Installing Samba AD
Come here to talk about your experience with Samba4, your opinion and your wishes.
Dohakor
Registration: May 9, 2020 - 2:59 p.m.
May 15, 2020 - 4:24 PM
So generally for my tests I always prefer to have the same type of installation:
- Raspbian: lite version with only SSH enabled
- Debian: "small installation image" version with the minimum ("SSH" and "usual system utilities")
I will add the lines to the file and I will keep you informed :)
. Thank you.
Dohakor
May 15, 2020 - 4:33 PM
I tried and still nothing:
root@srvads:~# kinit administrator
kinit: Cannot contact any KDC for realm 'DOHAKOR.LAN' while getting initial credentials
root@srvads:~# klist
klist: No credentials cache found (filename: /tmp/krb5cc_0)
And after adding your modification, I do have the following part:
search dohakor.lan
nameserver 127.0.0.1
Which is no longer deleted from the file /etc/resolv.conf
Dohakor
May 15, 2020 - 5:36 PM
I finally managed to launch the command kinit Administrator And klist !!!!!!
I looked at this post ===> https://serverfault.com/questions/16676 ... getting-in
So I modified my file /etc/krb5.conf to move from:
[libdefaults]
        default_realm = DOHAKOR.LAN
        dns_lookup_realm = false
        dns_lookup_kdc = true
has
[libdefaults]
[realms]
    DOHAKOR.LAN = {
        kdc = srvads.dohakor.lan
        admin_server = srvads.dohakor.lan
And now it works!
However, it's strange because in your document it clearly says Edit the /etc/krb5.conf file and replace its entire contents with the following 4 lines, specifying your organization's Active Directory domain .
Another question is bothering me: when I run the klist command, I get this:
Ticket cache: FILE:/tmp/krb5cc_0
Default principal: administrator@DOHAKOR.LAN
Valid starting       Expires              Service principal
05/15/2020 16:42:06  05/16/2020 02:42:06  krbtgt/DOHAKOR.LAN@DOHAKOR.LAN
        renew until 05/16/2020 16:41:55
It's normal to have DOHAKOR.LAN@DOHAKOR.LAN???
May 15, 2020 - 6:24 PM
You likely have a DNS issue with your Samba AD. Does `samba_dnsupdate --use-samba-tool` work correctly?
Regards,
Dohakor
May 15, 2020 - 6:34 PM
I tried your command and here's the result:
root@srvads:~# samba_dnsupdate --use-samba-tool
Failed to get Kerberos credentials, falling back to samba-tool: kinit for SRVADS$@DOHAKOR.LAN failed (Cannot contact any KDC for requested realm)
ERROR(runtime): uncaught exception - (9711, 'WERR_DNS_ERROR_RECORD_ALREADY_EXISTS')
  File "/usr/lib/python3/dist-packages/samba/netcmd/__init__.py", line 185, in _run
    return self.run(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/samba/netcmd/dns.py", line 945, in run
    raise e
  File "/usr/lib/python3/dist-packages/samba/netcmd/dns.py", line 941, in run
    0, server, zone, name, add_rec_buf, None)
    raise e
    raise e
    raise e
    raise e
    raise e
    raise e
    raise e
    raise e
    raise e
    raise e
    raise e
    raise e
    raise e
    raise e
    raise e
    raise e
    raise e
    raise e
    raise e
Failed update of 20 entries
Dohakor
May 18, 2020 - 11:21
I searched this weekend and couldn't find a way to fix this DNS problem.
Furthermore, when I ran the commands in the Verifying DNS section of the Samba wiki, I got this:
root@srvads:~# host -t SRV _ldap._tcp.dohakor.lan
Host _ldap._tcp.dohakor.lan not found: 3(NXDOMAIN)
root@srvads:~# host -t SRV _ldap._tcp.srvads.dohakor.lan
Host _ldap._tcp.srvads.dohakor.lan not found: 3(NXDOMAIN)
root@srvads:~# host -t SRV _ldap._tcp.dohakor.lan.
Host _ldap._tcp.dohakor.lan. not found: 3(NXDOMAIN)
root@srvads:~# host -t SRV _kerberos._udp.dohakor.lan
Host _kerberos._udp.dohakor.lan not found: 3(NXDOMAIN)
root@srvads:~# host -t A srvads.dohakor.lan.
