a planned task that self-destructs after completion
florentR2
Registration: February 13, 2020 - 5:23 PM
July 23, 2020 - 11:54
For mobile laptops on which the WAPT agent needs to be deployed, I refer to this section of the documentation:
https://www.wapt.fr/fr/doc/wapt-configuration ... duled-task
Next, specify a start time and indicate that the task should be repeated every 30 minutes or until successful:
However, I cannot find the option(s) to prevent the task from repeating once it has succeeded, or to prevent it from self-destructing once the wapt agent is deployed.
Do you think it's possible?
florentR2
September 30, 2020 - 2:25 PM
That doesn't seem possible?
