[RESOLVED] Microsoft Office 2019 ProPlus in two languages ​​and Proofing Tools
lfkl
Registration: Apr 11, 2019 - 05:51
June 11, 2020 - 07:07
Uninstalling my package is not working.
Knowing that I started from my colleague's package in Bangkok which works but is simpler.
viewtopic.php?f=9&t=2361
The difference is that my XML requires installation in both languages ​​(fr and us) as well as the proofing tools (verification tools) (also in fr and us).
Installation was no problem.
So, I'm pretty sure that my uninstallation condition is not good or sufficient, but in all honesty, I don't see how to modify it with "softname".
Below is my PY and XML setup.
Attached are the software programs successfully installed by WAPT.
# Empty package, you have to include offline downloaded files
# You can use the following tool to help creating Configuration.xml and download necessary files :
# https://github.com/YerongAI/Office-Tool
# You should also check for the uninstall string for uninstall_args by using : wapt-get list-registry Office
softname = "Microsoft Office Professional Plus 2019 - fr-fr"
pgmsoffice = programfiles
uninstall_args = r'scenario=install scenariosubtype=ARP sourcetype=None productstoremove=ProPlus2019Volume.16_fr-fr_x-none culture=fr-fr version.16=16.0 DisplayLevel=False'
kill_list = ['winword.exe','powerpnt.exe','excel.exe','mspub.exe','msaccess.exe','infopath.exe','lync.exe','onenote.exe','outlook.exe','onenotem.exe','msosync.exe','groove.exe','OfficeClicktoRun.exe']
    print('installing %s'.format(control.asrequirement()))
    office_installed = installed_softwares(softname)
    cmd = '"setup.exe" /configure "configuration-eleves.xml"'
    if not office_installed:
        print('Installing {}'.format(softname))
        if Version(office_installed[0]['version']) < Version(control.version.split('-',1)[0]):
            print('{} already up to date or newer : {}'.format(softname,office_installed[0]['version']))
        error(' {} has been installed but the uninstall key can not be found'.format(softname))
    print('Removing {}'.format(softname))
    for soft in kill_list:
        killalltasks(soft)
    run('"%s" %s' % (makepath(pgmsoffice,'Common Files','microsoft shared','ClickToRun','OfficeClickToRun.exe'),uninstall_args),timeout=1200)
<Configuration ID="ID de ma configuration">
  <Info Description="Configuration élève" />
  <Add OfficeClientEdition="32" Channel="PerpetualVL2019" SourcePath="\\NOM.DE.MON.SERVEUR\REPERTOIRE.INSTALLATION\" AllowCdnFallback="TRUE">
    <Product ID="ProPlus2019Volume" PIDKEY="xxxxx-xxxxx-xxxxx-xxxxx-xxxxx">
      <Language ID="fr-fr" />
      <Language ID="en-us" />
      <Language ID="MatchPreviousMSI" />
      <ExcludeApp ID="Groove" />
      <ExcludeApp ID="OneDrive" />
      <ExcludeApp ID="Outlook" />
    </Product>
    <Product ID="LanguagePack">
    </Product>
    <Product ID="ProofingTools">
    </Product>
  </Add>
  <Property Name="SharedComputerLicensing" Value="0" />
  <Property Name="PinIconsToTaskbar" Value="FALSE" />
  <Property Name="SCLCacheOverride" Value="0" />
  <Property Name="AUTOACTIVATE" Value="0" />
  <Property Name="FORCEAPPSHUTDOWN" Value="TRUE" />
  <Property Name="DeviceBasedLicensing" Value="0" />
  <Updates Enabled="TRUE" UpdatePath="\\NOM.DE.MON.SERVEUR\REPERTOIRE.INSTALLATION\Updates" />
  <RemoveMSI />
  <AppSettings>
    <Setup Name="Company" Value="NOM DE L'ETABLISSEMENT" />
    <User Key="software\microsoft\office\16.0\common\toolbars" Name="screentipscheme" Value="2" Type="REG_DWORD" App="office16" Id="L_ShowScreenTips" />
    <User Key="software\microsoft\office\16.0\excel\options" Name="defaultformat" Value="51" Type="REG_DWORD" App="excel16" Id="L_SaveExcelfilesas" />
    <User Key="software\microsoft\office\16.0\powerpoint\options" Name="defaultformat" Value="27" Type="REG_DWORD" App="ppt16" Id="L_SavePowerPointfilesas" />
    <User Key="software\microsoft\office\16.0\word\options" Name="defaultformat" Value="" Type="REG_SZ" App="word16" Id="L_SaveWordfilesas" />
  </AppSettings>
  <Display Level="None" AcceptEULA="TRUE" />
  <Logging Level="Off" />
</Configuration>
Thank you in advance for your help and time.
Best regards.
Wapt version: 1.8.1
OS: Debian Stretch 9
Client OS: Windows 10 x64 v.1909
Software installed after WAPT.jpg installation
Software installed after WAPT installation.jpg (29.59 KB) Viewed 21341 times
June 11, 2020 - 6:23 PM
In my opinion, you need to modify "uninstall_args"
These may not be the right arguments for your version
lfkl
June 12, 2020 - 08:13
I contacted my colleague in Bangkok regarding the problem and we checked it together.
On its original ticket marked as resolved, the package installs and uninstalls correctly from the administration console.
However, on a physical machine, installation works but uninstallation does not.
The situation is therefore the same as in my case.
Here is the result of a "wapt-get list-registry" command with only the wapt agent installed by GPO and the Office 2019 package above.
C:\windows\system32>wapt-get list-registry
UninstallKey                           Software                                                              Version             Uninstallstring
ProPlus2019Volume - fr-fr              Microsoft Office Professional Plus 2019 - fr-fr                       16.0.10361.20002    "C:\Program Files\Common Files\Microsoft Shared\ClickToRun\OfficeClickToRun.exe" scenario=install scenariosubtype=ARP sourcetype=None productstoremove=ProPlus2019Volume.16_fr-fr_x-none culture=fr-fr version.16=16.0
{90160000-008F-0000-1000-0000000FF1CE} Office 16 Click-to-Run Licensing Component                            16.0.10361.20002    MsiExec.exe /I{90160000-008F-0000-1000-0000000FF1CE}
{90160000-00DD-0000-1000-0000000FF1CE} Office 16 Click-to-Run Extensibility Component 64-bit Registration    16.0.10361.20002    MsiExec.exe /X{90160000-00DD-0000-1000-0000000FF1CE}
WAPT_is1                               WAPTAgent Enterprise 1.8.1.6756                                       1.8.1.6756          "C:\Program Files (x86)\wapt\unins000.exe"
{90160000-008C-0000-0000-0000000FF1CE} Office 16 Click-to-Run Extensibility Component                        16.0.10361.20002    MsiExec.exe /X{90160000-008C-0000-0000-0000000FF1CE}
{90160000-008C-040C-0000-0000000FF1CE} Office 16 Click-to-Run Localization Component                         16.0.10361.20002    MsiExec.exe /X{90160000-008C-040C-0000-0000000FF1CE}
"uninstall_args" seems to be correct then...
It's very difficult to determine what might be preventing the uninstallation. I'm assuming it's not a network or machine configuration issue. Where could I possibly find logs or information, since WAPT returns an error on the console but without any further details? See below.
ID;Description;Résumé;Terminée le;Créé par
2;Uninstall of lfkl-microsoft-office2019-eleves (task #2);Retiré(s) : lfkl-microsoft-office2019-eleves
Erreurs: lfkl-microsoft-office2019-eleves;2020-06-12T13:55:35.685000;privatekey
On the physical machine, in c:\Temp, there are 5 log files specific to the uninstallation that I don't know how to interpret. The other 3 are in the following post because I am limited in characters in this reply! :oops: :
Timestamp	Process	TID	Area	Category	EventID	Level	Message	Correlation
06/12/2020 13:52:15.777	OFFICECL (0xe98)	0xe9c		Click-To-Run General Telemetry	aqkhc	Medium	InitLogging {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "0.0.0.0", "C2RClientVer": "16.0.10361.20002", "ContextData": "{\"AppVVersion\":\"5.1.141\",\"Bitness\":\"64\",\"CommandLine\":\"/service\",\"ExeVer\":\"16.0.10361.20002\",\"IntegrityLevel\":\"0x4000\",\"Locale\":\"1036\",\"ModulePath\":\"C:\\\\Program Files\\\\Common Files\\\\Microsoft Shared\\\\ClickToRun\\\\OfficeClickToRun.exe\",\"OSVersion\":\"10.0\",\"ProcessType\":\"OfficeClickToRun\",\"ProcessorArch\":\"9\",\"ProductType\":\"1\",\"SecuritySessionId\":\"0\"}"}
06/12/2020 13:52:15.777	OFFICECL (0xe98)	0xd00		Activity	bjtcw	Medium	ActivityEnded {"Name": "Office.Telemetry.LoadXmlRules", "CV": "NFyOGj7xhEaViBp9EZeCDQ.3.1", "ProcessIdentifier": "OfficeClickToRun.exe_16.0.10361.20002_X86_{1A8E5C34-F13E-4684-9588-1A7D1197820D}"}
06/12/2020 13:52:15.777	OFFICECL (0xe98)	0xe9c		Click-To-Run General Telemetry	bexde	Medium	::wWinMain {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "0.0.0.0", "C2RClientVer": "16.0.10361.20002", "ContextData": "Startup complete. {'LibletsTimeSpent':'94','LoggingTimeSpent':'31','TimeSpent':'125'}"}
06/12/2020 13:52:15.777	OFFICECL (0xe98)	0xd00		Activity	bjtcw	Medium	ActivityEnded {"Name": "Office.Telemetry.ProcessIdleQueueJob", "CV": "NFyOGj7xhEaViBp9EZeCDQ.3", "ProcessIdentifier": "OfficeClickToRun.exe_16.0.10361.20002_X86_{1A8E5C34-F13E-4684-9588-1A7D1197820D}"}
06/12/2020 13:52:15.793	OFFICECL (0xe98)	0xdd0		Click-To-Run General Telemetry	bexdf	Medium	ServiceStartupBehavior::ServiceMain {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "0.0.0.0", "C2RClientVer": "16.0.10361.20002", "ContextData": "Starting ServiceMain"}
06/12/2020 13:52:15.809	OFFICECL (0xe98)	0xdd0		Click-To-Run	a14x0	Medium	ServiceStartupBehavior::ServiceMain - Setting clean reboot atom
06/12/2020 13:52:15.809	OFFICECL (0xe98)	0xdd0		Click-To-Run General Telemetry	bexdg	Medium	ServiceStartupBehavior::ServiceMain {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "Starting pool initialization"}
06/12/2020 13:52:15.809	OFFICECL (0xe98)	0xdd0		Click-To-Run	annt7	Medium	ProcessPool::Initialize - Initializing Main Process Pool
06/12/2020 13:52:15.809	OFFICECL (0xe98)	0xdd0		Click-To-Run	a6n06	Medium	ExecutionContext::IsScenarioResumeMutexHeld - Acquired scenario resume mutex
06/12/2020 13:52:15.809	OFFICECL (0xe98)	0xdd0		Click-To-Run	annuf	Medium	SystemProcessPool::DoInitialize - Initializing System Process Pool	CBB239AC-0915-4488-885E-4837D8FBC4C6
06/12/2020 13:52:15.809	OFFICECL (0xe98)	0xdd0		Click-To-Run	anntv	Medium	ConfigurationManager::Initialize - Initializing ConfigurationManager	CBB239AC-0915-4488-885E-4837D8FBC4C6
06/12/2020 13:52:15.809	OFFICECL (0xe98)	0xdd0		Click-To-Run General Telemetry	azfeb	Medium	ConfigurationManager::Initialize {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "Initialize"}	CBB239AC-0915-4488-885E-4837D8FBC4C6
06/12/2020 13:52:15.809	OFFICECL (0xe98)	0xdd0		Click-To-Run	bduv7	Medium	ConfigurationManager::PopulateInitialConfigurationSettings {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "Populating initial configuration settings"}	CBB239AC-0915-4488-885E-4837D8FBC4C6
06/12/2020 13:52:15.809	OFFICECL (0xe98)	0xdd0		Activity	bjtct	Medium	ActivityStarted {"Name": "Office.ClickToRun.DisableVirtualizationSettingForC2RHive", "CV": "NFyOGj7xhEaViBp9EZeCDQ.4", "ProcessIdentifier": "OfficeClickToRun.exe_16.0.10361.20002_X86_{1A8E5C34-F13E-4684-9588-1A7D1197820D}"}	CBB239AC-0915-4488-885E-4837D8FBC4C6
06/12/2020 13:52:15.809	OFFICECL (0xe98)	0xdd0		Activity	bjtcw	Medium	ActivityEnded {"Name": "Office.ClickToRun.DisableVirtualizationSettingForC2RHive", "CV": "NFyOGj7xhEaViBp9EZeCDQ.4", "ProcessIdentifier": "OfficeClickToRun.exe_16.0.10361.20002_X86_{1A8E5C34-F13E-4684-9588-1A7D1197820D}"}	CBB239AC-0915-4488-885E-4837D8FBC4C6
06/12/2020 13:52:15.809	OFFICECL (0xe98)	0xdd0		Click-To-Run	annt4	Medium	Pipeline::Initialize - Initializing pipeline with PipelineServerName: "ClickToRun_Pipeline16"	CBB239AC-0915-4488-885E-4837D8FBC4C6
06/12/2020 13:52:15.855	OFFICECL (0xe98)	0xdd0		Click-To-Run General Telemetry	bexdb	Medium	Pipeline::Initialize {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "Pipeline initialized"}	CBB239AC-0915-4488-885E-4837D8FBC4C6
06/12/2020 13:52:15.855	OFFICECL (0xe98)	0xdd0		Click-To-Run	annt1	Medium	Orchestration::Initialize - Initializing Orchestration	CBB239AC-0915-4488-885E-4837D8FBC4C6
06/12/2020 13:52:16.043	OFFICECL (0xe98)	0xdd0		Click-To-Run	annto	Medium	ApiServer::Initialize - Initializing ApiServer for endpoint: C2RClientAPI_Server_System16	CBB239AC-0915-4488-885E-4837D8FBC4C6
06/12/2020 13:52:16.043	OFFICECL (0xe98)	0xdd0		Click-To-Run General Telemetry	bexdh	Medium	ServiceStartupBehavior::ServiceMain {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "Pool initialized correctly"}
06/12/2020 13:52:16.043	OFFICECL (0xe98)	0xdd0		Click-To-Run Non Task Error	a5bqr	Unexpected	O15Client::RefreshOfficeStubs {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ErrorCode": 1115, "ErrorType": "1115", "AppVErrorSource": "", "ErrorMessage": "ErrorCodeOnly (failed to open SCM database , Error:0x45b)", "ErrorDetails": "", "ContextData": "Unexpected Error."}
06/12/2020 13:52:16.058	OFFICECL (0xe98)	0x618		Click-To-Run General Telemetry	blyso	Medium	LogWatcher::ManageLogsInDirectory {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "{'NumFiles':'11','DeletesAttempted':'0','FilesDeleted':'0','FilesDeleteSizeInMB':'0'}"}
06/12/2020 13:52:16.152	OFFICECL (0xe98)	0xe9c		Click-To-Run	an6r7	Medium	ServiceStartupBehavior::ServiceControlHandler - Service is stopping. Control Code:5
06/12/2020 13:52:16.152	OFFICECL (0xe98)	0xe9c		Click-To-Run	ap3jf	Medium	ProcessPool::Shutdown - Shutting down process pool.
