs" AS "t1" WHERE ("t1"."key" = %s) LIMIT %s OFFSET %s', [u'db_version', 1, 0])
2020-05-15 21:58:19,522 [peewee ] DEBUG ('SELECT "t1"."key", "t1"."value" FROM "serverattribs" AS "t1" WHERE ("t1"."key" = %s) LIMIT %s OFFSET %s', [u'db_version', 1, 0])
2020-05-15 21:58:19,523 [peewee ] DEBUG ('SELECT "t1"."key", "t1"."value" FROM "serverattribs" AS "t1" WHERE ("t1"."key" = %s) LIMIT %s OFFSET %s', [u'db_version', 1, 0])
2020-05-15 21:58:19,526 [peewee ] DEBUG ('SELECT "t1"."key", "t1"."value" FROM "serverattribs" AS "t1" WHERE ("t1"."key" = %s) LIMIT %s OFFSET %s', [u'db_version', 1, 0])
2020-05-15 21:58:19,529 [peewee ] DEBUG ('SELECT "t1"."id", "t1"."created_on", "t1"."created_by", "t1"."updated_on", "t1"."updated_by", "t1"."name", "t1"."auth_method", "t1"."description", "t1"."user_certificate", "t1"."user_fingerprint_sha1", "t1"."user_fingerprint_sha256" FROM "waptusers" AS "t1" WHERE ("t1"."name" = %s) LIMIT %s OFFSET %s', [u'admin', 1, 0])
2020-05-15 21:58:19,561 [peewee ] DEBUG ('UPDATE "waptusers" SET "created_on" = %s, "created_by" = %s, "updated_on" = %s, "updated_by" = %s, "name" = %s, "auth_method" = %s, "description" = %s, "user_certificate" = %s, "user_fingerprint_sha1" = %s, "user_fingerprint_sha256" = %s WHERE ("waptusers"."id" = %s)', [datetime.datetime(2020, 3, 11, 10, 15, 54, 253000), None, datetime.datetime(2020, 5, 15, 19, 58, 19, 560000), None, u'admin', None, None, None, None, None, 1])
2020-05-15 21:58:19,575 [waptdb ] DEBUG Disconnecting from waptdb explicitely. Count: 1
2020-05-15 21:58:19,575 [peewee.pool ] DEBUG Returning 44181024 to pool.
2020-05-15 21:58:19,575 [waptserver ] INFO Waptserver starting...
2020-05-15 21:58:19,575 [waptdb ] INFO Connecting to waptdb explicitely. Count: 0
2020-05-15 21:58:19,576 [waptserver ] INFO Reset connections SID for former hosts on this server
2020-05-15 21:58:19,579 [peewee ] DEBUG ('UPDATE "hosts" SET "reachable" = %s, "listening_protocol" = %s, "listening_address" = %s WHERE (("hosts"."listening_protocol" = %s) AND ("hosts"."server_uuid" = %s))', [u'DISCONNECTED', None, None, u'websockets', u'00000000-0000-0000-18d8-730300000000'])
2020-05-15 21:58:19,743 [waptdb ] DEBUG Disconnecting from waptdb explicitely. Count: 1
2020-05-15 21:58:19,743 [peewee.pool ] DEBUG Returning 44181024 to pool.
