I want to protect our WAPT server, accessible on the internet, using client certificate authentication.
I believe I followed the documentation https://www.wapt.fr/fr/doc/wapt-securit...ation.htmlwhich, incidentally, isn't entirely consistent with the nginx files generated by version 1.8.2.7334. After adding the line "include /etc/nginx/certificate-auth.conf;" wherever I think it's necessary, I can run "wapt-get update", but launching and attempting authentication on the console returns a 401 error. On the WAPT server, in the nginx logs I have:
xxxx - admin [07/Dec/2020:17:19:37 +0100] "POST /api/v3/login HTTP/1.0" 401 195 "-" "waptconsole/1.8.2.7334"
My nginx configuration file is as follows:
server {
listen 80;
listen [::]:80;
server_name _;
return 301 https://$host$request_uri;
server {
listen 443 ssl;
server_name _;
ssl_certificate "/opt/wapt/waptserver/ssl/cert.pem";
ssl_certificate_key "/opt/wapt/waptserver/ssl/key.pem";
ssl_protocols TLSv1.2;
ssl_dhparam /etc/ssl/certs/dhparam.pem;
ssl_prefer_server_ciphers on;
ssl_ciphers 'EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH';
ssl_stapling on;
ssl_stapling_verify on;
ssl_session_cache none;
ssl_session_tickets off;
ssl_client_certificate "/opt/wapt/conf/ca-wapt.public.geovar.net.crt";
ssl_verify_client optional;
gzip_min_length 1000;
gzip_buffers 4 8k;
gzip_http_version 1.0;
gzip_disable "msie6";
gzip_types text/plain text/css application/json;
gzip_vary on;
index index.html;
location / {
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header Host $host;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
# be sure these headers are not forwarded
proxy_set_header X-Ssl-Client-Dn "";
proxy_set_header X-Ssl-Authenticated "";
client_max_body_size 4096m;
client_body_timeout 1800;
location /static {
alias "/opt/wapt/waptserver/static";
location /ssl {
alias "/var/www/ssl";
location ~ ^/(wapt/waptsetup-tis.exe|wapt/waptagent.exe|wapt/waptdeploy.exe|sync.json|rules.json)$ {
add_header Cache-Control "store, no-cache, must-revalidate, post-check=0, pre-check=0";
add_header Pragma "no-cache";
root "/var/www";
location ~ ^/(wapt/.*|waptwua/.*|wapt-diff-repos/.*)$ {
root "/var/www";
location ~ ^/(wapt-host/.*)$ {
log_not_found off;
root "/var/www";
location / {
location /add_host_kerberos {
return 403;
location /wapt-host/Packages {
return 403;
location / {
add_header X-Forwarded-List $http_x_forwarded_for;
add_header X-Remote-IP $remote_addr;
proxy_pass http://127.0.0.1:8080;
location /socket.io {
proxy_http_version 1.1;
proxy_buffering off;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "Upgrade";
proxy_pass http://127.0.0.1:8080/socket.io;
Thank you for your invaluable help.
