Socket error #10061 Connection Refused.
knpc
Registration: Nov. 20, 2015 - 4:40 p.m.
December 14, 2015 - 1:01 AM
Hi,
I just wanted to know if any of you have experienced this problem before?
I don't know where else to look.
Thanks
Mael
Registration: December 9, 2015 - 4:38 PM
December 14, 2015 - 4:24 PM
So, just a random idea, but are you able to generate a WAPT agent or a new security key?
knpc
December 14, 2015 - 9:43 PM
Hi,
thanks for your reply, but since I'm completely new to Wapt, how do I do it?
Thanks
Mael
December 15, 2015 - 4:24 PM
In the console > Tools > Create a WAPT agent
EDIT: I'm a bit absentminded at the moment, the flu is really getting to me. That's precisely why you're creating a custom installer, and that's where you're having problems.
When you installed the console, did you change the default WAPT installation directory?
knpc
December 15, 2015 - 9:35 PM
Hi,
yes indeed I changed the destination of wapt, I installed it on D: but if that causes a problem I can reinstall it on C: but I need to be able to put my downloads on D:.
Thanks
Mael
December 16, 2015 - 10:59
From what I've seen, the installation directory for generating a custom installer via the console must be the default one. I've noticed that this also prevents certificate generation via the console.
However, private and public certificates can still be generated using commands. I haven't had the chance to test whether creating a custom installer using Inno-setup causes an error.
It seems this problem stems from a lack of updates to some .py file (I think it was common.py).
knpc
December 16, 2015 - 3:18 PM
Hi,
So in the end, I completely uninstalled everything, reinstalled using the default settings, and when I click "create installer," here's the result in the image
Thank you for your help.
knpc
December 16, 2015 - 4:06 PM
If I configure it as shown below, I get 2 error messages:
knpc
December 16, 2015 - 6:53 PM
Well, I ended up starting from scratch with the default settings, and it works.
However, I'd like to have the folder that retrieves the installation packages on another drive.
What do I need to change to do that?