2020-05-15 21:58:19,743 [waptserver ] INFO Starting socketio/wsgi server on port 8080
2020-05-15 21:58:19,744 [waptserver ] INFO (3332) wsgi starting up on http://127.0.0.1:8080
2020-05-15 21:58:26,394 [waptserver ] DEBUG (3332) accepted ('127.0.0.1', 54665)
2020-05-15 21:58:26,476 [waptserver ] DEBUG wapt admin passwd verification failed
2020-05-15 21:58:26,480 [waptserver ] INFO 10.0.0.23,127.0.0.1 - - [15/May/2020 21:58:26] "POST /api/v3/login HTTP/1.0" 401 324 0.086000
2020-05-15 21:58:29,493 [waptserver ] DEBUG (3332) accepted ('127.0.0.1', 54667)
2020-05-15 21:58:29,575 [waptserver ] DEBUG wapt admin passwd verification failed
2020-05-15 21:58:29,578 [waptserver ] INFO 10.0.0.23,127.0.0.1 - - [15/May/2020 21:58:29] "POST /api/v3/login HTTP/1.0" 401 324 0.085000
2020-05-15 21:58:32,461 [waptserver ] DEBUG (3332) accepted ('127.0.0.1', 54670)
2020-05-15 21:58:32,542 [waptserver ] DEBUG wapt admin passwd verification failed
2020-05-15 21:58:32,546 [waptserver ] INFO 10.0.0.23,127.0.0.1 - - [15/May/2020 21:58:32] "POST /api/v3/login HTTP/1.0" 401 324 0.084000
2020-05-15 21:58:54,526 [waptserver ] DEBUG (3332) accepted ('127.0.0.1', 54673)
2020-05-15 21:58:54,536 [waptserver ] DEBUG (3332) accepted ('127.0.0.1', 54674)
2020-05-15 21:58:54,538 [waptws ] INFO a2dd6ecfdb3f4b98b3eaf83a11b0a218: Sending packet OPEN data {'pingInterval': 25000, 'pingTimeout': 60000, 'upgrades': ['websocket'], 'sid': 'a2dd6ecfdb3f4b98b3eaf83a11b0a218'}
2020-05-15 21:58:54,539 [waptws ] INFO Unauthenticated Socket.IO connection from wapt client sid a2dd6ecfdb3f4b98b3eaf83a11b0a218 (uuid: 07FD1C18-35A8-4E04-8DE7-1D45AD58D929)
2020-05-15 21:58:54,539 [waptdb ] INFO Connecting to waptdb explicitely. Count: 0
2020-05-15 21:58:54,540 [peewee ] DEBUG ('UPDATE "hosts" SET "server_uuid" = %s, "listening_protocol" = %s, "listening_address" = %s, "listening_timestamp" = %s, "last_seen_on" = %s WHERE ("hosts"."uuid" = %s)', [u'00000000-0000-0000-18d8-730300000000', u'websockets', u'a2dd6ecfdb3f4b98b3eaf83a11b0a218', u'2020-05-15T21:58:54.540000', u'2020-05-15T21:58:54.540000', u'07FD1C18-35A8-4E04-8DE7-1D45AD58D929'])
2020-05-15 21:58:54,542 [waptws ] INFO 44e558a037934e14addd70e413a9e385: Sending packet OPEN data {'pingInterval': 25000, 'pingTimeout': 60000, 'upgrades': ['websocket'], 'sid': '44e558a037934e14addd70e413a9e385'}
2020-05-15 21:58:54,542 [waptws ] INFO Unauthenticated Socket.IO connection from wapt client sid 44e558a037934e14addd70e413a9e385 (uuid: 1538058D-B393-D013-D0C3-5FD23A93AFBB)
2020-05-15 21:58:54,543 [waptdb ] INFO Connecting to waptdb explicitely. Count: 1
2020-05-15 21:58:54,543 [peewee.pool ] DEBUG No connection available in pool.
2020-05-15 21:58:54,569 [waptdb ] DEBUG Disconnecting from waptdb explicitely. Count: 1
2020-05-15 21:58:54,575 [peewee.pool ] DEBUG Created new connection 44182240.
2020-05-15 21:58:54,576 [peewee ] DEBUG ('UPDATE "hosts" SET "server_uuid" = %s, "listening_protocol" = %s, "listening_address" = %s, "listening_timestamp" = %s, "last_seen_on" = %s WHERE ("hosts"."uuid" = %s)', [u'00000000-0000-0000-18d8-730300000000', u'websockets', u'44e558a037934e14addd70e413a9e385', u'2020-05-15T21:58:54.576000', u'2020-05-15T21:58:54.576000', u'1538058D-B393-D013-D0C3-5FD23A93AFBB'])
2020-05-15 21:58:54,578 [peewee.pool ] DEBUG Returning 44181024 to pool.
