I have the WAPT management console on a Windows 10 machine and it works.
I changed the hard drive, installed Windows 10 v2004, and now I can't get the console to work with the .crt and .pem keys.
I put the old hard drive back in and the console works.
I've read the documentation, but nothing works.
Is there a solution?
Yann
Management console installation error
- WAPT Expert
I don't have a key problem with Windows 10 v2004.
The problem lies elsewhere.
- WAPT Expert
Good evening Yann,
what exactly isn't working? Is it opening the console, configuring the local keys, assigning a package to a workstation, etc.?
Which version of WAPT are you using?
when I open the administration console on a Windows machine, I get a key or password error. I think I'm not putting the .crt and .pem keys in the right places. In my previous installation, the PEM key was in C:\private and the .crt key was in \issl. The password is OK.
I reinstalled the administration console, but it doesn't uninstall everything because it keeps the settings from the previous installation.
The server (version 1.81) works fine; I manage it with the console from the old disk, which is working.
I installed the administration console on another machine, and I get the same key/password error. Where should I put the private PEM key and the public .crt key?
Yann
Yann
