Uninstalling Agent 1.8.2 for Mac OSX
MisterP
Registration: May 28, 2020 - 12:10
June 25, 2020 - 12:34
Hello everyone,
I'm currently having trouble uninstalling the agent on macOS.
The following command:
`sudo pkgutil --forget com.tranquilit.tis-waptagent-enterprise`
returns: `
No receipt for 'com.tranquilit.tis-waptagent-entreprise' at '/'.
Agent version 1.8.2
OS: Mac OS X 10.15`.
June 25, 2020 - 4:17 PM
What do you get if you run the following command line?
pkgutil --packages |  grep wapt
That said, the installed files/directories are very localized:
/opt/wapt/
/Applications/Wapt*
1 fichier launcher
One other question: why the need to uninstall it? Does it cause any problems?
MisterP
July 1, 2020 - 2:46 PM
Thank you for your reply, it works perfectly by deleting the two directories.