2020-05-15 21:58:54,578 [waptws ] INFO a2dd6ecfdb3f4b98b3eaf83a11b0a218: Sending packet MESSAGE data 0
2020-05-15 21:58:54,578 [waptserver ] INFO 127.0.0.1 - - [15/May/2020 21:58:54] "GET /socket.io/?token=eyJhbGciOiJIUzUxMiIsImV4cCI6MTU4OTYxNTQ1MiwiaWF0IjoxNTg5NTcyMjUyfQ.eyJ1dWlkIjoiMDdGRDFDMTgtMzVBOC00RTA0LThERTctMUQ0NUFENThEOTI5Iiwic2VydmVyX3V1aWQiOiIwMDAwMDAwMC0wMDAwLTAwMDAtMThkOC03MzAzMDAwMDAwMDAifQ.d3YTkczLP_0TkubO4qRkK3DaHpufzs837sHg7IEd-asqH8h_7S7nhoXUI4JYku3CvfTuvlmxL9ca-JmTS3M-Ww&uuid=07FD1C18-35A8-4E04-8DE7-1D45AD58D929&EIO=3&transport=polling&t=1589572734429-0 HTTP/1.1" 200 325 0.043000
2020-05-15 21:58:54,582 [waptserver ] DEBUG (3332) accepted ('127.0.0.1', 54676)
2020-05-15 21:58:54,592 [waptws ] INFO 912d5137ee1b4502a0f997fa741a9ba5: Sending packet OPEN data {'pingInterval': 25000, 'pingTimeout': 60000, 'upgrades': ['websocket'], 'sid': '912d5137ee1b4502a0f997fa741a9ba5'}
2020-05-15 21:58:54,594 [waptws ] INFO Unauthenticated Socket.IO connection from wapt client sid 912d5137ee1b4502a0f997fa741a9ba5 (uuid: 4C4C4544-0042-4710-8033-CAC04F303332)
2020-05-15 21:58:54,594 [waptdb ] INFO Connecting to waptdb explicitely. Count: 1
2020-05-15 21:58:54,595 [peewee ] DEBUG ('UPDATE "hosts" SET "server_uuid" = %s, "listening_protocol" = %s, "listening_address" = %s, "listening_timestamp" = %s, "last_seen_on" = %s WHERE ("hosts"."uuid" = %s)', [u'00000000-0000-0000-18d8-730300000000', u'websockets', u'912d5137ee1b4502a0f997fa741a9ba5', u'2020-05-15T21:58:54.595000', u'2020-05-15T21:58:54.595000', u'4C4C4544-0042-4710-8033-CAC04F303332'])
2020-05-15 21:58:54,604 [waptdb ] DEBUG Disconnecting from waptdb explicitely. Count: 2
2020-05-15 21:58:54,605 [peewee.pool ] DEBUG Returning 44182240 to pool.
2020-05-15 21:58:54,605 [waptws ] INFO 44e558a037934e14addd70e413a9e385: Sending packet MESSAGE data 0
2020-05-15 21:58:54,605 [waptserver ] INFO 127.0.0.1 - - [15/May/2020 21:58:54] "GET /socket.io/?token=eyJhbGciOiJIUzUxMiIsImV4cCI6MTU4OTYxNTQ1MiwiaWF0IjoxNTg5NTcyMjUyfQ.eyJ1dWlkIjoiMTUzODA1OEQtQjM5My1EMDEzLUQwQzMtNUZEMjNBOTNBRkJCIiwic2VydmVyX3V1aWQiOiIwMDAwMDAwMC0wMDAwLTAwMDAtMThkOC03MzAzMDAwMDAwMDAifQ.l9cJxDuweJl0iw3hRmou7DFszQnpTYWZ-AuIWNNkIgngbw_K5cF8aCiCGxtAp99zXYBbW1aoXRQWF7m3VtYLTg&uuid=1538058D-B393-D013-D0C3-5FD23A93AFBB&EIO=3&transport=polling&t=1589572734422-0 HTTP/1.1" 200 325 0.064000
2020-05-15 21:58:54,619 [waptdb ] DEBUG Disconnecting from waptdb explicitely. Count: 1
2020-05-15 21:58:54,619 [peewee.pool ] DEBUG Returning 44181024 to pool.
