I have a problem with Anaconda3-2020.07-Windows-x86_64; it installs perfectly on all the identical machines (we just deployed them), but on some, for some unknown reason, Anaconda does not launch with the error: "This application failed to start because it could not find or load the Qt platform plugin "windows". Reinstalling the application may fix this problem.".
The only way to solve this problem is to launch a conda cmd with admin rights with the command "conda install qt", there is a prompt asking for y/n which must be passed for the command to succeed.
My question is: how do I add this to the end of the Anaconda installation in my script, but more importantly, how do I pass the y/n prompt to cmd?
Or another solution, perhaps a Qt package...
Thank you for your help
Here is my script if needed.
# raccourcis
RaccourcisPathExe = r'C:\ProgramData\Anaconda3\pythonw.exe'
RaccourcisArguments = r'C:\ProgramData\Anaconda3\cwp.py C:\ProgramData\Anaconda3 C:\ProgramData\Anaconda3\pythonw.exe C:\ProgramData\Anaconda3\Scripts\anaconda-navigator-script.py'
RaccourcisArguments1 = r'C:\ProgramData\Anaconda3\cwp.py C:\ProgramData\Anaconda3 C:\ProgramData\Anaconda3\pythonw.exe C:\ProgramData\Anaconda3\Scripts\spyder-script.py'
RaccourcisDossier = "_LFIB MATHS"
RaccourcisName = u"Anaconda Navigator (Anaconda3)"
RaccourcisName2 = u"Spyder (Anaconda3)"
RaccourcisName3 = u"Anaconda Powershell Prompt (Anaconda3)"
RaccourcisName4 = u"Anaconda Prompt (Anaconda3)"
RaccourcisName5 = u"Jupyter Notebook (Anaconda3)"
RaccourcisName6 = u"Reset Spyder Settings (Anaconda3)"
RaccourcisDossierProgramm = r"C:\ProgramData\Anaconda3"
ExeName = 'pythonw.exe'
ExeName2 = 'pythonw.exe'
if os.path.isdir('C:\ProgramData\Anaconda3') == False:
install_exe_if_needed("Anaconda3-2020.07-Windows-x86_64.exe",'/InstallationType=AllUsers /RegisterPython=1 /S',key='',min_version='2020.02')
print ('Anaconda already install')
print('Creation du lien dans le menu demarrer _LFIB MATHS')
#create_programs_menu_shortcut(RaccourcisName,target=RaccourcisPathExe,arguments=RaccourcisArguments,icon=r'C:\ProgramData\Anaconda3\pkgs\anaconda-navigator-1.9.12-py38_0\info\recipe\navigator.ico',folder=RaccourcisDossier)
#create_programs_menu_shortcut(RaccourcisName2,target=RaccourcisPathExe,arguments=RaccourcisArguments1,icon=r'C:\ProgramData\Anaconda3\pkgs\spyder-4.1.4-py38_0\Scripts\spyder.ico',folder=RaccourcisDossier)
copytree2(r'icone',r'c:\ProgramData\Microsoft\Windows\Start Menu\Programs\_LFIB MATHS')
print('uninstalling Anaconda')
run(r'"C:\ProgramData\Anaconda3\Uninstall-Anaconda3.exe" /S')
print('Supression du lien dans le menu demarrer _LFIB MATHS')
remove_programs_menu_shortcut(RaccourcisName,folder=RaccourcisDossier)
remove_programs_menu_shortcut(RaccourcisName2,folder=RaccourcisDossier)
remove_programs_menu_shortcut(RaccourcisName3,folder=RaccourcisDossier)
remove_programs_menu_shortcut(RaccourcisName4,folder=RaccourcisDossier)
remove_programs_menu_shortcut(RaccourcisName5,folder=RaccourcisDossier)
remove_programs_menu_shortcut(RaccourcisName6,folder=RaccourcisDossier)Debian 10
Wapt 1.8.2
Windows 10 x64