Host srvads.dohakor.lan. not found: 3(NXDOMAIN)
Unfortunately, I am completely lost.
Edit:
I just checked the Samba status and here's the result:
root@srvads:~# service samba-ad-dc status
● samba-ad-dc.service - Samba AD Daemon
   Loaded: loaded (/lib/systemd/system/samba-ad-dc.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Mon 2020-05-18 11:24:38 CEST; 4min 45s ago
     Docs: man:samba(8)
           man:samba(7)
           man:smb.conf(5)
  Process: 375 ExecStart=/usr/sbin/samba --foreground --no-process-group $SAMBAOPTIONS (code=exited, status=1/FAILURE)
 Main PID: 375 (code=exited, status=1/FAILURE)
May 18 11:24:37 srvads.dohakor.lan systemd[1]: samba-ad-dc.service: Main process exited, code=exited, status=1/FAILURE
May 18 11:24:37 srvads.dohakor.lan samba[397]: task[dnsupdate][397]: [2020/05/18 11:24:37.698256,  0] ../../source4/smbd/process_standard.c:84(sigterm_signal_handler)
May 18 11:24:37 srvads.dohakor.lan samba[397]: task[dnsupdate][397]:   sigterm_signal_handler: Exiting pid 397 on SIGTERM
May 18 11:24:37 srvads.dohakor.lan samba[399]: task[dns][399]: [2020/05/18 11:24:37.725713,  0] ../../source4/smbd/process_standard.c:84(sigterm_signal_handler)
May 18 11:24:37 srvads.dohakor.lan samba[399]: task[dns][399]:   sigterm_signal_handler: Exiting pid 399 on SIGTERM
May 18 11:24:38 srvads.dohakor.lan samba[389]: task[ldapsrv][389]: [2020/05/18 11:24:38.466342,  0] ../../source4/smbd/process_standard.c:84(sigterm_signal_handler)
May 18 11:24:38 srvads.dohakor.lan samba[389]: task[ldapsrv][389]:   sigterm_signal_handler: Exiting pid 389 on SIGTERM
May 18 11:24:38 srvads.dohakor.lan systemd[1]: Failed to start Samba AD Daemon.
May 18 11:24:38 srvads.dohakor.lan systemd[1]: samba-ad-dc.service: Unit entered failed state.
May 18 11:24:38 srvads.dohakor.lan systemd[1]: samba-ad-dc.service: Failed with result 'exit-code'.
EDIT 2:
I restarted the service manually:
root@srvads:~# service samba-ad-dc stop
root@srvads:~# service samba-ad-dc start
So, after that I have:
   Active: active (running) since Mon 2020-05-18 11:35:32 CEST; 5s ago
     Docs: man:samba(8)
           man:samba(7)
           man:smb.conf(5)
 Main PID: 755 (samba)
   Status: "smbd: ready to serve connections..."
    Tasks: 23 (limit: 4915)
   CGroup: /system.slice/samba-ad-dc.service
           ├─755 samba: root process
           ├─756 samba: task[s3fs_parent]
           ├─757 samba: task[dcesrv]
           ├─758 samba: task[nbtd]
           ├─759 samba: task[wrepl]
           ├─760 samba: task[ldapsrv]
           ├─761 samba: task[cldapd]
           ├─762 samba: task[kdc]
           ├─763 samba: task[dreplsrv]
           ├─764 samba: tfork waiter process
           ├─765 /usr/sbin/smbd -D --option=server role check:inhibit=yes --foreground
           ├─766 samba: task[winbindd_parent]
           ├─767 samba: task[ntp_signd]
           ├─768 samba: task[kccsrv]
           ├─769 samba: tfork waiter process
           ├─770 /usr/sbin/winbindd -D --option=server role check:inhibit=yes --foreground
           ├─771 samba: task[dnsupdate]
           ├─772 samba: task[dns]
           ├─773 samba: tfork waiter process
           ├─774 /usr/bin/python3 /usr/sbin/samba_dnsupdate
           ├─780 /usr/sbin/smbd -D --option=server role check:inhibit=yes --foreground
           ├─781 /usr/sbin/smbd -D --option=server role check:inhibit=yes --foreground
           └─782 /usr/sbin/smbd -D --option=server role check:inhibit=yes --foreground
May 18 11:35:28 srvads.dohakor.lan samba[755]: root process[755]:   Copyright Andrew Tridgell and the Samba Team 1992-2019
May 18 11:35:29 srvads.dohakor.lan samba[755]: root process[755]: [2020/05/18 11:35:29.544625,  0] ../../source4/smbd/server.c:773(binary_smbd_main)
May 18 11:35:29 srvads.dohakor.lan samba[755]: root process[755]:   binary_smbd_main: samba: using 'standard' process model
May 18 11:35:32 srvads.dohakor.lan winbindd[770]: [2020/05/18 11:35:32.467112,  0] ../../source3/winbindd/winbindd_cache.c:3166(initialize_winbindd_cache)
May 18 11:35:32 srvads.dohakor.lan winbindd[770]:   initialize_winbindd_cache: clearing cache and re-creating with version number 2
May 18 11:35:32 srvads.dohakor.lan systemd[1]: Started Samba AD Daemon.