2020-05-15 21:58:54,621 [waptws ] INFO 912d5137ee1b4502a0f997fa741a9ba5: Sending packet MESSAGE data 0
2020-05-15 21:58:54,621 [waptserver ] INFO 127.0.0.1 - - [15/May/2020 21:58:54] "GET /socket.io/?token=eyJhbGciOiJIUzUxMiIsImV4cCI6MTU4OTYxNTQ1MiwiaWF0IjoxNTg5NTcyMjUyfQ.eyJ1dWlkIjoiNEM0QzQ1NDQtMDA0Mi00NzEwLTgwMzMtQ0FDMDRGMzAzMzMyIiwic2VydmVyX3V1aWQiOiIwMDAwMDAwMC0wMDAwLTAwMDAtMThkOC03MzAzMDAwMDAwMDAifQ.8DESXqSU1eO3E-A83jol1xCJbYtxhvu16pQ3W1kUTQMRkP1zuqPcGx7D-Ng9QJkkfEb-6YyCD-TD0EDAFQq4zA&uuid=4C4C4544-0042-4710-8033-CAC04F303332&EIO=3&transport=polling&t=1589572734381-0 HTTP/1.1" 200 325 0.029000
2020-05-15 21:58:54,641 [waptserver ] DEBUG (3332) accepted ('127.0.0.1', 54677)
2020-05-15 21:58:54,641 [waptserver ] DEBUG (3332) accepted ('127.0.0.1', 54678)
2020-05-15 21:58:54,642 [waptws ] INFO 966cb7ee35144e09b6c414611d8c468b: Sending packet OPEN data {'pingInterval': 25000, 'pingTimeout': 60000, 'upgrades': ['websocket'], 'sid': '966cb7ee35144e09b6c414611d8c468b'}
2020-05-15 21:58:54,644 [waptws ] INFO Unauthenticated Socket.IO connection from wapt client sid 966cb7ee35144e09b6c414611d8c468b (uuid: 3ECE3423-7C37-E611-8160-4CCC6A341464)
2020-05-15 21:58:54,644 [waptdb ] INFO Connecting to waptdb explicitely. Count: 0
2020-05-15 21:58:54,645 [peewee ] DEBUG ('UPDATE "hosts" SET "server_uuid" = %s, "listening_protocol" = %s, "listening_address" = %s, "listening_timestamp" = %s, "last_seen_on" = %s WHERE ("hosts"."uuid" = %s)', [u'00000000-0000-0000-18d8-730300000000', u'websockets', u'966cb7ee35144e09b6c414611d8c468b', u'2020-05-15T21:58:54.645000', u'2020-05-15T21:58:54.645000', u'3ECE3423-7C37-E611-8160-4CCC6A341464'])
2020-05-15 21:58:54,647 [waptws ] INFO 746c197c3a9d4f51a0cb3a6f2decbce6: Sending packet OPEN data {'pingInterval': 25000, 'pingTimeout': 60000, 'upgrades': ['websocket'], 'sid': '746c197c3a9d4f51a0cb3a6f2decbce6'}
2020-05-15 21:58:54,648 [waptws ] INFO Unauthenticated Socket.IO connection from wapt client sid 746c197c3a9d4f51a0cb3a6f2decbce6 (uuid: 4C4C4544-004C-4A10-8030-C6C04F594B32)
2020-05-15 21:58:54,648 [waptdb ] INFO Connecting to waptdb explicitely. Count: 1
2020-05-15 21:58:54,650 [peewee ] DEBUG ('UPDATE "hosts" SET "server_uuid" = %s, "listening_protocol" = %s, "listening_address" = %s, "listening_timestamp" = %s, "last_seen_on" = %s WHERE ("hosts"."uuid" = %s)', [u'00000000-0000-0000-18d8-730300000000', u'websockets', u'746c197c3a9d4f51a0cb3a6f2decbce6', u'2020-05-15T21:58:54.649000', u'2020-05-15T21:58:54.649000', u'4C4C4544-004C-4A10-8030-C6C04F594B32'])
2020-05-15 21:58:54,651 [waptserver ] DEBUG (3332) accepted ('127.0.0.1', 54679)
2020-05-15 21:58:54,661 [waptws ] INFO a2dd6ecfdb3f4b98b3eaf83a11b0a218: Received request to upgrade to websocket
2020-05-15 21:58:54,677 [waptdb ] DEBUG Disconnecting from waptdb explicitely. Count: 2
2020-05-15 21:58:54,677 [peewee.pool ] DEBUG Returning 44181024 to pool.
2020-05-15 21:58:54,677 [waptws ] INFO 966cb7ee35144e09b6c414611d8c468b: Sending packet MESSAGE data 0
2020-05-15 21:58:54,677 [waptserver ] INFO 127.0.0.1 - - [15/May/2020 21:58:54] "GET /socket.io/?token=eyJhbGciOiJIUzUxMiIsImV4cCI6MTU4OTYxNTQ1MiwiaWF0IjoxNTg5NTcyMjUyfQ.eyJ1dWlkIjoiM0VDRTM0MjMtN0MzNy1FNjExLTgxNjAtNENDQzZBMzQxNDY0Iiwic2VydmVyX3V1aWQiOiIwMDAwMDAwMC0wMDAwLTAwMDAtMThkOC03MzAzMDAwMDAwMDAifQ.3tDitg6yRP-jFDsaaP71rykBu8J0pnykz24kMLT8M5Bsh4HVajV30s-86HF6MejvAtVNz9RPCM384xMkZ59l8A&uuid=3ECE3423-7C37-E611-8160-4CCC6A341464&EIO=3&transport=polling&t=1589572734593-0 HTTP/1.1" 200 325 0.036000
2020-05-15 21:58:54,686 [waptdb ] DEBUG Disconnecting from waptdb explicitely. Count: 1
2020-05-15 21:58:54,686 [peewee.pool ] DEBUG Returning 44182240 to pool.
