[RESOLVED] tis-itunes package
Yoann
Registration: July 24, 2019 - 09:39
September 17, 2020 - 1:56 PM
there is a problem with the new version of the tis-itunes package.
The following error is returned: `msi file AppleApplicationSupport.msi not found in package`.
In the 64-bit package, the AppleApplicationSupport.msi is not present even though it is referenced in the `to_install_bins`.
Thank you,
Best regards.
WAPT Community 1.8
jpele
Registration: March 4, 2019 - 12:01
September 18, 2020 - 11:00 AM
Yes, I noticed that too. Apple made some changes to iTunes, and I was able to modify the package accordingly and greatly improve it in the process.
The new package is available on the Store. ;)
Best regards,
Jimmy
Yoann
September 18, 2020 - 2:12 PM
package tis-itunes, when launching iTunes, a dialog box displays the following message: "The software required to communicate with iPods is not properly installed. Do you want iTunes to attempt to repair it?"
Thank you,
Best regards.
WAPT Community 1.8
jpele
September 18, 2020 - 2:38 PM
Yoann,
what type of device are you using? I don't have this problem with my iPhone.
Regards,
Jimmy
Yoann
September 21, 2020 - 11:46
I don't use any devices.
I've encountered a problem installing the tis-itunes in a virtualized environment: Windows 10 Pro 64-bit and Windows 7 Pro 32-bit.
After installing the package, when launching the software, the following message appears: "The software required to communicate with iPods is not properly installed. Do you want iTunes to attempt to repair it?"
I haven't connected any devices.
Sincerely.
WAPT Community 1.8
jpele
September 21, 2020 - 2:41 PM
You're getting this error because you're in a virtualized environment. Since iTunes is an audio media player, it displays an error because it doesn't detect a sound card on the system. This isn't a bug in the package; the machines on your network won't have this error. ;)
Regards,
Jimmy
Yoann
September 25, 2020 - 1:51 PM
By removing the following lines from the function installI no longer get the message when launching iTunes:
    # Modifying default startup mode of Apple services
    if get_service_start_mode('Apple Mobile Device Service') != 'Manual':
        set_service_start_mode('Apple Mobile Device Service', 'Manual')
    if get_service_start_mode('iPod Service') != 'Disabled':
        set_service_start_mode('iPod Service', 'Disabled')
Sincerely
WAPT Community 1.8
jpele
September 28, 2020 - 10:15
My mistake, I misinterpreted your error as a very similar one. Then I was also able to confirm the one you mentioned.
I'm switching the two iTunes-related services to "Manual" in the package, which should resolve the issue.
    if get_service_start_mode('iPod Service') != 'Manual':
        set_service_start_mode('iPod Service', 'Manual')
Jimmy
Yoann
September 29, 2020 - 10:02 AM
Yes, it does work with both services set to "Manual".
Thank you,
Best regards.
WAPT Community 1.8