06/12/2020 13:52:16.152	OFFICECL (0xe98)	0xd58		Click-To-Run	aznhr	Medium	SystemProcessPool::MonitorProcessPool - Process pool is being shutdown.
06/12/2020 13:52:16.152	OFFICECL (0xe98)	0xf88		Click-To-Run	ati22	Medium	SystemProcessPool::WaitOnScenarioReset - Process pool is being shutdown.
06/12/2020 13:52:16.183	OFFICECL (0xe98)	0xe9c		Click-To-Run	as6n8	Medium	Pipeline::DeInitialize - DeInitializing Pipeline.
06/12/2020 13:52:16.183	OFFICECL (0xe98)	0xdd0		Click-To-Run	arqlg	Medium	ServiceStartupBehavior::ServiceMain - Service stop event is set.
06/12/2020 13:52:16.449	OFFICECL (0xe98)	0xe9c		Activity	bjtco	Medium	DroppedAggregatedActivity {"Name": "Office.Telemetry.WritePayloadsToDisk", "CV": "NFyOGj7xhEaViBp9EZeCDQ.5", "ProcessIdentifier": "OfficeClickToRun.exe_16.0.10361.20002_X86_{1A8E5C34-F13E-4684-9588-1A7D1197820D}"}
06/12/2020 13:52:38.105	OFFICECL (0xc10)	0xf40		Orapi	cpknf	Medium	Successfully got the registry values
06/12/2020 13:52:38.105	OFFICECL (0xc10)	0xf40		Activity	bjtct	Medium	ActivityStarted {"Name": "Office.Telemetry.LoadXmlRules", "CV": "xBKbTsBqd0Cf2mOxv8UiuQ.3.1", "ProcessIdentifier": "OfficeClickToRun.exe_16.0.10361.20002_X86_{4E9B12C4-6AC0-4077-9FDA-63B1BFC522B9}"}
06/12/2020 13:52:38.121	OFFICECL (0xc10)	0xc14		Click-To-Run General Telemetry	aqkhc	Medium	InitLogging {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "0.0.0.0", "C2RClientVer": "16.0.10361.20002", "ContextData": "{\"AppVVersion\":\"5.1.141\",\"Bitness\":\"64\",\"CommandLine\":\"/service\",\"ExeVer\":\"16.0.10361.20002\",\"IntegrityLevel\":\"0x4000\",\"Locale\":\"1036\",\"ModulePath\":\"C:\\\\Program Files\\\\Common Files\\\\Microsoft Shared\\\\ClickToRun\\\\OfficeClickToRun.exe\",\"OSVersion\":\"10.0\",\"ProcessType\":\"OfficeClickToRun\",\"ProcessorArch\":\"9\",\"ProductType\":\"1\",\"SecuritySessionId\":\"0\"}"}
06/12/2020 13:52:38.121	OFFICECL (0xc10)	0xc14		Click-To-Run General Telemetry	bexde	Medium	::wWinMain {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "0.0.0.0", "C2RClientVer": "16.0.10361.20002", "ContextData": "Startup complete. {'LibletsTimeSpent':'140','LoggingTimeSpent':'63','TimeSpent':'203'}"}
06/12/2020 13:52:38.121	OFFICECL (0xc10)	0xf58		Click-To-Run General Telemetry	bexdf	Medium	ServiceStartupBehavior::ServiceMain {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "0.0.0.0", "C2RClientVer": "16.0.10361.20002", "ContextData": "Starting ServiceMain"}
06/12/2020 13:52:38.136	OFFICECL (0xc10)	0xf58		Click-To-Run	a14x0	Medium	ServiceStartupBehavior::ServiceMain - Setting clean reboot atom
06/12/2020 13:52:38.136	OFFICECL (0xc10)	0xf58		Click-To-Run General Telemetry	bexdg	Medium	ServiceStartupBehavior::ServiceMain {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "Starting pool initialization"}
06/12/2020 13:52:38.136	OFFICECL (0xc10)	0xf58		Click-To-Run	annt7	Medium	ProcessPool::Initialize - Initializing Main Process Pool
06/12/2020 13:52:38.136	OFFICECL (0xc10)	0xf58		Click-To-Run	a6n06	Medium	ExecutionContext::IsScenarioResumeMutexHeld - Acquired scenario resume mutex
06/12/2020 13:52:38.136	OFFICECL (0xc10)	0xf40		Activity	bjtcw	Medium	ActivityEnded {"Name": "Office.Telemetry.LoadXmlRules", "CV": "xBKbTsBqd0Cf2mOxv8UiuQ.3.1", "ProcessIdentifier": "OfficeClickToRun.exe_16.0.10361.20002_X86_{4E9B12C4-6AC0-4077-9FDA-63B1BFC522B9}"}
06/12/2020 13:52:38.136	OFFICECL (0xc10)	0xf40		Activity	bjtcw	Medium	ActivityEnded {"Name": "Office.Telemetry.ProcessIdleQueueJob", "CV": "xBKbTsBqd0Cf2mOxv8UiuQ.3", "ProcessIdentifier": "OfficeClickToRun.exe_16.0.10361.20002_X86_{4E9B12C4-6AC0-4077-9FDA-63B1BFC522B9}"}
06/12/2020 13:52:38.136	OFFICECL (0xc10)	0xf58		Click-To-Run	annuf	Medium	SystemProcessPool::DoInitialize - Initializing System Process Pool	A7028234-E1E4-4154-8FAA-1730E2C4BF1C
06/12/2020 13:52:38.136	OFFICECL (0xc10)	0xf58		Click-To-Run	anntv	Medium	ConfigurationManager::Initialize - Initializing ConfigurationManager	A7028234-E1E4-4154-8FAA-1730E2C4BF1C
06/12/2020 13:52:38.136	OFFICECL (0xc10)	0xf58		Click-To-Run General Telemetry	azfeb	Medium	ConfigurationManager::Initialize {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "Initialize"}	A7028234-E1E4-4154-8FAA-1730E2C4BF1C
06/12/2020 13:52:38.136	OFFICECL (0xc10)	0xf58		Click-To-Run	bduv7	Medium	ConfigurationManager::PopulateInitialConfigurationSettings {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "Populating initial configuration settings"}	A7028234-E1E4-4154-8FAA-1730E2C4BF1C
06/12/2020 13:52:38.136	OFFICECL (0xc10)	0xf58		Activity	bjtct	Medium	ActivityStarted {"Name": "Office.ClickToRun.DisableVirtualizationSettingForC2RHive", "CV": "xBKbTsBqd0Cf2mOxv8UiuQ.4", "ProcessIdentifier": "OfficeClickToRun.exe_16.0.10361.20002_X86_{4E9B12C4-6AC0-4077-9FDA-63B1BFC522B9}"}	A7028234-E1E4-4154-8FAA-1730E2C4BF1C
06/12/2020 13:52:38.136	OFFICECL (0xc10)	0xf58		Activity	bjtcw	Medium	ActivityEnded {"Name": "Office.ClickToRun.DisableVirtualizationSettingForC2RHive", "CV": "xBKbTsBqd0Cf2mOxv8UiuQ.4", "ProcessIdentifier": "OfficeClickToRun.exe_16.0.10361.20002_X86_{4E9B12C4-6AC0-4077-9FDA-63B1BFC522B9}"}	A7028234-E1E4-4154-8FAA-1730E2C4BF1C
06/12/2020 13:52:38.136	OFFICECL (0xc10)	0xf58		Click-To-Run	annt4	Medium	Pipeline::Initialize - Initializing pipeline with PipelineServerName: "ClickToRun_Pipeline16"	A7028234-E1E4-4154-8FAA-1730E2C4BF1C
06/12/2020 13:52:38.199	OFFICECL (0xc10)	0xf58		Click-To-Run General Telemetry	bexdb	Medium	Pipeline::Initialize {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "Pipeline initialized"}	A7028234-E1E4-4154-8FAA-1730E2C4BF1C
06/12/2020 13:52:38.199	OFFICECL (0xc10)	0xf58		Click-To-Run	annt1	Medium	Orchestration::Initialize - Initializing Orchestration	A7028234-E1E4-4154-8FAA-1730E2C4BF1C
06/12/2020 13:52:38.402	OFFICECL (0xc10)	0xf58		Click-To-Run	annto	Medium	ApiServer::Initialize - Initializing ApiServer for endpoint: C2RClientAPI_Server_System16	A7028234-E1E4-4154-8FAA-1730E2C4BF1C
06/12/2020 13:52:38.402	OFFICECL (0xc10)	0xf58		Click-To-Run General Telemetry	bexdh	Medium	ServiceStartupBehavior::ServiceMain {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "Pool initialized correctly"}
06/12/2020 13:52:38.418	OFFICECL (0xc10)	0xfc8		Click-To-Run General Telemetry	blyso	Medium	LogWatcher::ManageLogsInDirectory {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "{'NumFiles':'12','DeletesAttempted':'0','FilesDeleted':'0','FilesDeleteSizeInMB':'0'}"}
06/12/2020 13:53:41.915	OFFICECL (0xc10)	0xf74		Activity	bjtco	Medium	DroppedAggregatedActivity {"Name": "Office.Telemetry.GetFilteredPayloadsFromDisk", "CV": "xBKbTsBqd0Cf2mOxv8UiuQ.5", "ProcessIdentifier": "OfficeClickToRun.exe_16.0.10361.20002_X86_{4E9B12C4-6AC0-4077-9FDA-63B1BFC522B9}"}
06/12/2020 13:53:44.930	OFFICECL (0xc10)	0xf74		Activity	bjtct	Medium	ActivityStarted {"Name": "Office.Telemetry.LoadXmlRules", "CV": "xBKbTsBqd0Cf2mOxv8UiuQ.6", "ProcessIdentifier": "OfficeClickToRun.exe_16.0.10361.20002_X86_{4E9B12C4-6AC0-4077-9FDA-63B1BFC522B9}"}
06/12/2020 13:53:44.930	OFFICECL (0xc10)	0xf74		Activity	bjtcw	Medium	ActivityEnded {"Name": "Office.Telemetry.LoadXmlRules", "CV": "xBKbTsBqd0Cf2mOxv8UiuQ.6", "ProcessIdentifier": "OfficeClickToRun.exe_16.0.10361.20002_X86_{4E9B12C4-6AC0-4077-9FDA-63B1BFC522B9}"}
06/12/2020 13:55:01.683	OFFICECL (0x175c)	0x2350		Telemetry Rules Engine	bcdgv	Monitorable	Unrecognized category specified in UlsCategorySeveritySource {"Category": "NexusTenantTokenExcelInsightsServices"}
06/12/2020 13:55:01.683	OFFICECL (0x175c)	0x2350		Telemetry Rules Engine	bcdgv	Monitorable	Unrecognized category specified in UlsCategorySeveritySource {"Category": "NexusTenantTokenAirTrafficControl"}
06/12/2020 13:55:01.683	OFFICECL (0x175c)	0x2350		Telemetry Rules Engine	bcdgv	Monitorable	Unrecognized category specified in UlsCategorySeveritySource {"Category": "NexusTenantTokenScriptLab"}
06/12/2020 13:55:01.683	OFFICECL (0x175c)	0x2350		Telemetry Rules Engine	bcdgv	Monitorable	Unrecognized category specified in UlsCategorySeveritySource {"Category": "NexusTenantTokenProgrammableSurfaces"}
06/12/2020 13:55:01.683	OFFICECL (0x175c)	0x2350		Telemetry Rules Engine	bcdgv	Monitorable	Unrecognized category specified in UlsCategorySeveritySource {"Category": "NexusTenantTokenOfficeMobile"}
06/12/2020 13:55:01.683	OFFICECL (0x175c)	0x2350		Telemetry Rules Engine	bcdgv	Monitorable	Unrecognized category specified in UlsCategorySeveritySource {"Category": "NexusTenantTokenSandbox"}
06/12/2020 13:55:01.683	OFFICECL (0x175c)	0x2350		Telemetry Rules Engine	bcdgv	Monitorable	Unrecognized category specified in UlsCategorySeveritySource {"Category": "NexusTenantTokenDocumentXRay"}
06/12/2020 13:55:01.683	OFFICECL (0x175c)	0x2350		Telemetry Rules Engine	bcdgv	Monitorable	Unrecognized category specified in UlsCategorySeveritySource {"Category": "NexusTenantTokenMaker"}
