[SOLVED] wapt agent installation folder
William12
Registration: June 3, 2020 - 4:57 PM
June 3, 2020 - 5:56 PM
I would like to know if it's possible to change the installation folder for the Wapt agent in silent mode?
I looked in the ISS files but couldn't find the correct setting.
Wapt version: 1.8.1.
Thank you in advance.
June 4, 2020 - 11:15
William12
June 9, 2020 - 10:17
sorry for the late reply.
Thank you for your feedback; I hadn't thought about the Innosetup parameters.
Here's the command to enter for waptdeploy, in case it's helpful to anyone:
--hash=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx --minversion=1.8.1.6756 --wait=15 --setupargs=/DIR="C:\Wapt"
June 9, 2020 - 11:10
Thanks for the feedback!
