Windows Update ERROR DOWNLOADING WSUSSCAN
May 28, 2020 - 3:08 PM
The order:
wapt-get list
Using a command prompt might help you find the package in question
Benoit ALBERT
Registration: May 25, 2020 - 4:04 p.m.
May 28, 2020 - 3:49 PM
Okay, very good, we're starting to see the light at the end of the tunnel. The problem comes from a TeamViewer package. However, when I edit it, I don't see the problematic field.
package version install_status install_date description
tdl-firefox 75.0-10 OK 2020-05-18T16:52 Firefox fr Web Browser
tdl-teamviewer-host-installer 12.3.-10759.0-0 OK 2020-05-19T12:25 None
In the control file, the field is set to 12.4. And in the software inventory, it's set to 12.0.251385.
Benoit ALBERT
May 28, 2020 - 3:58 PM
It's all good! After forgetting the problematic package, I thank you for your clear and efficient service!
