WAPT agent deployment
Mael
Registration: December 9, 2015 - 4:38 PM
February 3, 2016 - 9:20 AM
Hello.
I'm trying to deploy WAPT agents across a network of computers. The only solution I have is via Group Policy Objects (GPO) - Scheduled Tasks.
The task's objective is to install the WAPT agent once on each workstation. The scheduled task I created works. A task was created on my test client machine, and the agent installed successfully.
However, this is where a problem arises.
My Active Directory server is running Windows Server 2008 R2. My test client machine is running Windows 7.
After each login, the installation restarts, along with the reinstallation of the packages.
Here are the current task parameters:
My questions are:
- How did you deploy WAPT?
- How can I modify this GPO - Scheduled Task to achieve my objective?
Frédéric Bonnier
Registration: June 23, 2014 - 10:10
February 3, 2016 - 5:51 PM
I think our documentation on the wiki will answer your question. http://dev.tranquil.it/wiki/WAPT_-_D%C3 ... PT_par_GPO
Frédéric
Frédéric Bonnier - Tranquil IT Systems.
Display yourself on the WAPT user map by completing the questionnaire.
Discover our service offerings at Tranquil IT Systems and join us on Twitter.
Floflobel
Registration: Oct 15, 2015 - 5:32 p.m.
February 8, 2016 - 8:05 AM
The documentation is quite lacking in explanation; I struggled a lot to set up the GPO, but here it is.
"Asynchronously" allows the script to run only when the user has internet access, or at least some kind of connection, whether local or not.
February 9, 2016 - 10:17
With version 1.3.5, you will also need to add the SHA256 hash of waptagent.exe.
This hash can be calculated using `sha256sum` on Linux.
This is required to prevent waptdeploy.exe from deploying a waptagent.exe that is not the one you intend.
Parameters
--hash=0e592e9113ebe2e040ad945d7b887fc69843addb5950bf0dade20458be529a1d --wait=15 --minversion=1.3.5.0
knpc
Registration: Nov. 20, 2015 - 4:40 p.m.
March 4, 2016 - 5:37 PM
Hi,
could you explain your GPO in detail on a 2008 server? I'm having trouble understanding it from the documentation.
I created my computer GPO
, but in my gpresult, under Computer configuration, it says: No data available.
Could you provide an example of the path you're hiding in your settings, using the server "\\CONTROLLER.local\", to show the exact path
? Where should the waptagent file be located?
Thanks
, Knpc
a.grisard
Registration: March 15, 2016 - 08:14
April 5, 2016 - 11:27
you can follow my post on this topic here: viewtopic.php?f=13&t=438