May 18 11:35:32 srvads.dohakor.lan winbindd[770]: [2020/05/18 11:35:32.486989,  0] ../../lib/util/become_daemon.c:136(daemon_ready)
May 18 11:35:32 srvads.dohakor.lan winbindd[770]:   daemon_ready: daemon 'winbindd' finished starting up and ready to serve connections
May 18 11:35:32 srvads.dohakor.lan smbd[765]: [2020/05/18 11:35:32.569315,  0] ../../lib/util/become_daemon.c:136(daemon_ready)
May 18 11:35:32 srvads.dohakor.lan smbd[765]:   daemon_ready: daemon 'smbd' finished starting up and ready to serve connections
But I still get the error after the command samba_dnsupdate --use-samba-tool:
    raise e
May 18, 2020 - 2:09 PM
DNS field verification is in the samba tranquil it documentation.
Do you perhaps have something else listening on port 53?
netstat -tapn | grep 53
Dohakor
May 18, 2020 - 4:40 PM
Yes, indeed, with the dig command. I have no problem with this command.
This is what I get:
root@srvads:~# netstat -tapn | grep 53
tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      772/samba: task[dns
tcp        0      0 0.0.0.0:49153           0.0.0.0:*               LISTEN      757/samba: task[dce
tcp6       0      0 :::53                   :::*                    LISTEN      772/samba: task[dns
tcp6       0      0 :::49153                :::*                    LISTEN      757/samba: task[dce
May 18, 2020 - 6:02 PM
In your /etc/samba/smb.conf file, you've configured your server as the DNS forwarder... this creates a loop, and the Samba process probably doesn't like that.
Regards,
Dohakor
May 18, 2020 - 6:28 PM
Indeed, that's the configuration I had when I installed it on my Raspberry Pi.
On my Debien 9 VM, here are the different files:
/etc/samba/smb.conf:
# Global parameters
[global]
        dns forwarder = 192.168.1.1
        netbios name = SRVADS
        realm = DOHAKOR.LAN
        server role = active directory domain controller
        workgroup = DOHAKOR
[sysvol]
        path = /var/lib/samba/sysvol
        read only = No
[netlogon]
        path = /var/lib/samba/sysvol/dohakor.lan/scripts
        read only = No
/etc/krb5.conf:
[libdefaults]
[realms]
    DOHAKOR.LAN = {
/etc/hostname:
srvads.dohakor.lan
/etc/hosts:
127.0.0.1       localhost
127.0.1.1       pc-47.home      pc-47
# The following lines are desirable for IPv6 capable hosts
::1     localhost ip6-localhost ip6-loopback
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
192.168.1.150   srvads.dohakor.lan      srvads
srvads.dohakor.lan
/etc/network/interfaces:
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
source /etc/network/interfaces.d/*
# The loopback network interface
auto lo
iface lo inet loopback
# The primary network interface
auto enp0s3
iface enp0s3 inet static
  address 192.168.1.150/24
  gateway 192.168.1.1
# This is an autoconfigured IPv6 interface
iface enp0s3 inet6 auto
