Solved: Help copying a Python file
tienou
Registration: February 11, 2016 - 4:11 PM
February 15, 2016 - 3:05 PM
I'm a beginner in Python.
I have a very simple VBS script but I can't translate it.
If someone could help me, I would make progress in understanding this language.
THANKS
If Not Fso.FolderExists("C:\Users\Default\Documents\FirstClass\") Then
Fso.CreateFolder("C:\Users\Default\Documents\FirstClass\")
End IF
If Not Fso.FolderExists("C:\Users\Default\Documents\FirstClass\settings\") Then
Fso.CreateFolder("C:\Users\Default\Documents\FirstClass\settings\")
End IF
Fso.CopyFile "\\10.42.20.221\waptdev\wapt-firstclassclient-wapt.12.110-0\home.fc","C:\Users\Default\Documents\FirstClass\settings\",True
February 15, 2016 - 3:21 PM
Literal answer:
    mkdirs(r'C:\Users\Default\Documents\FirstClass\settings')
    filecopyto(r'\\10.42.20.221\waptdev\wapt-firstclassclient-wapt.12.110-0\home.fc',r'C:\Users\Default\Documents\FirstClass\settings')
(Perhaps it would be cleaner to include \\wapt-firstclassclient-wapt.12.110-0\home.fc in the package...)
tienou
February 15, 2016 - 4:16 PM
Thanks htouvet :D
, even though it doesn't work.
I think there's a permissions issue :( .
February 15, 2016 - 4:19 PM
The share \\10.42.20.221\waptdev is definitely not accessible to the System account under which the wapt service runs on the machine.
That's why it's better to put the "home.fc" file directly in the package...
tienou
February 18, 2016 - 09:47
htouvet wrote:The share \\10.42.20.221\waptdev is definitely not accessible to the System account under which the wapt service runs on the machine.
It works by putting the file in the package, thank you :)
