Synchronization to remote repository
dsp
Registration: February 27, 2018 - 09:15
June 18, 2020 - 1:39 PM
I wanted to set up synchronization to a secondary repository; it works, but in the console my repository still shows as NO SYNC, even though the agent for my secondary repository correctly retrieves the packages
secondary repository.png (5.89 KB) Viewed 5579 times
I don't know if this is related, but every time a package synchronizes, I get this type of error
Jun 18 13:16:38 wapt57 waptservice[25991]: errors: {u'wapt/icons/5ea1b401-dae2-494d-bb36-bdd93fb60691.png': "unsupported operand type(s) for -: 'str' and 'float'", u'wapt/Packages': "unsupported operand type(s) for -: 'str' and 'float'", u'wapt/ge-microsoft-edge_83.0.478.54-1_x64_fb255b2d8a131b3544cea99787fec5d8.wapt': "unsupported operand type(s) for -: 'str' and 'float'"}
Jun 18 13:16:38 wapt57 waptservice[25991]: success: False
I should point out that both the primary and secondary repositories are on Linux systems with fresh installs of version 1.8.2
WAPT version: 1.8.2
Server OS: Debian 10
Administration/package creation machine OS: Windows 10 1909
eblaudy
Registration: August 5, 2019 - 2:15 PM
June 18, 2020 - 3:53 PM
Hello again,
I found the problem while waiting for a new build; you can fix it manually on the secondary repository.
The following line needs to be replaced /opt/wapt/waptenterprise/repositories.py :
print('Downloaded in %f seconds.\n' % time.time()-self.start_time_download)
By :
print('Downloaded in %f seconds.\n' % (time.time()-self.start_time_download))
Can you then tell me if the status is correct in the console?
WAPT Developer at TRANQUIL IT
dsp
June 18, 2020 - 4:08 PM
Hello again,
I no longer have the error message in the logs, but the status remains unchanged.
WAPT version: 1.8.2