06/12/2020 13:55:01.683	OFFICECL (0x175c)	0x2350		Telemetry Rules Engine	bcdgv	Monitorable	Unrecognized category specified in UlsCategorySeveritySource {"Category": "NexusTenantTokenGroove"}
06/12/2020 13:55:01.683	OFFICECL (0x175c)	0x2350		Telemetry Rules Engine	bcdgv	Monitorable	Unrecognized category specified in UlsCategorySeveritySource {"Category": "NexusTenantTokenLivePersonaCard"}
06/12/2020 13:55:01.683	OFFICECL (0x175c)	0x2350		Telemetry Rules Engine	bcdgv	Monitorable	Unrecognized category specified in UlsCategorySeveritySource {"Category": "NexusTenantTokenLivePersonaCardUserActions"}
06/12/2020 13:55:01.683	OFFICECL (0x175c)	0x2350		Telemetry Rules Engine	bcdgv	Monitorable	Unrecognized category specified in UlsCategorySeveritySource {"Category": "NexusTenantTokenLivePersonaPicker"}
06/12/2020 13:55:01.683	OFFICECL (0x175c)	0x2350		Telemetry Rules Engine	bcdgv	Monitorable	Unrecognized category specified in UlsCategorySeveritySource {"Category": "NexusTenantTokenLivePersonaPickerUserActions"}
06/12/2020 13:55:01.683	OFFICECL (0x175c)	0x2350		Telemetry Rules Engine	bcdgv	Monitorable	Unrecognized category specified in UlsCategorySeveritySource {"Category": "NexusTenantTokenServiceabilityManager"}
06/12/2020 13:55:01.683	OFFICECL (0x175c)	0x2350		Telemetry Rules Engine	bcdgv	Monitorable	Unrecognized category specified in UlsCategorySeveritySource {"Category": "NexusTenantTokenFloodgate"}
06/12/2020 13:55:01.683	OFFICECL (0x175c)	0x2350		Telemetry Rules Engine	bcdgv	Monitorable	Unrecognized category specified in UlsCategorySeveritySource {"Category": "NexusTenantTokenDiagnosticsSystem"}
06/12/2020 13:55:01.683	OFFICECL (0x175c)	0x2350		Telemetry Rules Engine	bcdgv	Monitorable	Unrecognized category specified in UlsCategorySeveritySource {"Category": "NexusTenantTokenLens"}
06/12/2020 13:55:01.683	OFFICECL (0x175c)	0x2350		OfficeTelemetry_PerfMetrics	axbjw	Medium	RuleFieldNamesImpact {"ETW_EventId": 196, "ETW_Keywords": 128, "cbMemory": 6714, "count": 204}
06/12/2020 13:55:01.699	OFFICECL (0x175c)	0x2350		Activity	bjtcw	Medium	ActivityEnded {"Name": "Office.Telemetry.ProcessIdleQueueJob", "CV": "9XJsFEIpPECEf/J+gbEQjg.3", "ProcessIdentifier": "OfficeClickToRun.exe_16.0.10361.20002_X86_{146C72F5-2942-403C-847F-F27E81B1108E}"}
06/12/2020 13:55:01.746	OFFICECL (0x175c)	0x1784		Click-To-Run General Telemetry	aqkhc	Medium	InitLogging {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "0.0.0.0", "C2RClientVer": "16.0.10361.20002", "ContextData": "{\"AppVVersion\":\"5.1.141\",\"Bitness\":\"64\",\"CommandLine\":\"/service\",\"ExeVer\":\"16.0.10361.20002\",\"IntegrityLevel\":\"0x4000\",\"Locale\":\"1036\",\"ModulePath\":\"C:\\\\Program Files\\\\Common Files\\\\Microsoft Shared\\\\ClickToRun\\\\OfficeClickToRun.exe\",\"OSVersion\":\"10.0\",\"ProcessType\":\"OfficeClickToRun\",\"ProcessorArch\":\"9\",\"ProductType\":\"1\",\"SecuritySessionId\":\"0\"}"}
06/12/2020 13:55:01.746	OFFICECL (0x175c)	0x1784		Click-To-Run General Telemetry	bexde	Medium	::wWinMain {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "0.0.0.0", "C2RClientVer": "16.0.10361.20002", "ContextData": "Startup complete. {'LibletsTimeSpent':'31','LoggingTimeSpent':'63','TimeSpent':'94'}"}
06/12/2020 13:55:01.746	OFFICECL (0x175c)	0x2374		Click-To-Run General Telemetry	bexdf	Medium	ServiceStartupBehavior::ServiceMain {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "0.0.0.0", "C2RClientVer": "16.0.10361.20002", "ContextData": "Starting ServiceMain"}
06/12/2020 13:55:01.746	OFFICECL (0x175c)	0x2374		Click-To-Run General Telemetry	bexdg	Medium	ServiceStartupBehavior::ServiceMain {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "Starting pool initialization"}
06/12/2020 13:55:01.746	OFFICECL (0x175c)	0x2374		Click-To-Run	annt7	Medium	ProcessPool::Initialize - Initializing Main Process Pool
06/12/2020 13:55:01.746	OFFICECL (0x175c)	0x2374		Click-To-Run	a6n06	Medium	ExecutionContext::IsScenarioResumeMutexHeld - Acquired scenario resume mutex
06/12/2020 13:55:01.746	OFFICECL (0x175c)	0x2374		Click-To-Run	annuf	Medium	SystemProcessPool::DoInitialize - Initializing System Process Pool	BF1C8BEA-434E-4B04-AA9E-20A9B230D549
06/12/2020 13:55:01.746	OFFICECL (0x175c)	0x2374		Click-To-Run	anntv	Medium	ConfigurationManager::Initialize - Initializing ConfigurationManager	BF1C8BEA-434E-4B04-AA9E-20A9B230D549
06/12/2020 13:55:01.746	OFFICECL (0x175c)	0x2374		Click-To-Run General Telemetry	azfeb	Medium	ConfigurationManager::Initialize {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "Initialize"}	BF1C8BEA-434E-4B04-AA9E-20A9B230D549
06/12/2020 13:55:01.746	OFFICECL (0x175c)	0x2374		Click-To-Run	bduv7	Medium	ConfigurationManager::PopulateInitialConfigurationSettings {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "Populating initial configuration settings"}	BF1C8BEA-434E-4B04-AA9E-20A9B230D549
06/12/2020 13:55:01.746	OFFICECL (0x175c)	0x2374		Activity	bjtct	Medium	ActivityStarted {"Name": "Office.ClickToRun.DisableVirtualizationSettingForC2RHive", "CV": "9XJsFEIpPECEf/J+gbEQjg.4", "ProcessIdentifier": "OfficeClickToRun.exe_16.0.10361.20002_X86_{146C72F5-2942-403C-847F-F27E81B1108E}"}	BF1C8BEA-434E-4B04-AA9E-20A9B230D549
06/12/2020 13:55:01.746	OFFICECL (0x175c)	0x2374		Activity	bjtcw	Medium	ActivityEnded {"Name": "Office.ClickToRun.DisableVirtualizationSettingForC2RHive", "CV": "9XJsFEIpPECEf/J+gbEQjg.4", "ProcessIdentifier": "OfficeClickToRun.exe_16.0.10361.20002_X86_{146C72F5-2942-403C-847F-F27E81B1108E}"}	BF1C8BEA-434E-4B04-AA9E-20A9B230D549
06/12/2020 13:55:01.746	OFFICECL (0x175c)	0x2374		Click-To-Run	annt4	Medium	Pipeline::Initialize - Initializing pipeline with PipelineServerName: "ClickToRun_Pipeline16"	BF1C8BEA-434E-4B04-AA9E-20A9B230D549
06/12/2020 13:55:01.855	OFFICECL (0x175c)	0x2374		Click-To-Run General Telemetry	bexdb	Medium	Pipeline::Initialize {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "Pipeline initialized"}	BF1C8BEA-434E-4B04-AA9E-20A9B230D549
06/12/2020 13:55:01.855	OFFICECL (0x175c)	0x2374		Click-To-Run	annt1	Medium	Orchestration::Initialize - Initializing Orchestration	BF1C8BEA-434E-4B04-AA9E-20A9B230D549
06/12/2020 13:55:02.093	OFFICECL (0x175c)	0x2374		Click-To-Run	annuz	Medium	TaskFactory::TryLoadScenario - Start loading INSTALL scenario	BF1C8BEA-434E-4B04-AA9E-20A9B230D549
06/12/2020 13:55:02.093	OFFICECL (0x175c)	0x2374		Click-To-Run	annu0	Medium	TaskFactory::TryLoadScenario - Loading INSTALL scenario is successful	BF1C8BEA-434E-4B04-AA9E-20A9B230D549
06/12/2020 13:55:02.093	OFFICECL (0x175c)	0x2374		Click-To-Run	arqkd	Medium	ScenarioController::Initialize - requested display level: False	BF1C8BEA-434E-4B04-AA9E-20A9B230D549
06/12/2020 13:55:02.093	OFFICECL (0x175c)	0x2374		Click-To-Run	apvws	Medium	TaskScenario::ResumeScenario - Attempts to resume scenario INSTALL	BF1C8BEA-434E-4B04-AA9E-20A9B230D549
06/12/2020 13:55:02.093	OFFICECL (0x175c)	0x2374		Click-To-Run	aqdyl	Medium	TaskScenario::ResumeScenario - Resuming the scenario INSTALL	BF1C8BEA-434E-4B04-AA9E-20A9B230D549
06/12/2020 13:55:02.093	OFFICECL (0x175c)	0x2374		Click-To-Run	as776	Medium	TaskGroup::ResumeExecutingTasks - Resuming task FB9843BB-0D8A-4347-A227-C759C3FC9103.	BF1C8BEA-434E-4B04-AA9E-20A9B230D549
06/12/2020 13:55:02.093	OFFICECL (0x175c)	0x2374		Click-To-Run	aqdyj	Medium	TaskGroup::ResumeExecutingTasks - Resuming Group {DF3BBBD9-F521-43BA-BE89-8749E5F80983}	BF1C8BEA-434E-4B04-AA9E-20A9B230D549
06/12/2020 13:55:32.751	OFFICECL (0x175c)	0x2374		Click-To-Run	as777	Medium	TaskGroup::ResumeExecutingTasks - Group was not resumed, queuing Group {DF3BBBD9-F521-43BA-BE89-8749E5F80983}	BF1C8BEA-434E-4B04-AA9E-20A9B230D549
06/12/2020 13:55:32.751	OFFICECL (0x175c)	0x2374		Click-To-Run	annua	Medium	ProcessPool::QueueTaskItem - Task BRANCH:{DF3BBBD9-F521-43BA-BE89-8749E5F80983} is being scheduled to run in this process	BF1C8BEA-434E-4B04-AA9E-20A9B230D549
06/12/2020 13:55:32.751	OFFICECL (0x175c)	0x2374		Click-To-Run	a4z5n	Medium	TaskScenario::ResumeScenario - Successfully resumed executing tasks.	BF1C8BEA-434E-4B04-AA9E-20A9B230D549
06/12/2020 13:55:32.751	OFFICECL (0x175c)	0x2374		Click-To-Run	aplq5	Medium	ExecutionContext::ResumeExecutingScenario - Successfully resumed scenario INSTALL.	BF1C8BEA-434E-4B04-AA9E-20A9B230D549
06/12/2020 13:55:32.751	OFFICECL (0x175c)	0x2374		Click-To-Run	annto	Medium	ApiServer::Initialize - Initializing ApiServer for endpoint: C2RClientAPI_Server_System16	BF1C8BEA-434E-4B04-AA9E-20A9B230D549
06/12/2020 13:55:32.751	OFFICECL (0x175c)	0x2080		Click-To-Run	aozsl	Medium	TaskBranch::DoExecute - Found task {8D3B8D3F-A1B6-4149-8187-5530518A3849} that matches {Continue} condition.
