[RESOLVED] tis-microsoft-teams
jpele
Registration: March 4, 2019 - 12:01
July 31, 2020 - 2:29 PM
I tested it in a similar situation to yours and I don't have the problem.
What is the exact command line that is executed by Teams? In your attached image, it's the "program location" (the end of the command is cut off).
Are we sure that the session setup was correctly executed on the affected user's session? Command: "wapt-get session-setup tis-microsoft-teams -f"
Regards,
Jimmy
alex_30
Registration: July 8, 2020 - 5:33 PM
July 31, 2020 - 5:19 PM
Same on a Win10 x64
Sorry, here's a new screenshot from Windows 10; the command line is clearer:
jpele
August 3, 2020 - 5:09 PM
Thank you for the clarification. It seems that a link with Microsoft Office is being attempted to integrate Teams as a "Chat" application.
Source: https://techcommunity.microsoft.com/t5/ ... mp/353660
You will need to adjust the application preferences, which you can do from the "session-setup" section of the package. If you want to test this, you will need to modify the options labeled "Meeting," "Chat," etc.
This option could be: "registerAddinOnMeetingPolicySettingsSync": true => false
I'll make a note of this for later. Please feel free to keep us updated on your tests.
Best regards,
Jimmy
alex_30
August 5, 2020 - 11:31
Thank you for your feedback. Unfortunately, I won't be able to modify the options or run further tests.
I think I'll wait for your next updates to test it again.
Alexandre.
jpele
September 17, 2020 - 3:03 PM
I've made the change, the problem should be solved! ;)
The package will be available on the store very soon.
Regards,
Jimmy
alex_30
July 12, 2021 - 2:50 PM
sorry I didn't reply, but yes, the problem has been resolved.
Thanks again.
