[SOLVED] [WUA] KB in Discarded despite the WUA packet in auth
ozsupport
Registration: July 6, 2020 - 4:52 PM
July 16, 2020 - 3:24 PM
We're continuing with the tool setup, and this time I'm stuck on the WUA part regarding the application of certain KBs:
1/ I created a "windows update" package in which I authorized all Critical and Important KBs to date (including KB4565541 :) ).
2/ It's installed on the Win2012R2 servers that I have connected to my WAPT server.
3/ I run the update search on the agents.
4/ Some servers correctly accept OK/PENDING/DISCARDED.
4bis/ A group of servers displays certain KBs as "DISCARDED" even though they are authorized by the package I created in step 1.
What actions can I take to see what might be blocking them?
D.
WAPT 1.8.2 Ent
Server OS: Debian 10
Client OS: Windows Server 2012R2
Administration Machine OS: Windows Server 2016
ozsupport
July 16, 2020 - 3:44 PM
Well, in the end, after a day of searching and after deciding to post on the forum, the posts in question changed from "PENDING_UPDATES" to "OK," and the update status was corrected.
So perhaps I had the update installations in progress, and that was blocking the update status from being updated?
D.
July 16, 2020 - 11:01 PM
In order:
- scan
- creation of the wua rules package
- installation of the wua rules package
- rescan (to take into account the new rules and switch the KB to missing)
- download of the KB by the wapt server (since it is missing on the machine, it is automatically downloaded to the server, every 30 minutes)
- installation of the KB
example: https://www.youtube.com/watch?v=x36gAaT31Ko
To put it simply, after installing a wua rules package, you need to run a new wua scan.
ozsupport
July 17, 2020 - 2:25 PM
I had started the scan, but the packages remained discarded until the umpteenth "refresh".
Anyway, it works now; I just had to be patient. I'm marking this as resolved, :)
thanks!
D.