06/12/2020 13:55:32.751	OFFICECL (0x175c)	0x2080		Click-To-Run	annvj	Medium	Worker::TaskExecutionThreadProc - Task BRANCH:{DF3BBBD9-F521-43BA-BE89-8749E5F80983} completed with TaskState TASKSTATE_FAILED.
06/12/2020 13:55:32.751	OFFICECL (0x175c)	0x2080		Click-To-Run	aozsm	Medium	TaskBranch::DoHandleWorkerCompleteEvent - Task {DF3BBBD9-F521-43BA-BE89-8749E5F80983} success event is handled by task {DF3BBBD9-F521-43BA-BE89-8749E5F80983}
06/12/2020 13:55:32.751	OFFICECL (0x175c)	0x2080		Click-To-Run	annu6	Medium	TaskGroup::DoHandleWorkerCompleteEvent - Task {DF3BBBD9-F521-43BA-BE89-8749E5F80983} complete event is handled by task {FB9843BB-0D8A-4347-A227-C759C3FC9103}
06/12/2020 13:55:32.751	OFFICECL (0x175c)	0x2080		Click-To-Run	apm4q	Monitorable	TaskGroup::DoCancel - Can't cancel task {FB9843BB-0D8A-4347-A227-C759C3FC9103} because it is in TASKSTATE_FAILED state
06/12/2020 13:55:32.751	OFFICECL (0x175c)	0x2374		Click-To-Run General Telemetry	bexdh	Medium	ServiceStartupBehavior::ServiceMain {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "Pool initialized correctly"}
06/12/2020 13:55:32.751	OFFICECL (0x175c)	0x2080		Click-To-Run	apm4o	Medium	TaskGroup::Finalize - Finalizing task FB9843BB-0D8A-4347-A227-C759C3FC9103.
06/12/2020 13:55:32.751	OFFICECL (0x175c)	0x23cc		Click-To-Run	ati21	Medium	SystemProcessPool::WaitOnScenarioReset - Scenario is reset.
06/12/2020 13:55:32.751	OFFICECL (0x175c)	0x2080		Click-To-Run	annt0	Medium	ExecutionContext::ResetExecutingScenario - Reset executing scenario
06/12/2020 13:55:32.751	OFFICECL (0x175c)	0x20d8		Click-To-Run General Telemetry	blyso	Medium	LogWatcher::ManageLogsInDirectory {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "{'NumFiles':'14','DeletesAttempted':'0','FilesDeleted':'0','FilesDeleteSizeInMB':'0'}"}
06/12/2020 13:58:40.357	OFFICECL (0x175c)	0x2220		Click-To-Run General Telemetry	a4htx	Medium	::QueueUpdate {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "Triggering an update: {'Parameters':'displaylevel=False flt.useexptransportinplacepl=unknown flt.useofficehelperaddon=unknown flt.useoutlookshareaddon=unknown flt.useteamsaddon=unknown flt.usedms=true flt.dmsapiversion=2 flt.dmsapiuri=https://mrodevicemgr.officeapps.live.com/mrodevicemgrsvc/api flt.dmsrequestattemptlimit=3 flt.dmsshouldallowtargetaudiencemove=false triggersource=SCHEDULEDTASK'}"}
06/12/2020 13:58:40.357	OFFICECL (0x175c)	0x1928		Click-To-Run	annty	Medium	ExecutionContext::QueueScenario - Set executing scenario to UPDATE
06/12/2020 13:58:40.357	OFFICECL (0x175c)	0x1928		Click-To-Run	annuz	Medium	TaskFactory::TryLoadScenario - Start loading UPDATE scenario
06/12/2020 13:58:40.357	OFFICECL (0x175c)	0x1928		Click-To-Run	annu0	Medium	TaskFactory::TryLoadScenario - Loading UPDATE scenario is successful
06/12/2020 13:58:40.357	OFFICECL (0x175c)	0x1928		Click-To-Run	axiks	Medium	TaskScenario::TryInitializeScenarioSettings - ScenarioInstanceId = 52EB0076-2F60-4973-B021-23A0CD8EF8B3
06/12/2020 13:58:40.357	OFFICECL (0x175c)	0x1928		Click-To-Run	arqkd	Medium	ScenarioController::Initialize - requested display level: False
06/12/2020 13:58:40.357	OFFICECL (0x175c)	0x1928		Click-To-Run	annua	Medium	ProcessPool::QueueTaskItem - Task SCENARIO:{AC2F0D89-6518-48E9-A0D9-EF039C456034} is being scheduled to run in this process
06/12/2020 13:58:40.357	OFFICECL (0x175c)	0x1928		Click-To-Run	aoicd	Medium	ExecutionContext::QueueScenario - Successfully queue scenario UPDATE.
06/12/2020 13:58:40.357	OFFICECL (0x175c)	0xb28		Click-To-Run	annua	Medium	ProcessPool::QueueTaskItem - Task UPDATEDETECTION:{77176F9C-873B-4A7D-8051-EBEB52DDE8B0} is being scheduled to run in this process
06/12/2020 13:58:40.357	OFFICECL (0x175c)	0xb28		Click-To-Run	annvj	Medium	Worker::TaskExecutionThreadProc - Task SCENARIO:{AC2F0D89-6518-48E9-A0D9-EF039C456034} completed with TaskState TASKSTATE_EXECUTING.
06/12/2020 13:58:40.357	OFFICECL (0x175c)	0xb28		Click-To-Run	annu6	Medium	TaskGroup::DoHandleWorkerCompleteEvent - Task {AC2F0D89-6518-48E9-A0D9-EF039C456034} complete event is handled by task {AC2F0D89-6518-48E9-A0D9-EF039C456034}
06/12/2020 13:58:40.357	OFFICECL (0x175c)	0x19a0		Activity	bjtct	Medium	ActivityStarted {"Name": "Office.ClickToRun.Scenario.UpdateTaskUpdatedetection", "CV": "9XJsFEIpPECEf/J+gbEQjg.5", "ProcessIdentifier": "OfficeClickToRun.exe_16.0.10361.20002_X86_{146C72F5-2942-403C-847F-F27E81B1108E}"}
06/12/2020 13:58:40.357	OFFICECL (0x175c)	0x19a0		Click-To-Run Task Telemetry	aqvpf	Medium	Task::Execute {"ScenarioInstanceId": "52EB0076-2F60-4973-B021-23A0CD8EF8B3", "TaskId": "77176F9C-873B-4A7D-8051-EBEB52DDE8B0", "TaskType": "UPDATEDETECTION:{77176F9C-873B-4A7D-8051-EBEB52DDE8B0}", "TaskState": 1, "Scenario": "UPDATE", "InstallID": "6ED626A4-A873-4B64-94C2-15BF67F34A63", "ScenarioSubType": "", "SourceType": "", "MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "Starting task {'Attempt':'1'}"}
06/12/2020 13:58:40.357	OFFICECL (0x175c)	0x19a0		Click-To-Run Task Telemetry	bj5z7	Medium	TaskUpdateDetection::IsChannelChanged {"ScenarioInstanceId": "52EB0076-2F60-4973-B021-23A0CD8EF8B3", "TaskId": "77176F9C-873B-4A7D-8051-EBEB52DDE8B0", "TaskType": "UPDATEDETECTION:{77176F9C-873B-4A7D-8051-EBEB52DDE8B0}", "TaskState": 1, "Scenario": "UPDATE", "InstallID": "6ED626A4-A873-4B64-94C2-15BF67F34A63", "ScenarioSubType": "", "SourceType": "", "MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "{\"message\":\": Channel changed from [\\\\\\\\pedasrv\\\\office2019$] to [\\\\\\\\pedasrv\\\\office2019$\\\\Updates] for MajorVersion 16\"}"}
06/12/2020 13:58:40.357	OFFICECL (0x175c)	0x19a0		Click-To-Run Task Telemetry	aoh58	Medium	TaskUpdateDetection::IsUpdatesDiscoveryPeriodComplete {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ScenarioInstanceId": "52EB0076-2F60-4973-B021-23A0CD8EF8B3", "TaskId": "77176F9C-873B-4A7D-8051-EBEB52DDE8B0", "TaskType": "UPDATEDETECTION:{77176F9C-873B-4A7D-8051-EBEB52DDE8B0}", "TaskState": 1, "Scenario": "UPDATE", "InstallID": "6ED626A4-A873-4B64-94C2-15BF67F34A63", "ScenarioSubType": "", "SourceType": "UNC", "ContextData": "Scheduled task update disabled due to updates discovery period not yet complete. {'ReasonIncomplete':'discoveryperiod','Duration':'1943','MajorVersion':'16'}"}
06/12/2020 13:58:40.372	OFFICECL (0x175c)	0x19a0		Click-To-Run General Telemetry	csli6	Medium	C2R::UpdateTask::IsGpoTransitionBeingRun {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "{\"message\":\"IsGpoTransitionBeingRun\",\"Is Gpo Transition Being Run ?\":\"False\"}"}
06/12/2020 13:58:40.372	OFFICECL (0x175c)	0x19a0		Click-To-Run General Telemetry	csmfr	Medium	C2R::TaskUpdateDetection::IsConfigurationChangeRequested {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "{\"message\":\"IsConfigurationChangeRequested\",\"Is download expected ?\":\"False\"}"}
06/12/2020 13:58:40.372	OFFICECL (0x175c)	0x19a0		Click-To-Run Task Telemetry	av6xn	Medium	TaskUpdateDetection::PopulateDetectionStateForMajorVersion {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ScenarioInstanceId": "52EB0076-2F60-4973-B021-23A0CD8EF8B3", "TaskId": "77176F9C-873B-4A7D-8051-EBEB52DDE8B0", "TaskType": "UPDATEDETECTION:{77176F9C-873B-4A7D-8051-EBEB52DDE8B0}", "TaskState": 1, "Scenario": "UPDATE", "InstallID": "6ED626A4-A873-4B64-94C2-15BF67F34A63", "ScenarioSubType": "", "SourceType": "UNC", "ContextData": "Beginning Update Scenario. {'TaskCaller':'SCHEDULEDTASK','TriggeringUI':'UNDEFINED','TargetVersion':'UNDEFINED','MajorVersion':'16'}"}
06/12/2020 13:58:40.372	OFFICECL (0x175c)	0x19a0		Click-To-Run Task Telemetry	aoh6s	Medium	TaskUpdateDetection::Execute {"ScenarioInstanceId": "52EB0076-2F60-4973-B021-23A0CD8EF8B3", "TaskId": "77176F9C-873B-4A7D-8051-EBEB52DDE8B0", "TaskType": "UPDATEDETECTION:{77176F9C-873B-4A7D-8051-EBEB52DDE8B0}", "TaskState": 1, "Scenario": "UPDATE", "InstallID": "6ED626A4-A873-4B64-94C2-15BF67F34A63", "ScenarioSubType": "DefaultCustomVersion", "SourceType": "UNC", "MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "Ending Update scenario, task trigger source disabled and not a config change."}
06/12/2020 13:58:40.372	OFFICECL (0x175c)	0x19a0		Click-To-Run	annvj	Medium	Worker::TaskExecutionThreadProc - Task UPDATEDETECTION:{77176F9C-873B-4A7D-8051-EBEB52DDE8B0} completed with TaskState TASKSTATE_FAILED.
