self-service logo
paulo
Registration: Nov 18, 2020 - 09:32
November 18, 2020 - 09:34
how can a personalized logo for the self-service area be applied to all customers?
By customizing the customer profile?
And how, please?
Thank you.
paulo
November 18, 2020 - 10:20
Thank you.
Yes, it works if I copy the logo to the directory on a workstation.
Can this be automated so that all workstations receive the correct logo?
For example, with the agent deployment?
November 18, 2020 - 10:43
A package like this will do the job:
    wapt_path = WAPT.wapt_base_dir
    print('Install custom logo')
    filecopyto('waptexit-logo.png',makepath(wapt_path,'templates'))
    filecopyto('waptself-logo.png',makepath(wapt_path,'templates'))
    remove_file(makepath(wapt_path,'templates','waptexit-logo.png'))
    remove_file(makepath(wapt_path,'templates','waptself-logo.png'))
paulo
November 18, 2020 - 10:45 AM
I'll try it.
Thank you very much.
paulo
November 19, 2020 - 08:21
I put the script in the setuphelpers folder of the WAPT agent package, for example?
At what point do I point the image file I want to copy to the templates directory?
November 19, 2020 - 09:36
The two files simply need to be in the root directory of the package
paulo
November 19, 2020 - 10:46
Thank you,
I inserted the script into the agent package and copied the files.
It's not working, I must be missing something.