2020-05-15 21:58:54,686 [waptws ] INFO 746c197c3a9d4f51a0cb3a6f2decbce6: Sending packet MESSAGE data 0
2020-05-15 21:58:54,687 [waptserver ] INFO 127.0.0.1 - - [15/May/2020 21:58:54] "GET /socket.io/?token=eyJhbGciOiJIUzUxMiIsImV4cCI6MTU4OTYxNTM5MSwiaWF0IjoxNTg5NTcyMTkxfQ.eyJ1dWlkIjoiNEM0QzQ1NDQtMDA0Qy00QTEwLTgwMzAtQzZDMDRGNTk0QjMyIiwic2VydmVyX3V1aWQiOiIwMDAwMDAwMC0wMDAwLTAwMDAtMThkOC03MzAzMDAwMDAwMDAifQ.Y8CkuXcDuIskqOMMbyIkEM_rvPpHfjMFpCiXBamU1tgwPSFKu4eL3G0hukfzG-26bsytqlyCY5zFGVOtEg0KIA&uuid=4C4C4544-004C-4A10-8030-C6C04F594B32&EIO=3&transport=polling&t=1589572734586-0 HTTP/1.1" 200 325 0.040000
2020-05-15 21:58:54,785 [waptserver ] DEBUG (3332) accepted ('127.0.0.1', 54680)
2020-05-15 21:58:54,832 [waptserver ] DEBUG (3332) accepted ('127.0.0.1', 54681)
2020-05-15 21:58:54,834 [waptws ] INFO 44e558a037934e14addd70e413a9e385: Received request to upgrade to websocket
2020-05-15 21:58:54,835 [waptws ] INFO 912d5137ee1b4502a0f997fa741a9ba5: Received request to upgrade to websocket
2020-05-15 21:58:54,835 [waptws ] INFO a2dd6ecfdb3f4b98b3eaf83a11b0a218: Upgrade to websocket successful
2020-05-15 21:58:54,835 [waptserver ] DEBUG (3332) accepted ('127.0.0.1', 54682)
2020-05-15 21:58:54,836 [waptws ] INFO 966cb7ee35144e09b6c414611d8c468b: Received request to upgrade to websocket
2020-05-15 21:58:54,839 [waptserver ] DEBUG (3332) accepted ('127.0.0.1', 54683)
2020-05-15 21:58:54,851 [waptws ] INFO 746c197c3a9d4f51a0cb3a6f2decbce6: Received request to upgrade to websocket
2020-05-15 21:58:54,855 [waptws ] INFO 44e558a037934e14addd70e413a9e385: Upgrade to websocket successful
2020-05-15 21:58:54,857 [waptws ] INFO 966cb7ee35144e09b6c414611d8c468b: Upgrade to websocket successful
2020-05-15 21:58:54,858 [waptws ] INFO 746c197c3a9d4f51a0cb3a6f2decbce6: Upgrade to websocket successful
2020-05-15 21:58:54,858 [waptws ] INFO 746c197c3a9d4f51a0cb3a6f2decbce6: Received packet PING data None
2020-05-15 21:58:54,858 [waptws ] INFO 746c197c3a9d4f51a0cb3a6f2decbce6: Sending packet PONG data None
2020-05-15 21:58:54,859 [waptws ] INFO 912d5137ee1b4502a0f997fa741a9ba5: Upgrade to websocket successful
2020-05-15 21:58:55,316 [waptserver ] DEBUG (3332) accepted ('127.0.0.1', 54684)
2020-05-15 21:58:55,319 [waptws ] INFO 74a1bc2a3f2c4f178299032f3360b5d7: Sending packet OPEN data {'pingInterval': 25000, 'pingTimeout': 60000, 'upgrades': ['websocket'], 'sid': '74a1bc2a3f2c4f178299032f3360b5d7'}
2020-05-15 21:58:55,319 [waptws ] INFO Unauthenticated Socket.IO connection from wapt client sid 74a1bc2a3f2c4f178299032f3360b5d7 (uuid: 5B047FC3-076E-4871-86BB-992CB958F6CC)
2020-05-15 21:58:55,321 [waptdb ] INFO Connecting to waptdb explicitely. Count: 0
2020-05-15 21:58:55,322 [peewee ] DEBUG ('UPDATE "hosts" SET "server_uuid" = %s, "listening_protocol" = %s, "listening_address" = %s, "listening_timestamp" = %s, "last_seen_on" = %s WHERE ("hosts"."uuid" = %s)', [u'00000000-0000-0000-18d8-730300000000', u'websockets', u'74a1bc2a3f2c4f178299032f3360b5d7', u'2020-05-15T21:58:55.321000', u'2020-05-15T21:58:55.321000', u'5B047FC3-076E-4871-86BB-992CB958F6CC'])
2020-05-15 21:58:55,338 [waptdb ] DEBUG Disconnecting from waptdb explicitely. Count: 1
2020-05-15 21:58:55,338 [peewee.pool ] DEBUG Returning 44181024 to pool.