06/12/2020 13:58:40.372	OFFICECL (0x175c)	0x19a0		Click-To-Run	apm4b	Medium	Task::DoHandleWorkerCompleteEvent - Setting Task (77176F9C-873B-4A7D-8051-EBEB52DDE8B0) Task State to (TASKSTATE_FAILED)
06/12/2020 13:58:40.372	OFFICECL (0x175c)	0x19a0		Click-To-Run	aqkg7	Medium	Task::DoHandleWorkerCompleteEvent - No event is specified for task (77176F9C-873B-4A7D-8051-EBEB52DDE8B0)
06/12/2020 13:58:40.372	OFFICECL (0x175c)	0x19a0		Click-To-Run Task Telemetry	annux	Medium	Task::DoHandleWorkerSuccessEvent {"ScenarioInstanceId": "52EB0076-2F60-4973-B021-23A0CD8EF8B3", "TaskId": "77176F9C-873B-4A7D-8051-EBEB52DDE8B0", "TaskType": "UPDATEDETECTION:{77176F9C-873B-4A7D-8051-EBEB52DDE8B0}", "TaskState": 5, "Scenario": "UPDATE", "InstallID": "6ED626A4-A873-4B64-94C2-15BF67F34A63", "ScenarioSubType": "DefaultCustomVersion", "SourceType": "UNC", "MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "Task execution complete {'Attempt':'1'}"}
06/12/2020 13:58:40.372	OFFICECL (0x175c)	0x19a0		Click-To-Run Task Telemetry	apm4e	Medium	Task::HandleTaskStateFailed {"ScenarioInstanceId": "52EB0076-2F60-4973-B021-23A0CD8EF8B3", "TaskId": "77176F9C-873B-4A7D-8051-EBEB52DDE8B0", "TaskType": "UPDATEDETECTION:{77176F9C-873B-4A7D-8051-EBEB52DDE8B0}", "TaskState": 5, "Scenario": "UPDATE", "InstallID": "6ED626A4-A873-4B64-94C2-15BF67F34A63", "ScenarioSubType": "DefaultCustomVersion", "SourceType": "UNC", "MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "Handling TaskState for task"}
06/12/2020 13:58:40.372	OFFICECL (0x175c)	0x19a0		Click-To-Run	apkpk	Monitorable	ScenarioController::CheckProcessPool - Failed to get/create ui process pool, and we are not the ui handler. Cannot process event
06/12/2020 13:58:40.372	OFFICECL (0x175c)	0x19a0		Click-To-Run	annu6	Medium	TaskGroup::DoHandleWorkerCompleteEvent - Task {77176F9C-873B-4A7D-8051-EBEB52DDE8B0} complete event is handled by task {AC2F0D89-6518-48E9-A0D9-EF039C456034}
06/12/2020 13:58:40.372	OFFICECL (0x175c)	0x19a0		Click-To-Run	apm4p	Medium	TaskGroup::DoCancel - Attempting to cancel task {AC2F0D89-6518-48E9-A0D9-EF039C456034}
06/12/2020 13:58:40.372	OFFICECL (0x175c)	0x19a0		Click-To-Run	apm4a	Monitorable	Task::DoCancel - Can't cancel task (77176F9C-873B-4A7D-8051-EBEB52DDE8B0) because it is in TASKSTATE_FAILED state
06/12/2020 13:58:40.372	OFFICECL (0x175c)	0x19a0		Click-To-Run	apm4p	Medium	TaskGroup::DoCancel - Attempting to cancel task {CBE12CCA-A2EC-4B22-910B-34FF28AD415A}
06/12/2020 13:58:40.372	OFFICECL (0x175c)	0x19a0		Click-To-Run	apm4p	Medium	TaskGroup::DoCancel - Attempting to cancel task {AFBE6AE5-BEBB-4CE4-9110-0CA503B60703}
06/12/2020 13:58:40.372	OFFICECL (0x175c)	0x19a0		Click-To-Run	apm39	Medium	Task::DoCancel - Task (EEC7D146-7A4A-44C7-B04C-09B87C37724C) in TASKSTATE_NOTSTARTED, set to Cancelled.
06/12/2020 13:58:40.372	OFFICECL (0x175c)	0x19a0		Click-To-Run	apm39	Medium	Task::DoCancel - Task (EC2DCD0D-14B9-4297-8A08-E1F4E938E8B5) in TASKSTATE_NOTSTARTED, set to Cancelled.
06/12/2020 13:58:40.372	OFFICECL (0x175c)	0x19a0		Click-To-Run	apm4o	Medium	TaskGroup::Finalize - Finalizing task AFBE6AE5-BEBB-4CE4-9110-0CA503B60703.
06/12/2020 13:58:40.372	OFFICECL (0x175c)	0x19a0		Click-To-Run	apm4o	Medium	TaskGroup::Finalize - Finalizing task CBE12CCA-A2EC-4B22-910B-34FF28AD415A.
06/12/2020 13:58:40.372	OFFICECL (0x175c)	0x19a0		Click-To-Run	apm4p	Medium	TaskGroup::DoCancel - Attempting to cancel task {C0DFE4C2-56CC-4766-A23E-7BE2675359C3}
06/12/2020 13:58:40.372	OFFICECL (0x175c)	0x19a0		Click-To-Run	apm4p	Medium	TaskGroup::DoCancel - Attempting to cancel task {A0A4CAB7-FA90-4AD9-81C9-EB0E138B919A}
06/12/2020 13:58:40.372	OFFICECL (0x175c)	0x19a0		Click-To-Run	apm39	Medium	Task::DoCancel - Task (9ECBBD08-437D-4246-9F21-2572B9898318) in TASKSTATE_NOTSTARTED, set to Cancelled.
06/12/2020 13:58:40.372	OFFICECL (0x175c)	0x19a0		Click-To-Run	apm39	Medium	Task::DoCancel - Task (11B5A027-3F59-4C37-8CE0-5C34AC0A8FA2) in TASKSTATE_NOTSTARTED, set to Cancelled.
06/12/2020 13:58:40.372	OFFICECL (0x175c)	0x19a0		Click-To-Run	apm4p	Medium	TaskGroup::DoCancel - Attempting to cancel task {D1506E3F-4B2A-41D3-913B-FA3E889CE20D}
06/12/2020 13:58:40.372	OFFICECL (0x175c)	0x19a0		Click-To-Run	apm4p	Medium	TaskGroup::DoCancel - Attempting to cancel task {9C141B7D-2B22-4C33-9C5C-F6F3394AD19E}
06/12/2020 13:58:40.372	OFFICECL (0x175c)	0x19a0		Click-To-Run	apm4p	Medium	TaskGroup::DoCancel - Attempting to cancel task {501487AD-0A47-419D-AF30-B9E616A4579B}
06/12/2020 13:58:40.372	OFFICECL (0x175c)	0x19a0		Click-To-Run	apm4p	Medium	TaskGroup::DoCancel - Attempting to cancel task {0270BAF9-3CE0-46EE-A3FE-099ABC06BC14}
06/12/2020 13:58:40.372	OFFICECL (0x175c)	0x19a0		Click-To-Run	apm39	Medium	Task::DoCancel - Task (F0E5AF5D-5D82-4370-A2A6-C064CBC39247) in TASKSTATE_NOTSTARTED, set to Cancelled.
06/12/2020 13:58:40.372	OFFICECL (0x175c)	0x19a0		Click-To-Run	apm4o	Medium	TaskGroup::Finalize - Finalizing task 0270BAF9-3CE0-46EE-A3FE-099ABC06BC14.
06/12/2020 13:58:40.372	OFFICECL (0x175c)	0x19a0		Click-To-Run	apm4o	Medium	TaskGroup::Finalize - Finalizing task 501487AD-0A47-419D-AF30-B9E616A4579B.
06/12/2020 13:58:40.372	OFFICECL (0x175c)	0x19a0		Click-To-Run	apm39	Medium	Task::DoCancel - Task (A5E75ADF-8BF1-44C4-8900-1BE6070EB609) in TASKSTATE_NOTSTARTED, set to Cancelled.
06/12/2020 13:58:40.372	OFFICECL (0x175c)	0x19a0		Click-To-Run	apm4o	Medium	TaskGroup::Finalize - Finalizing task 9C141B7D-2B22-4C33-9C5C-F6F3394AD19E.
06/12/2020 13:58:40.372	OFFICECL (0x175c)	0x19a0		Click-To-Run	apm4o	Medium	TaskGroup::Finalize - Finalizing task D1506E3F-4B2A-41D3-913B-FA3E889CE20D.
06/12/2020 13:58:40.372	OFFICECL (0x175c)	0x19a0		Click-To-Run	apm4o	Medium	TaskGroup::Finalize - Finalizing task A0A4CAB7-FA90-4AD9-81C9-EB0E138B919A.
06/12/2020 13:58:40.372	OFFICECL (0x175c)	0x19a0		Click-To-Run	apm4o	Medium	TaskGroup::Finalize - Finalizing task C0DFE4C2-56CC-4766-A23E-7BE2675359C3.
06/12/2020 13:58:40.372	OFFICECL (0x175c)	0x19a0		Click-To-Run	apm4o	Medium	TaskGroup::Finalize - Finalizing task AC2F0D89-6518-48E9-A0D9-EF039C456034.
06/12/2020 13:58:40.372	OFFICECL (0x175c)	0x19a0		Click-To-Run	annt0	Medium	ExecutionContext::ResetExecutingScenario - Reset executing scenario
06/12/2020 13:58:40.372	OFFICECL (0x175c)	0x23cc		Click-To-Run	ati21	Medium	SystemProcessPool::WaitOnScenarioReset - Scenario is reset.
06/12/2020 13:58:40.372	OFFICECL (0x175c)	0x19a0		Activity	bjtcw	Medium	ActivityEnded {"Name": "Office.ClickToRun.Scenario.UpdateTaskUpdatedetection", "CV": "9XJsFEIpPECEf/J+gbEQjg.5", "ProcessIdentifier": "OfficeClickToRun.exe_16.0.10361.20002_X86_{146C72F5-2942-403C-847F-F27E81B1108E}"}
Do you see any other uninstallation methods? I really don't see where this could be coming from.
Without being particularly expert in Python, I still managed to code almost all the establishment software (that's the magic of WAPT) but now I'm really at a dead end.
So yes, this post is a bit long and probably contains too much detail on our end, but I'm looking for a solution...
lfkl
June 12, 2020 - 08:14
The two missing logs...
06/12/2020 13:55:01.808	OFFICECL (0x236c)	0x2340		OfficeTelemetry_RuleProcessing	axbjw	Medium	OTele_ETW_TDC_LoadingRulesStarted {"ETW_EventId": 119, "ETW_Keywords": 4}
06/12/2020 13:55:01.808	OFFICECL (0x236c)	0x2340		Activity	bjtct	Medium	ActivityStarted {"Name": "Office.Telemetry.LoadXmlRules", "CV": "NpNljPoL4keFzW32Lx7D6A.3.1", "ProcessIdentifier": "OfficeClickToRun.exe_16.0.10361.20002_X86_{8C659336-0BFA-47E2-85CD-6DF62F1EC3E8}"}
06/12/2020 13:55:01.808	OFFICECL (0x236c)	0x2340		Telemetry Rules Engine	bcdgv	Monitorable	Unrecognized category specified in UlsCategorySeveritySource {"Category": "NexusTenantTokenExcelInsightsServices"}
06/12/2020 13:55:01.808	OFFICECL (0x236c)	0x2340		Telemetry Rules Engine	bcdgv	Monitorable	Unrecognized category specified in UlsCategorySeveritySource {"Category": "NexusTenantTokenAirTrafficControl"}
06/12/2020 13:55:01.808	OFFICECL (0x236c)	0x2340		Telemetry Rules Engine	bcdgv	Monitorable	Unrecognized category specified in UlsCategorySeveritySource {"Category": "NexusTenantTokenScriptLab"}
06/12/2020 13:55:01.808	OFFICECL (0x236c)	0x2340		Telemetry Rules Engine	bcdgv	Monitorable	Unrecognized category specified in UlsCategorySeveritySource {"Category": "NexusTenantTokenProgrammableSurfaces"}
06/12/2020 13:55:01.808	OFFICECL (0x236c)	0x2340		Telemetry Rules Engine	bcdgv	Monitorable	Unrecognized category specified in UlsCategorySeveritySource {"Category": "NexusTenantTokenOfficeMobile"}
06/12/2020 13:55:01.808	OFFICECL (0x236c)	0x2340		Telemetry Rules Engine	bcdgv	Monitorable	Unrecognized category specified in UlsCategorySeveritySource {"Category": "NexusTenantTokenSandbox"}
06/12/2020 13:55:01.808	OFFICECL (0x236c)	0x2340		Telemetry Rules Engine	bcdgv	Monitorable	Unrecognized category specified in UlsCategorySeveritySource {"Category": "NexusTenantTokenDocumentXRay"}
06/12/2020 13:55:01.808	OFFICECL (0x236c)	0x2340		Telemetry Rules Engine	bcdgv	Monitorable	Unrecognized category specified in UlsCategorySeveritySource {"Category": "NexusTenantTokenMaker"}
06/12/2020 13:55:01.808	OFFICECL (0x236c)	0x2340		Telemetry Rules Engine	bcdgv	Monitorable	Unrecognized category specified in UlsCategorySeveritySource {"Category": "NexusTenantTokenGroove"}
06/12/2020 13:55:01.808	OFFICECL (0x236c)	0x2340		Telemetry Rules Engine	bcdgv	Monitorable	Unrecognized category specified in UlsCategorySeveritySource {"Category": "NexusTenantTokenLivePersonaCard"}
06/12/2020 13:55:01.808	OFFICECL (0x236c)	0x2340		Telemetry Rules Engine	bcdgv	Monitorable	Unrecognized category specified in UlsCategorySeveritySource {"Category": "NexusTenantTokenLivePersonaCardUserActions"}
06/12/2020 13:55:01.808	OFFICECL (0x236c)	0x2340		Telemetry Rules Engine	bcdgv	Monitorable	Unrecognized category specified in UlsCategorySeveritySource {"Category": "NexusTenantTokenLivePersonaPicker"}
06/12/2020 13:55:01.808	OFFICECL (0x236c)	0x2340		Telemetry Rules Engine	bcdgv	Monitorable	Unrecognized category specified in UlsCategorySeveritySource {"Category": "NexusTenantTokenLivePersonaPickerUserActions"}
