wapt console error
Yann44
Registration: July 9, 2018 - 1:39 PM
October 9, 2020 - 9:38 AM
I'm getting an error when importing packages from the internet in the WAPT console. I'm getting the following message: "
Unable to import package: EWaptBadCertificate: Certificate None doesn't allow to sign packages with setup.py file."
Perhaps my public and private keys are in the wrong place?
Do you have any ideas?
Thank you.
October 15, 2020 - 3:25 PM
Hello Yann44,
Yann44 wrote: Oct 9, 2020 - 9:38 AM Hello,
I'm getting an error when importing packages from the internet in the WAPT console. I get the following message:
Unable to import package: EWaptBadCertificate: Certificate None don't allow to sign packages with setup.py file.
Indeed, it's probably a mix of keys. According to the message, the key used cannot be used to sign software packages (only machine configuration packages).
Denis Cardon
Yann44
November 24, 2020 - 1:34 PM
thank you for your reply.
I haven't been able to import packages for over six months, so I had abandoned that solution.
I'm now looking into the server again. I have two keys to run the crt and perm consoles. The question is, where should I save the files?
(Console on Windows 10, Wapt V1.8.1)
Thank you in advance
, Yann44