2020-05-15 21:58:55,339 [waptws ] INFO 74a1bc2a3f2c4f178299032f3360b5d7: Sending packet MESSAGE data 0
2020-05-15 21:58:55,339 [waptserver ] INFO 127.0.0.1 - - [15/May/2020 21:58:55] "GET /socket.io/?uuid=5B047FC3-076E-4871-86BB-992CB958F6CC&EIO=3&transport=polling&t=1589572735313-0 HTTP/1.1" 200 325 0.021000
2020-05-15 21:58:56,299 [waptserver ] DEBUG (3332) accepted ('127.0.0.1', 54687)
2020-05-15 21:58:56,388 [waptserver ] DEBUG wapt admin passwd verification failed
2020-05-15 21:58:56,392 [waptserver ] INFO 10.0.0.23,127.0.0.1 - - [15/May/2020 21:58:56] "POST /api/v3/login HTTP/1.0" 401 324 0.090000
2020-05-15 21:58:56,395 [waptserver ] DEBUG (3332) accepted ('127.0.0.1', 54689)
2020-05-15 21:58:56,397 [waptws ] INFO 74a1bc2a3f2c4f178299032f3360b5d7: Received request to upgrade to websocket
2020-05-15 21:58:56,403 [waptws ] INFO 74a1bc2a3f2c4f178299032f3360b5d7: Upgrade to websocket successful
2020-05-15 21:59:08,849 [waptws ] INFO 966cb7ee35144e09b6c414611d8c468b: Received packet PING data None
2020-05-15 21:59:08,849 [waptws ] INFO 966cb7ee35144e09b6c414611d8c468b: Sending packet PONG data None
2020-05-15 21:59:08,911 [waptws ] INFO 966cb7ee35144e09b6c414611d8c468b: Received packet MESSAGE data 2["wapt_pong"]
2020-05-15 21:59:08,911 [waptws ] INFO received event "wapt_pong" from 966cb7ee35144e09b6c414611d8c468b [/]
2020-05-15 21:59:08,911 [waptws ] DEBUG Socket.IO pong from wapt client sid 966cb7ee35144e09b6c414611d8c468b (uuid: 3ECE3423-7C37-E611-8160-4CCC6A341464)
2020-05-15 21:59:08,911 [waptdb ] INFO Connecting to waptdb explicitely. Count: 0
2020-05-15 21:59:08,911 [peewee ] DEBUG ('UPDATE "hosts" SET "reachable" = %s, "server_uuid" = %s, "listening_protocol" = %s, "listening_address" = %s, "listening_timestamp" = %s WHERE ("hosts"."uuid" = %s)', [u'OK', u'00000000-0000-0000-18d8-730300000000', u'websockets', u'966cb7ee35144e09b6c414611d8c468b', u'2020-05-15T21:59:08.912000', u'3ECE3423-7C37-E611-8160-4CCC6A341464'])
2020-05-15 21:59:08,927 [waptdb ] DEBUG Disconnecting from waptdb explicitely. Count: 1
2020-05-15 21:59:08,944 [peewee.pool ] DEBUG Returning 44181024 to pool.
2020-05-15 21:59:08,944 [waptws ] INFO 966cb7ee35144e09b6c414611d8c468b: Received packet PING data None
2020-05-15 21:59:08,944 [waptws ] INFO 966cb7ee35144e09b6c414611d8c468b: Sending packet PONG data None
Um, either my password is wrong or it doesn't recognize it... I'm really skeptical.