06/12/2020 13:55:01.808	OFFICECL (0x236c)	0x2340		Telemetry Rules Engine	bcdgv	Monitorable	Unrecognized category specified in UlsCategorySeveritySource {"Category": "NexusTenantTokenServiceabilityManager"}
06/12/2020 13:55:01.808	OFFICECL (0x236c)	0x2340		Telemetry Rules Engine	bcdgv	Monitorable	Unrecognized category specified in UlsCategorySeveritySource {"Category": "NexusTenantTokenFloodgate"}
06/12/2020 13:55:01.808	OFFICECL (0x236c)	0x2340		Telemetry Rules Engine	bcdgv	Monitorable	Unrecognized category specified in UlsCategorySeveritySource {"Category": "NexusTenantTokenDiagnosticsSystem"}
06/12/2020 13:55:01.808	OFFICECL (0x236c)	0x2340		Telemetry Rules Engine	bcdgv	Monitorable	Unrecognized category specified in UlsCategorySeveritySource {"Category": "NexusTenantTokenLens"}
06/12/2020 13:55:01.824	OFFICECL (0x236c)	0x2340		OfficeTelemetry_PerfMetrics	axbjw	Medium	RuleFieldNamesImpact {"ETW_EventId": 196, "ETW_Keywords": 128, "cbMemory": 6714, "count": 204}
06/12/2020 13:55:01.824	OFFICECL (0x236c)	0x2380		Click-To-Run General Telemetry	aqkhc	Medium	InitLogging {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "0.0.0.0", "C2RClientVer": "16.0.10361.20002", "ContextData": "{\"AppVVersion\":\"5.1.141\",\"Bitness\":\"64\",\"CommandLine\":\"scenario=install scenariosubtype=ARP sourcetype=None productstoremove=ProPlus2019Volume.16_fr-fr_x-none culture=fr-fr version.16=16.0 DisplayLevel=False\",\"ExeVer\":\"16.0.10361.20002\",\"IntegrityLevel\":\"0x4000\",\"Locale\":\"1036\",\"ModulePath\":\"C:\\\\Program Files\\\\Common Files\\\\microsoft shared\\\\ClickToRun\\\\OfficeClickToRun.exe\",\"OSVersion\":\"10.0\",\"ProcessType\":\"OfficeClickToRun\",\"ProcessorArch\":\"9\",\"ProductType\":\"1\",\"SecuritySessionId\":\"0\"}"}
06/12/2020 13:55:01.824	OFFICECL (0x236c)	0x2380		Click-To-Run General Telemetry	bexde	Medium	::wWinMain {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "0.0.0.0", "C2RClientVer": "16.0.10361.20002", "ContextData": "Startup complete. {'LibletsTimeSpent':'15','LoggingTimeSpent':'16','TimeSpent':'31'}"}
06/12/2020 13:55:01.824	OFFICECL (0x236c)	0x2380		Click-To-Run	annt7	Medium	ProcessPool::Initialize - Initializing Main Process Pool
06/12/2020 13:55:01.824	OFFICECL (0x236c)	0x2380		Click-To-Run	a6n06	Medium	ExecutionContext::IsScenarioResumeMutexHeld - Acquired scenario resume mutex
06/12/2020 13:55:01.824	OFFICECL (0x236c)	0x2380		Click-To-Run	annuh	Medium	ElevatedProcessPool::DoInitialize - Initializing Elevated Process Pool
06/12/2020 13:55:01.824	OFFICECL (0x236c)	0x2380		Click-To-Run	anntv	Medium	ConfigurationManager::Initialize - Initializing ConfigurationManager
06/12/2020 13:55:01.824	OFFICECL (0x236c)	0x2380		Click-To-Run General Telemetry	azfeb	Medium	ConfigurationManager::Initialize {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "Initialize"}
06/12/2020 13:55:01.824	OFFICECL (0x236c)	0x2380		Click-To-Run	bduv7	Medium	ConfigurationManager::PopulateInitialConfigurationSettings {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "Populating initial configuration settings"}
06/12/2020 13:55:01.824	OFFICECL (0x236c)	0x2380		Activity	bjtct	Medium	ActivityStarted {"Name": "Office.ClickToRun.DisableVirtualizationSettingForC2RHive", "CV": "NpNljPoL4keFzW32Lx7D6A.4", "ProcessIdentifier": "OfficeClickToRun.exe_16.0.10361.20002_X86_{8C659336-0BFA-47E2-85CD-6DF62F1EC3E8}"}
06/12/2020 13:55:01.824	OFFICECL (0x236c)	0x2380		Activity	bjtcw	Medium	ActivityEnded {"Name": "Office.ClickToRun.DisableVirtualizationSettingForC2RHive", "CV": "NpNljPoL4keFzW32Lx7D6A.4", "ProcessIdentifier": "OfficeClickToRun.exe_16.0.10361.20002_X86_{8C659336-0BFA-47E2-85CD-6DF62F1EC3E8}"}
06/12/2020 13:55:01.824	OFFICECL (0x236c)	0x2380		Click-To-Run	annto	Medium	ApiServer::Initialize - Initializing ApiServer for endpoint: C2RClientAPI_Server_Elevated16
06/12/2020 13:55:01.824	OFFICECL (0x236c)	0x2380		Click-To-Run	annty	Medium	ExecutionContext::QueueScenario - Set executing scenario to INSTALL
06/12/2020 13:55:01.824	OFFICECL (0x236c)	0x2380		Click-To-Run	annuz	Medium	TaskFactory::TryLoadScenario - Start loading INSTALL scenario
06/12/2020 13:55:01.824	OFFICECL (0x236c)	0x584		Click-To-Run General Telemetry	blyso	Medium	LogWatcher::ManageLogsInDirectory {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "{'NumFiles':'14','DeletesAttempted':'0','FilesDeleted':'0','FilesDeleteSizeInMB':'0'}"}
06/12/2020 13:55:01.824	OFFICECL (0x236c)	0x2380		Click-To-Run	annu0	Medium	TaskFactory::TryLoadScenario - Loading INSTALL scenario is successful
06/12/2020 13:55:01.824	OFFICECL (0x236c)	0x2380		Click-To-Run	axiks	Medium	TaskScenario::TryInitializeScenarioSettings - ScenarioInstanceId = 3DDFB479-DA93-4757-B895-417E2C1A4E06
06/12/2020 13:55:01.824	OFFICECL (0x236c)	0x2380		Click-To-Run	arqkd	Medium	ScenarioController::Initialize - requested display level:
06/12/2020 13:55:01.824	OFFICECL (0x236c)	0x2380		Click-To-Run	aqvp3	Monitorable	UIWeight is 0, task progress wont affect overall progress.
06/12/2020 13:55:01.840	OFFICECL (0x236c)	0x2380		Click-To-Run	aqvp3	Monitorable	UIWeight is 0, task progress wont affect overall progress.
06/12/2020 13:55:01.840	OFFICECL (0x236c)	0x2380		Click-To-Run	annua	Medium	ProcessPool::QueueTaskItem - Task SCENARIO:{FB9843BB-0D8A-4347-A227-C759C3FC9103} is being scheduled to run in this process
06/12/2020 13:55:01.840	OFFICECL (0x236c)	0x2380		Click-To-Run	aoicd	Medium	ExecutionContext::QueueScenario - Successfully queue scenario INSTALL.
06/12/2020 13:55:01.840	OFFICECL (0x236c)	0x2380		Click-To-Run	apfr3	Medium	ExecutionContext::TryWaitOnExecutingScenarioCompletionOrCustomEvent - Waiting for scenario completion event.
06/12/2020 13:55:01.840	OFFICECL (0x236c)	0x1ce4		Click-To-Run	annua	Medium	ProcessPool::QueueTaskItem - Task PROMPTUSER:{0468216F-0C80-4620-AA53-3F53A84CDFC4} is being scheduled to run in this process
06/12/2020 13:55:01.840	OFFICECL (0x236c)	0x1ce4		Click-To-Run	annvj	Medium	Worker::TaskExecutionThreadProc - Task SCENARIO:{FB9843BB-0D8A-4347-A227-C759C3FC9103} completed with TaskState TASKSTATE_EXECUTING.
06/12/2020 13:55:01.840	OFFICECL (0x236c)	0x1ce4		Click-To-Run	annu6	Medium	TaskGroup::DoHandleWorkerCompleteEvent - Task {FB9843BB-0D8A-4347-A227-C759C3FC9103} complete event is handled by task {FB9843BB-0D8A-4347-A227-C759C3FC9103}
06/12/2020 13:55:01.840	OFFICECL (0x236c)	0x23ac		Activity	bjtct	Medium	ActivityStarted {"Name": "Office.ClickToRun.Scenario.InstallTaskPromptuser", "CV": "NpNljPoL4keFzW32Lx7D6A.5", "ProcessIdentifier": "OfficeClickToRun.exe_16.0.10361.20002_X86_{8C659336-0BFA-47E2-85CD-6DF62F1EC3E8}"}
06/12/2020 13:55:01.840	OFFICECL (0x236c)	0x23ac		Click-To-Run Task Telemetry	aqvpf	Medium	Task::Execute {"ScenarioInstanceId": "3DDFB479-DA93-4757-B895-417E2C1A4E06", "TaskId": "0468216F-0C80-4620-AA53-3F53A84CDFC4", "TaskType": "PROMPTUSER:{0468216F-0C80-4620-AA53-3F53A84CDFC4}", "TaskState": 1, "Scenario": "INSTALL", "InstallID": "6ED626A4-A873-4B64-94C2-15BF67F34A63", "ScenarioSubType": "ARP", "SourceType": "None", "MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "Starting task {'Attempt':'1'}"}
06/12/2020 13:55:01.840	OFFICECL (0x236c)	0x23ac		Click-To-Run	aonzl	Medium	TaskPromptUser::Execute - task started.
06/12/2020 13:55:01.840	OFFICECL (0x236c)	0x23ac		Click-To-Run	arqke	Medium	UI is suppressed - prompt should not show.
06/12/2020 13:55:01.840	OFFICECL (0x236c)	0x23ac		Click-To-Run General Telemetry	a4fry	Medium	ScenarioSettings::SetConditionValue {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "PromptAnswer=Continue"}
06/12/2020 13:55:01.840	OFFICECL (0x236c)	0x23ac		Click-To-Run	annvj	Medium	Worker::TaskExecutionThreadProc - Task PROMPTUSER:{0468216F-0C80-4620-AA53-3F53A84CDFC4} completed with TaskState TASKSTATE_COMPLETED.
06/12/2020 13:55:01.840	OFFICECL (0x236c)	0x23ac		Click-To-Run	apm4b	Medium	Task::DoHandleWorkerCompleteEvent - Setting Task (0468216F-0C80-4620-AA53-3F53A84CDFC4) Task State to (TASKSTATE_COMPLETED)
06/12/2020 13:55:01.840	OFFICECL (0x236c)	0x23ac		Click-To-Run Task Telemetry	annux	Medium	Task::DoHandleWorkerSuccessEvent {"ScenarioInstanceId": "3DDFB479-DA93-4757-B895-417E2C1A4E06", "TaskId": "0468216F-0C80-4620-AA53-3F53A84CDFC4", "TaskType": "PROMPTUSER:{0468216F-0C80-4620-AA53-3F53A84CDFC4}", "TaskState": 6, "Scenario": "INSTALL", "InstallID": "6ED626A4-A873-4B64-94C2-15BF67F34A63", "ScenarioSubType": "ARP", "SourceType": "None", "MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "Task execution complete {'Attempt':'1'}"}
06/12/2020 13:55:01.840	OFFICECL (0x236c)	0x23ac		Click-To-Run	aqvqm	Medium	ScenarioController::UpdateScenarioProgress - {0468216F-0C80-4620-AA53-3F53A84CDFC4}=100
06/12/2020 13:55:01.840	OFFICECL (0x236c)	0x23ac		Click-To-Run	apm4d	Medium	Task::HandleTaskStateCompleted - Handling TaskState (TASKSTATE_COMPLETED) for task (0468216F-0C80-4620-AA53-3F53A84CDFC4)
06/12/2020 13:55:01.840	OFFICECL (0x236c)	0x23ac		Click-To-Run	annu6	Medium	TaskGroup::DoHandleWorkerCompleteEvent - Task {0468216F-0C80-4620-AA53-3F53A84CDFC4} complete event is handled by task {FB9843BB-0D8A-4347-A227-C759C3FC9103}
06/12/2020 13:55:01.840	OFFICECL (0x236c)	0x23ac		Click-To-Run	annu9	Medium	TaskGroup::HandleTaskStateCompleted - Found task {{DF3BBBD9-F521-43BA-BE89-8749E5F80983}}, queue for execution.
06/12/2020 13:55:01.840	OFFICECL (0x236c)	0x23ac		Click-To-Run	annua	Medium	ProcessPool::QueueTaskItem - Task SCENARIO:{FB9843BB-0D8A-4347-A227-C759C3FC9103} is being scheduled to run in this process
06/12/2020 13:55:01.840	OFFICECL (0x236c)	0x23ac		Activity	bjtcw	Medium	ActivityEnded {"Name": "Office.ClickToRun.Scenario.InstallTaskPromptuser", "CV": "NpNljPoL4keFzW32Lx7D6A.5", "ProcessIdentifier": "OfficeClickToRun.exe_16.0.10361.20002_X86_{8C659336-0BFA-47E2-85CD-6DF62F1EC3E8}"}
06/12/2020 13:55:01.840	OFFICECL (0x236c)	0x23b4		Click-To-Run	annua	Medium	ProcessPool::QueueTaskItem - Task BRANCH:{DF3BBBD9-F521-43BA-BE89-8749E5F80983} is being scheduled to run in this process
06/12/2020 13:55:01.840	OFFICECL (0x236c)	0x23b4		Click-To-Run	annvj	Medium	Worker::TaskExecutionThreadProc - Task SCENARIO:{FB9843BB-0D8A-4347-A227-C759C3FC9103} completed with TaskState TASKSTATE_EXECUTING.
