[SOLVED] Edt Package v2022 build 0.3.0 / Pronote v2022 build 0.3.0
Mich
Registration: Sep 3, 2019 - 5:09 p.m.
September 3, 2019 - 5:13 PM
Thank you so much for this package, it will be very helpful.
However, I have a question: do you update the package with each new sub-version (for example, your package is at version 0.2.1 and version 0.2.2 is currently available), or does the Pronote client update automatically and you only deploy one version per school year?
Thank you in advance for your reply.
Sincerely
- Installed WAPT version: 1.8.1.6756 Community Edition
- Server OS: Linux / Debian Stretch
olaplanche
Registration: January 26, 2017 - 11:11
September 20, 2019 - 4:35 PM
Hi,
sorry for the late reply, back-to-school rush, didn't get a notification for your post?! Anyway...
Personally, I only deploy the new version via Wapt at the beginning of the school year; after that, the update happens automatically on the user's computer without requiring administrator rights!
Good luck!
- Installed WAPT version: 2.6.0.16795 Enterprise
- Server OS: Linux / Debian Bookworm
olaplanche
July 8, 2020 - 4:46 PM
Hello! Here's the code for the 2020 versions ;)
:!: Remember to replace SERVERNAME and SERVERPORT with your values :!:
This time I chose not to uninstall the previous version from the 2020 version setup, since uninstallation works correctly with the 2019 packages. Therefore, both versions can be installed side-by-side!
EDT 2020 v0.1.1 x64:
    print('installing wapt-edt2020_x64')
    import tempfile
    import codecs
    pathinstallfile = makepath(tempfile.gettempdir(),'Setup.iss')
    data = ur"""[InstallShield Silent]
Version=v7.00
File=Response File
[File Transfer]
OverwrittenReadOnly=NoToAll
[{AA9AC92C-2AEE-4FD7-BED8-5CFF8D26C38E}-DlgOrder]
Dlg0={AA9AC92C-2AEE-4FD7-BED8-5CFF8D26C38E}-SdLicense2Rtf-0
Count=6
Dlg1={AA9AC92C-2AEE-4FD7-BED8-5CFF8D26C38E}-SdAskDestPath-0
Dlg2={AA9AC92C-2AEE-4FD7-BED8-5CFF8D26C38E}-AskOptions-0
Dlg3={AA9AC92C-2AEE-4FD7-BED8-5CFF8D26C38E}-AskOptions-1
Dlg4={AA9AC92C-2AEE-4FD7-BED8-5CFF8D26C38E}-AskOptions-2
Dlg5={AA9AC92C-2AEE-4FD7-BED8-5CFF8D26C38E}-SdFinish-0
[{AA9AC92C-2AEE-4FD7-BED8-5CFF8D26C38E}-SdLicense2Rtf-0]
Result=1
[{AA9AC92C-2AEE-4FD7-BED8-5CFF8D26C38E}-SdAskDestPath-0]
szDir=C:\Program Files\Index Education\EDT 2020\Réseau\Client
Result=1
[{AA9AC92C-2AEE-4FD7-BED8-5CFF8D26C38E}-AskOptions-0]
Result=1
Sel-0=0
[{AA9AC92C-2AEE-4FD7-BED8-5CFF8D26C38E}-AskOptions-1]
Result=1
Sel-0=1
Sel-1=0
Sel-2=0
Sel-3=0
[{AA9AC92C-2AEE-4FD7-BED8-5CFF8D26C38E}-AskOptions-2]
Result=1
Sel-0=0
[{AA9AC92C-2AEE-4FD7-BED8-5CFF8D26C38E}-SdFinish-0]
Result=1
bOpt1=0
bOpt2=0
    fichier = codecs.open(pathinstallfile, "w", encoding='mbcs')
    fichier.write(data)
    fichier.close()
    install_exe_if_needed("Install_EDTclient_FR_2020.0.1.1_win64.exe",silentflags='-s -f1%s' % pathinstallfile,key='{AA9AC92C-2AEE-4FD7-BED8-5CFF8D26C38E}',min_version='0.1.1',killbefore='Client EDT.exe')
    uninstallkey.remove('{AA9AC92C-2AEE-4FD7-BED8-5CFF8D26C38E}')
    create_desktop_shortcut(r'EDT2020',target=u'C:\Program Files\Index Education\EDT 2020\Réseau\Client\Client EDT.exe',arguments=r'-Adresse "SERVERNAME" -PortTcp "SERVERPORT"')
    print('uninstalling wapt-edt2020_x64')
    import tempfile
    pathuninstallfile = makepath(tempfile.gettempdir(),'Uninstall.iss')
Version=v7.00
File=Response File
[File Transfer]
Dlg0={AA9AC92C-2AEE-4FD7-BED8-5CFF8D26C38E}-MessageBox-0
Count=2
Dlg1={AA9AC92C-2AEE-4FD7-BED8-5CFF8D26C38E}-SdFinishReboot-0
[{AA9AC92C-2AEE-4FD7-BED8-5CFF8D26C38E}-MessageBox-0]
Result=6
[{AA9AC92C-2AEE-4FD7-BED8-5CFF8D26C38E}-SdFinishReboot-0]
Result=1
BootOption=0
    fichier = open(pathuninstallfile, "w")
    fichier.write(data)
    fichier.close()
    run(r'"%s\InstallShield Installation Information\{AA9AC92C-2AEE-4FD7-BED8-5CFF8D26C38E}\setup.exe" -s -uninst -f1%s' % (programfiles32,pathuninstallfile))
    remove_file(pathuninstallfile)
    remove_desktop_shortcut('EDT2020.lnk')
    run('"MsiExec.exe" /X{775E087D-A428-428C-A5FD-000010003000} /qn')
Pronote 2020 v0.1.1 x64:
    print('installing wapt-pronote2020_x64')
    import tempfile
    import codecs
Version=v7.00
File=Response File
[File Transfer]
