Deploying a package containing a PowerShell script
Guillaume_ccfd
Registration: June 11, 2020 - 4:42 PM
June 23, 2020 - 1:05 PM
Having little experience in preparing packages other than MSI/EXE or MSU, I am stuck on deploying a few lines of PowerShell.
Here is my setup.py file:
    run_powershell(Get-NetIPInterface | where {$_.InterfaceAlias -eq "Wi-Fi"} | Set-NetIpInterface -InterfaceMetric 45)
    run_powershell(Get-NetIPInterface | where {$_.InterfaceAlias -match"Local"} | Set-NetIpInterface -InterfaceMetric 10)
    run_powershell(Get-NetIPInterface | where {$_.InterfaceAlias -match "Ethernet"} | Set-NetIpInterface -InterfaceMetric 10)
When I deploy the package to a machine, I get the following error:
  File "C:\Program Files (x86)\wapt\common.py", line 3807, in install_wapt
    setup = import_setup(setup_filename)
  File "C:\Program Files (x86)\wapt\waptutils.py", line 1383, in import_setup
    py_mod = imp.load_source(modulename, setupfilename.encode(sys.getfilesystemencoding()))
  File "c:\windows\temp\wapt_p5e60\setup.py", line 6
SyntaxError: invalid syntax
SyntaxError: invalid syntax (setup.py, line 6)
Do you have any idea where the problem might be coming from?
Do you have any example files containing PowerShell scripts?
Thank you in advance!
June 23, 2020 - 1:45 PM
Like this?
    run_powershell('Get-NetIPInterface | where {$_.InterfaceAlias -eq "Wi-Fi"} | Set-NetIpInterface -InterfaceMetric 45')
    run_powershell('Get-NetIPInterface | where {$_.InterfaceAlias -match"Local"} | Set-NetIpInterface -InterfaceMetric 10')
    run_powershell('Get-NetIPInterface | where {$_.InterfaceAlias -match "Ethernet"} | Set-NetIpInterface -InterfaceMetric 10')
Guillaume_ccfd
June 23, 2020 - 5:09 PM
Thank you so much!
Indeed, the dimensions needed to be included!
In any case, it's a pleasure to be working on WAPT again. ;)