06/12/2020 13:55:01.840	OFFICECL (0x236c)	0x23b4		Click-To-Run	annu6	Medium	TaskGroup::DoHandleWorkerCompleteEvent - Task {FB9843BB-0D8A-4347-A227-C759C3FC9103} complete event is handled by task {FB9843BB-0D8A-4347-A227-C759C3FC9103}
06/12/2020 13:55:01.840	OFFICECL (0x236c)	0x23b0		Click-To-Run	aozsl	Medium	TaskBranch::DoExecute - Found task {8D3B8D3F-A1B6-4149-8187-5530518A3849} that matches {Continue} condition.
06/12/2020 13:55:01.840	OFFICECL (0x236c)	0x23b0		Click-To-Run	annua	Medium	ProcessPool::QueueTaskItem - Task GROUP:{8D3B8D3F-A1B6-4149-8187-5530518A3849} is being scheduled to run in this process
06/12/2020 13:55:01.840	OFFICECL (0x236c)	0x23b0		Click-To-Run	annvj	Medium	Worker::TaskExecutionThreadProc - Task BRANCH:{DF3BBBD9-F521-43BA-BE89-8749E5F80983} completed with TaskState TASKSTATE_EXECUTING.
06/12/2020 13:55:01.840	OFFICECL (0x236c)	0x23b0		Click-To-Run	aozsm	Medium	TaskBranch::DoHandleWorkerCompleteEvent - Task {DF3BBBD9-F521-43BA-BE89-8749E5F80983} success event is handled by task {DF3BBBD9-F521-43BA-BE89-8749E5F80983}
06/12/2020 13:55:01.840	OFFICECL (0x236c)	0x23b8		Click-To-Run	ba8gm	Medium	SystemProcessPool::EnsureServiceProcess - ClickToRunSvc service is running.
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x23b8		Click-To-Run Non Task Error	apozb	Unexpected	SystemProcessPool::DoEnsureProcess {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ErrorCode": 0, "ErrorType": "", "AppVErrorSource": "", "ErrorMessage": "", "ErrorDetails": "", "ContextData": "Service started, but RPC endpoint failed to respond."}
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x23b8		Click-To-Run Non Task Error	ap3jc	Unexpected	ProcessPool::QueueTaskItem {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ErrorCode": 1715, "ErrorType": "", "AppVErrorSource": "", "ErrorMessage": "", "ErrorDetails": "", "ContextData": "Unable to ensure process pool for task {'Task':'CONFIGURELIGHT:{363FEBED-07D2-4993-B860-5925C6FAF115}'}"}
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x23b8		Click-To-Run	as78i	Medium	ProcessPool::QueueTaskItem - Task CONFIGURELIGHT:{363FEBED-07D2-4993-B860-5925C6FAF115} can't be queued. Attempt to skip the task.
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x23b8		Click-To-Run	as78j	Medium	Task::DoSkip - Hibernating task (363FEBED-07D2-4993-B860-5925C6FAF115). It is currently in TASKSTATE_NOTSTARTED state
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x23b8		Click-To-Run	as78k	Medium	Task::DoSkip - Skipping task (363FEBED-07D2-4993-B860-5925C6FAF115). It is currently in TASKSTATE_HIBERNATED state
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x23b8		Click-To-Run	annvj	Medium	Worker::TaskExecutionThreadProc - Task GROUP:{8D3B8D3F-A1B6-4149-8187-5530518A3849} completed with TaskState TASKSTATE_FAILED.
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x23b8		Click-To-Run	annu6	Medium	TaskGroup::DoHandleWorkerCompleteEvent - Task {8D3B8D3F-A1B6-4149-8187-5530518A3849} complete event is handled by task {8D3B8D3F-A1B6-4149-8187-5530518A3849}
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x23b8		Click-To-Run	apm4p	Medium	TaskGroup::DoCancel - Attempting to cancel task {8D3B8D3F-A1B6-4149-8187-5530518A3849}
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x23b8		Click-To-Run	apm4a	Monitorable	Task::DoCancel - Can't cancel task (363FEBED-07D2-4993-B860-5925C6FAF115) because it is in TASKSTATE_FAILED state
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x23b8		Click-To-Run	apm39	Medium	Task::DoCancel - Task (4CCD26FB-A773-42FB-8E44-CD53798BC0E7) in TASKSTATE_NOTSTARTED, set to Cancelled.
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x23b8		Click-To-Run	apm39	Medium	Task::DoCancel - Task (732E717C-22C1-4023-816C-7BB33BB24EAD) in TASKSTATE_NOTSTARTED, set to Cancelled.
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x23b8		Click-To-Run	apm39	Medium	Task::DoCancel - Task (A42AC5D1-70F7-48E9-8A2D-0A9635A57862) in TASKSTATE_NOTSTARTED, set to Cancelled.
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x23b8		Click-To-Run	apm4p	Medium	TaskGroup::DoCancel - Attempting to cancel task {A94EA03C-786F-49B8-AED1-5F9D84881BF8}
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x23b8		Click-To-Run	apm4p	Medium	TaskGroup::DoCancel - Attempting to cancel task {2BE168FD-0ECB-46A9-8998-03B2B55B4DF8}
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x23b8		Click-To-Run	apm4p	Medium	TaskGroup::DoCancel - Attempting to cancel task {31DBF8A1-18DC-4A41-B76B-5BA9D3BFF2D8}
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x23b8		Click-To-Run	apm39	Medium	Task::DoCancel - Task (17492C85-D313-44A7-B3EB-CCFB4029E0CB) in TASKSTATE_NOTSTARTED, set to Cancelled.
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x23b8		Click-To-Run	apm39	Medium	Task::DoCancel - Task (D22F3964-0490-4BCB-AEA4-A9C353669022) in TASKSTATE_NOTSTARTED, set to Cancelled.
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x23b8		Click-To-Run	apm39	Medium	Task::DoCancel - Task (74E7FD58-81CE-46EA-9BDC-A8125C77CC1A) in TASKSTATE_NOTSTARTED, set to Cancelled.
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x23b8		Click-To-Run	apm39	Medium	Task::DoCancel - Task (CB3F6915-84A5-4A18-889C-FA9A42D0BCBD) in TASKSTATE_NOTSTARTED, set to Cancelled.
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x23b8		Click-To-Run	apm39	Medium	Task::DoCancel - Task (FD07C30B-1348-43B9-B3F5-8476537C77CB) in TASKSTATE_NOTSTARTED, set to Cancelled.
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x23b8		Click-To-Run	apm4o	Medium	TaskGroup::Finalize - Finalizing task 31DBF8A1-18DC-4A41-B76B-5BA9D3BFF2D8.
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x23b8		Click-To-Run	apm39	Medium	Task::DoCancel - Task (61C08BFC-BFF7-49B5-897B-568FFE11F170) in TASKSTATE_NOTSTARTED, set to Cancelled.
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x23b8		Click-To-Run	apm4p	Medium	TaskGroup::DoCancel - Attempting to cancel task {6E052C8E-62F7-45D3-B864-40191450EFD6}
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x23b8		Click-To-Run	apm39	Medium	Task::DoCancel - Task (50463D7B-18BA-4CCF-A839-9D2C8639F50D) in TASKSTATE_NOTSTARTED, set to Cancelled.
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x23b8		Click-To-Run	apm4o	Medium	TaskGroup::Finalize - Finalizing task 6E052C8E-62F7-45D3-B864-40191450EFD6.
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x23b8		Click-To-Run	apm4o	Medium	TaskGroup::Finalize - Finalizing task 2BE168FD-0ECB-46A9-8998-03B2B55B4DF8.
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x23b8		Click-To-Run	apm4o	Medium	TaskGroup::Finalize - Finalizing task A94EA03C-786F-49B8-AED1-5F9D84881BF8.
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x23b8		Click-To-Run	apm4p	Medium	TaskGroup::DoCancel - Attempting to cancel task {C4E145E2-BFAD-4497-AB47-C92314E7E0A3}
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x23b8		Click-To-Run	apm39	Medium	Task::DoCancel - Task (F2A2F522-FCCE-4913-9C0D-C6FEB25CC298) in TASKSTATE_NOTSTARTED, set to Cancelled.
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x23b8		Click-To-Run	apm39	Medium	Task::DoCancel - Task (D7E11AA1-F6BD-4101-B7F4-AECA50B0030F) in TASKSTATE_NOTSTARTED, set to Cancelled.
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x23b8		Click-To-Run	apm4o	Medium	TaskGroup::Finalize - Finalizing task C4E145E2-BFAD-4497-AB47-C92314E7E0A3.
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x23b8		Click-To-Run	apm4o	Medium	TaskGroup::Finalize - Finalizing task 8D3B8D3F-A1B6-4149-8187-5530518A3849.
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x23b8		Click-To-Run	aozsm	Medium	TaskBranch::DoHandleWorkerCompleteEvent - Task {8D3B8D3F-A1B6-4149-8187-5530518A3849} success event is handled by task {DF3BBBD9-F521-43BA-BE89-8749E5F80983}
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x23b8		Click-To-Run	annu6	Medium	TaskGroup::DoHandleWorkerCompleteEvent - Task {DF3BBBD9-F521-43BA-BE89-8749E5F80983} complete event is handled by task {FB9843BB-0D8A-4347-A227-C759C3FC9103}
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x23b8		Click-To-Run	apm4p	Medium	TaskGroup::DoCancel - Attempting to cancel task {FB9843BB-0D8A-4347-A227-C759C3FC9103}
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x23b8		Click-To-Run	apm4a	Monitorable	Task::DoCancel - Can't cancel task (0468216F-0C80-4620-AA53-3F53A84CDFC4) because it is in TASKSTATE_COMPLETED state
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x23b8		Click-To-Run	apm4q	Monitorable	TaskGroup::DoCancel - Can't cancel task {DF3BBBD9-F521-43BA-BE89-8749E5F80983} because it is in TASKSTATE_FAILED state
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x23b8		Click-To-Run	apm4o	Medium	TaskGroup::Finalize - Finalizing task FB9843BB-0D8A-4347-A227-C759C3FC9103.
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x2380		Click-To-Run	apfr5	Medium	ExecutionContext::TryWaitOnExecutingScenarioCompletionOrCustomEvent - Failure event set.
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x2380		Click-To-Run	ap11d	Medium	StandaloneStartupBehavior::Start - Exit with error code 17002
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x2380		Click-To-Run	ap3jf	Medium	ProcessPool::Shutdown - Shutting down process pool.