[{52F13A9C-7815-4F65-BA5A-CC7E09191930}-DlgOrder]
Dlg0={52F13A9C-7815-4F65-BA5A-CC7E09191930}-SdLicense2Rtf-0
Count=6
Dlg1={52F13A9C-7815-4F65-BA5A-CC7E09191930}-SdAskDestPath-0
Dlg2={52F13A9C-7815-4F65-BA5A-CC7E09191930}-AskOptions-0
Dlg3={52F13A9C-7815-4F65-BA5A-CC7E09191930}-AskOptions-1
Dlg4={52F13A9C-7815-4F65-BA5A-CC7E09191930}-AskOptions-2
Dlg5={52F13A9C-7815-4F65-BA5A-CC7E09191930}-SdFinish-0
[{52F13A9C-7815-4F65-BA5A-CC7E09191930}-SdLicense2Rtf-0]
Result=1
[{52F13A9C-7815-4F65-BA5A-CC7E09191930}-SdAskDestPath-0]
szDir=C:\Program Files\Index Education\Pronote 2020\Réseau\Client
Result=1
[{52F13A9C-7815-4F65-BA5A-CC7E09191930}-AskOptions-0]
Result=1
Sel-0=0
[{52F13A9C-7815-4F65-BA5A-CC7E09191930}-AskOptions-1]
Result=1
Sel-0=1
Sel-1=0
Sel-2=0
Sel-3=0
[{52F13A9C-7815-4F65-BA5A-CC7E09191930}-AskOptions-2]
Result=1
Sel-0=0
[{52F13A9C-7815-4F65-BA5A-CC7E09191930}-SdFinish-0]
Result=1
bOpt1=0
bOpt2=0
    fichier.write(data)
    fichier.close()
    install_exe_if_needed("Install_PRNclient_FR_2020.0.1.1_win64.exe",silentflags='-s -f1%s' % pathinstallfile,key='{52F13A9C-7815-4F65-BA5A-CC7E09191930}',min_version='0.1.1',killbefore='Client PRONOTE.exe')
    uninstallkey.remove('{52F13A9C-7815-4F65-BA5A-CC7E09191930}')
    create_desktop_shortcut(r'Pronote2020',target=u'C:\Program Files\Index Education\Pronote 2020\Réseau\Client\Client PRONOTE.exe',arguments=r'-Adresse "SERVERNAME" -PortTcp "SERVERPORT"')
    print('uninstalling wapt-pronote2020_x64')
    import tempfile
Version=v7.00
File=Response File
[File Transfer]
Dlg0={52F13A9C-7815-4F65-BA5A-CC7E09191930}-MessageBox-0
Count=2
Dlg1={52F13A9C-7815-4F65-BA5A-CC7E09191930}-SdFinishReboot-0
[{52F13A9C-7815-4F65-BA5A-CC7E09191930}-MessageBox-0]
Result=6
[{52F13A9C-7815-4F65-BA5A-CC7E09191930}-SdFinishReboot-0]
Result=1
BootOption=0
    fichier.write(data)
    fichier.close()
    run(r'"%s\InstallShield Installation Information\{52F13A9C-7815-4F65-BA5A-CC7E09191930}\setup.exe" -s -uninst -f1%s' % (programfiles32,pathuninstallfile))
    remove_desktop_shortcut('Pronote2020.lnk')
Have a good holiday :mrgreen:
fredB
Registration: Nov. 30, 2020 - 12:16 p.m.
December 1, 2020 - 10:09 AM
thank you for sharing!
However, I can't use it because the Pronote client version available on the website is 0.2.4...
Could someone send me the complete package so I can modify it, or does anyone have the code adapted for the 2020 Pronote client version 0.2.4?
Thank you and have a good day.
olaplanche
December 1, 2020 - 1:50 PM
the code has been updated in the first post on page 1. ;)
fredB
December 1, 2020 - 3:54 PM
Thanks a lot !
joel.montelimard
Registration: August 29, 2017 - 10:48
January 4, 2021 - 12:24
Hello Olaplanche,
I'm not very comfortable creating packages... I've modified some before, but never created any.
I'm also interested in your Pronote package (version 0.2.5 if possible, as that's the current version) with the server configuration 0430113P.index-education.net.
And, to exaggerate a bit (!), where could I find a simple tutorial for creating this package (or any other package)? I have the code from page 1 and Pronote downloaded, but I don't know what to do with it.
Thanks in advance.
lemarec
Registration: January 25, 2021 - 6:53 PM
January 26, 2021 - 7:49 PM
Good evening.
Seems to work for version 0.2.5.
Have a good evening.
greening
Registration: December 20, 2018 - 2:45 PM
June 15, 2021 - 08:33
First, thank you for your work and for sharing this package.
I created a package with the preview version of EDT 2021, but I get an error message when I try to install it on machines with the latest 2020 version. I have no installation problems on machines without EDT pre-installed.
The error message is: returned non-zero exit status -2147213312.
Have you tested this preview version?
Do you have any idea what might be causing this error and how to resolve it?
Thank you in advance.
olaplanche
June 15, 2021 - 08:48
I haven't tested it with the 2021 preview yet. Normally, it's possible to install two major versions side by side...
However, the response file is different depending on whether it's generated on a machine with a previous version installed or not; the problem might stem from that.