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x23b8		Click-To-Run	annt0	Medium	ExecutionContext::ResetExecutingScenario - Reset executing scenario
06/12/2020 13:55:32.751	OFFICECL (0x236c)	0x2380		Click-To-Run	aqtpj	Medium	Main: returned: 17002
Timestamp	Process	TID	Area	Category	EventID	Level	Message	Correlation
06/12/2020 13:58:10.360	OFFICEC2 (0x1794)	0x1350		Telemetry Rules Engine	b0on0	Medium	initAudienceMetadata.enter
06/12/2020 13:58:10.360	OFFICEC2 (0x1794)	0x1350		Telemetry Rules Engine	b0on1	Medium	initAudienceMetadata.exit
06/12/2020 13:58:10.360	OFFICEC2 (0x1794)	0x1350		Identity Http Client	axidp	Medium	[HttpWin_Async] open {"Message": "Http open request.", "RequestId": "1", "RequestMethod": "GET", "Url": "https://nexusrules.officeapps.live.com/nexus/rules?Application=officec2rclient.exe&Version=16.0.10361.20002&ClientId={8AF96F56-67BA-4973-9897-4E084C4279A1}&OSEnvironment=10&MsoAppId=37&AudienceName=Production_LTSC&AudienceGroup=Production&AppVersion=16.0.10361.20002&", "IsAsync": false}
06/12/2020 13:58:10.360	OFFICEC2 (0x1794)	0x1350		Identity Http Client	bb9ek	Medium	[CWinHttpHelperBase] AutomaticProxyConfiguration {"Message": "InitSession detected proxy auto detect."}
06/12/2020 13:58:10.376	OFFICEC2 (0x1794)	0x1ec0		Click-To-Run General Telemetry	aqkhc	Medium	InitLogging {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "0.0.0.0", "C2RClientVer": "0.0", "ContextData": "{\"AppVVersion\":\"5.1.141\",\"Bitness\":\"64\",\"CommandLine\":\"/frequentupdate SCHEDULEDTASK displaylevel=False\",\"ExeVer\":\"16.0.10361.20002\",\"IntegrityLevel\":\"0x4000\",\"Locale\":\"1036\",\"ModulePath\":\"C:\\\\Program Files\\\\Common Files\\\\Microsoft Shared\\\\ClickToRun\\\\OfficeC2RClient.exe\",\"OSVersion\":\"10.0\",\"ProcessType\":\"OfficeC2RClient\",\"ProcessorArch\":\"9\",\"ProductType\":\"1\",\"SecuritySessionId\":\"0\"}"}
06/12/2020 13:58:10.376	OFFICEC2 (0x1794)	0x1ec0		Activity	bjtct	Medium	ActivityStarted {"Name": "Office.ClickToRun.C2RClient", "CV": "/dIJYvmpGEqKZZn0A6tWlA.6", "ProcessIdentifier": "OfficeC2RClient.exe_16.0.10361.20002_X86_{6209D2FD-A9F9-4A18-8A65-99F403AB5694}"}
06/12/2020 13:58:11.522	OFFICEC2 (0x1794)	0x1350		Activity	bjtct	Medium	ActivityStarted {"Name": "Office.Telemetry.LoadXmlRules", "CV": "/dIJYvmpGEqKZZn0A6tWlA.5.1", "ProcessIdentifier": "OfficeC2RClient.exe_16.0.10361.20002_X86_{6209D2FD-A9F9-4A18-8A65-99F403AB5694}"}
06/12/2020 13:58:11.522	OFFICEC2 (0x1794)	0x1350		Activity	bjtcw	Medium	ActivityEnded {"Name": "Office.Telemetry.LoadXmlRules", "CV": "/dIJYvmpGEqKZZn0A6tWlA.5.1", "ProcessIdentifier": "OfficeC2RClient.exe_16.0.10361.20002_X86_{6209D2FD-A9F9-4A18-8A65-99F403AB5694}"}
06/12/2020 13:58:11.522	OFFICEC2 (0x1794)	0x1350		Activity	bjtcw	Medium	ActivityEnded {"Name": "Office.Telemetry.ProcessIdleQueueJob", "CV": "/dIJYvmpGEqKZZn0A6tWlA.5", "ProcessIdentifier": "OfficeC2RClient.exe_16.0.10361.20002_X86_{6209D2FD-A9F9-4A18-8A65-99F403AB5694}"}
06/12/2020 13:58:25.369	OFFICEC2 (0x1794)	0x1ec0		Click-To-Run General Telemetry	bhltg	Medium	Core::GetFlightData {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "0.0.0.0", "C2RClientVer": "0.0", "ContextData": "{'flightIdentifier':'Microsoft.Office.Click2Run.UseExperimentalTransportForInPlacePipe','overrideValue':'','flightData':'','returnValue':'unknown'}"}
06/12/2020 13:58:25.369	OFFICEC2 (0x1794)	0x1ec0		Click-To-Run General Telemetry	bhltg	Medium	Core::GetFlightData {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "0.0.0.0", "C2RClientVer": "0.0", "ContextData": "{'flightIdentifier':'Microsoft.Office.Click2Run.UseOfficeHelperAddon','overrideValue':'','flightData':'','returnValue':'unknown'}"}
06/12/2020 13:58:25.369	OFFICEC2 (0x1794)	0x1ec0		Click-To-Run General Telemetry	bhltg	Medium	Core::GetFlightData {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "0.0.0.0", "C2RClientVer": "0.0", "ContextData": "{'flightIdentifier':'Microsoft.Office.Click2Run.UseOutlookShareAddon','overrideValue':'','flightData':'','returnValue':'unknown'}"}
06/12/2020 13:58:25.369	OFFICEC2 (0x1794)	0x1ec0		Click-To-Run General Telemetry	bhltg	Medium	Core::GetFlightData {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "0.0.0.0", "C2RClientVer": "0.0", "ContextData": "{'flightIdentifier':'Microsoft.Office.Click2Run.UseTeamsAddon','overrideValue':'','flightData':'','returnValue':'unknown'}"}
06/12/2020 13:58:25.369	OFFICEC2 (0x1794)	0x1ec0		Activity	bjtct	Medium	ActivityStarted {"Name": "Office.ClickToRun.C2RClient.DoFrequentUpdates.FrequentUpdates", "CV": "/dIJYvmpGEqKZZn0A6tWlA.6.1", "ProcessIdentifier": "OfficeC2RClient.exe_16.0.10361.20002_X86_{6209D2FD-A9F9-4A18-8A65-99F403AB5694}"}
06/12/2020 13:58:25.369	OFFICEC2 (0x1794)	0x1ec0		Click-To-Run	cfbm2	Medium	DoFrequentUpdates {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "{\"message\":\"Running frequent updates\",\"hours\":\"24\"}"}
06/12/2020 13:58:40.357	OFFICEC2 (0x1794)	0x1ec0		Click-To-Run General Telemetry	bhltg	Medium	Core::GetFlightData {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "{'flightIdentifier':'Microsoft.Office.Click2Run.UseExperimentalTransportForInPlacePipe','overrideValue':'','flightData':'','returnValue':'unknown'}"}
06/12/2020 13:58:40.357	OFFICEC2 (0x1794)	0x1ec0		Click-To-Run General Telemetry	bhltg	Medium	Core::GetFlightData {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "{'flightIdentifier':'Microsoft.Office.Click2Run.UseOfficeHelperAddon','overrideValue':'','flightData':'','returnValue':'unknown'}"}
06/12/2020 13:58:40.357	OFFICEC2 (0x1794)	0x1ec0		Click-To-Run General Telemetry	bhltg	Medium	Core::GetFlightData {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "{'flightIdentifier':'Microsoft.Office.Click2Run.UseOutlookShareAddon','overrideValue':'','flightData':'','returnValue':'unknown'}"}
06/12/2020 13:58:40.357	OFFICEC2 (0x1794)	0x1ec0		Click-To-Run General Telemetry	bhltg	Medium	Core::GetFlightData {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "{'flightIdentifier':'Microsoft.Office.Click2Run.UseTeamsAddon','overrideValue':'','flightData':'','returnValue':'unknown'}"}
06/12/2020 13:58:40.357	OFFICEC2 (0x1794)	0x1ec0		Click-To-Run General Telemetry	a4htr	Medium	::DoUpdates {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "Triggering an update: {'Parameters':'displaylevel=False flt.useexptransportinplacepl=unknown flt.useofficehelperaddon=unknown flt.useoutlookshareaddon=unknown flt.useteamsaddon=unknown flt.usedms=true flt.dmsapiversion=2 flt.dmsapiuri=https://mrodevicemgr.officeapps.live.com/mrodevicemgrsvc/api flt.dmsrequestattemptlimit=3 flt.dmsshouldallowtargetaudiencemove=false triggersource=SCHEDULEDTASK'}"}
06/12/2020 13:58:40.841	OFFICEC2 (0x1794)	0x1ec0		Click-To-Run General Telemetry	bon04	Medium	ReportMachineKey {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "{\"MachineKey\":\"NotFound\",\"Platform\":\"x86\",\"AppVVersion\":\"5.1.141\",\"DotNetVersions\":\"4.8.03752,3.5.30729.4926,3.0.30729.4926,2.0.50727.4927\"}"}
06/12/2020 13:58:40.841	OFFICEC2 (0x1794)	0x1ec0		Activity	bjtcw	Medium	ActivityEnded {"Name": "Office.ClickToRun.C2RClient.DoFrequentUpdates.FrequentUpdates", "CV": "/dIJYvmpGEqKZZn0A6tWlA.6.1", "ProcessIdentifier": "OfficeC2RClient.exe_16.0.10361.20002_X86_{6209D2FD-A9F9-4A18-8A65-99F403AB5694}"}
06/12/2020 13:58:40.841	OFFICEC2 (0x1794)	0x1ec0		Click-To-Run	azfea	Medium	::wWinMain {"MachineId": "046b3a244b4d1c4cb2bc3b1b26be0dac", "SessionID": "e910b480-83ed-4d5b-9acc-8613870d816b", "GeoID": 84, "Ver": "16.0.10361.20002", "C2RClientVer": "16.0.10361.20002", "ContextData": "ClientExe complete. {'Action':'20','Result':'0'}"}
06/12/2020 13:58:40.841	OFFICEC2 (0x1794)	0x1ec0		Activity	bjtcw	Medium	ActivityEnded {"Name": "Office.ClickToRun.C2RClient", "CV": "/dIJYvmpGEqKZZn0A6tWlA.6", "ProcessIdentifier": "OfficeC2RClient.exe_16.0.10361.20002_X86_{6209D2FD-A9F9-4A18-8A65-99F403AB5694}"}
lfkl
Registration: Apr 11, 2019 - 05:51
June 19, 2020 - 06:31
After struggling a lot, I applied another method that works and I'm sharing it here.
1) Create an .XML file named uninstall-all.xml
<Configuration>
    <!--Uninstall complete Office-->
    <Display Level="None" AcceptEULA="TRUE" />
    <Logging Level="Standard" Path="%temp%" />
    <Remove All="TRUE" />
</Configuration>
2) Copy "uninstall-all.xml" and "setup.exe" into a folder named "uninstall"
3) Modify the PY script to copy the files contained in the "uninstall" folder into the Office 2019 directory
4) Modification of the PY script on def uninstall(): in order to launch setup.exe applying the parameters from the XML.
Everything works.
Below is the final script:
# Empty package, you have to include offline downloaded files
# You can use the following tool to help creating Configuration.xml and download necessary files :
# https://github.com/YerongAI/Office-Tool
# You should also check for the uninstall string for uninstall_args by using : wapt-get list-registry Office
# raccourcis
RaccourcisDossierProgramm1 = makepath(programfiles32,"Microsoft Office","root","Office16")
softname = "Microsoft Office Professional Plus 2019 - fr-fr"
pgmsoffice = programfiles
uninstall_args = r'scenario=install scenariosubtype=ARP sourcetype=None productstoremove=ProPlus2019Volume.16_fr-fr_x-none culture=fr-fr version.16=16.0 DisplayLevel=False'
kill_list = ['winword.exe','powerpnt.exe','excel.exe','mspub.exe','msaccess.exe','infopath.exe','lync.exe','onenote.exe','outlook.exe','onenotem.exe','msosync.exe','groove.exe','OfficeClicktoRun.exe']
    print('installing %s'.format(control.asrequirement()))
    office_installed = installed_softwares(softname)
    cmd = '"setup.exe" /configure "configuration-eleves.xml"'
    if not office_installed:
        print('Installing {}'.format(softname))
        if Version(office_installed[0]['version']) < Version(control.version.split('-',1)[0]):
            print('{} already up to date or newer : {}'.format(softname,office_installed[0]['version']))
        error(' {} has been installed but the uninstall key can not be found'.format(softname))
    print('Copie des fichiers de desinstallation uninstall-all.XML et setup.exe')
    copytree2(r"uninstall",(RaccourcisDossierProgramm1))
    print('Removing {}'.format(softname))
    for soft in kill_list:
        killalltasks(soft)
    uninstallcmd = r'"C:\Program Files (x86)\Microsoft Office\root\Office16\setup.exe" /configure "C:\Program Files (x86)\Microsoft Office\root\Office16\uninstall-all.xml"'
    print('desinstallation de Microsoft Office')
    run(uninstallcmd,timeout=1800,accept_returncodes=[1641,3010,0])
    print('fin de uninstall')
lfkl
June 19, 2020 - 06:33
Title change resolved! :)
Gaelds
Registration: Nov 22, 2015 - 08:37
November 6, 2020 - 11:53
I was inspired by your office2019 package but the installation does not work via the wapt package.
> viewtopic.php?f=9&t=2583
I want to install Office from a source on the network, but it doesn't work when setup.exe and XML are on the local disk.
<Configuration>
  <Add OfficeClientEdition="64" Channel="PerpetualVL2019" SourcePath="\\172.16.10.3\Logiciels\Office2019\" AllowCdnFallback="TRUE">
    <Product ID="ProPlus2019Volume" PIDKEY="XXXXXXX">
      <Language ID="fr-fr" />
      <ExcludeApp ID="OneDrive" />
      <ExcludeApp ID="Outlook" />
    </Product>
    <Product ID="LanguagePack">
    </Product>
    <Product ID="ProofingTools">
	  <Language ID="de-de" />
      <Language ID="en-us" />
	  <Language ID="es-ES" />
    </Product>
  </Add>
  <Property Name="SharedComputerLicensing" Value="0" />
  <Property Name="PinIconsToTaskbar" Value="FALSE" />
  <Property Name="SCLCacheOverride" Value="0" />
  <Property Name="AUTOACTIVATE" Value="1" />
  <Property Name="FORCEAPPSHUTDOWN" Value="TRUE" />
  <Property Name="DeviceBasedLicensing" Value="0" />
  <Updates Enabled="TRUE" UpdatePath="\\172.16.10.3\Logiciels\Office2019\Updates\" />
  <AppSettings>
    <Setup Name="Company" Value="DOM SORTAIS" />
    <User Key="software\microsoft\office\16.0\common\toolbars" Name="screentipscheme" Value="2" Type="REG_DWORD" App="office16" Id="L_ShowScreenTips" />
    <User Key="software\microsoft\office\16.0\excel\options" Name="defaultformat" Value="51" Type="REG_DWORD" App="excel16" Id="L_SaveExcelfilesas" />
    <User Key="software\microsoft\office\16.0\powerpoint\options" Name="defaultformat" Value="27" Type="REG_DWORD" App="ppt16" Id="L_SavePowerPointfilesas" />
    <User Key="software\microsoft\office\16.0\word\options" Name="defaultformat" Value="" Type="REG_SZ" App="word16" Id="L_SaveWordfilesas" />
  </AppSettings>
  <Display Level="FULL" AcceptEULA="TRUE" />
  <Logging Level="Off" />
</Configuration>
November 6, 2020 - 12:04 PM
Please do not reuse thread views for new topics (even if they are related). This is called necroposting, and it's frowned upon because it makes forum management difficult. Thank you.
I'm closing this thread.
