We need to check if a directory is present on the desktops of machines used with a generic Active Directory account.
The directory must be located on the desktop of that account.
We would like to deploy a package to the affected machines that returns some result in their audit (for example, whether the directory is present or not).
We have written the code in the `def audit` section of the package for this purpose.
We are trying to retrieve the name of the user currently logged into the machine to build the search path (c:\users\'username'\desktop\...).
However, we have tried several methods, but they either return the machine name or incorrect information:
`os.environ['USERPROFILE']` returns `C:\WINDOWS\system32\config\systemprofile`, `
win32api.GetUserName()` returns `SystÞme`,
`os.getenv('username')` returns the machine name (e.g., `my-machine$`),
`getpass.getuser()` returns the machine name (e.g., `my-machine$`).
Do you know why? We've been stuck for a while.
Thank you.
A package that checks if a directory is present in the user's profile
It seems this stems from the fact that wapt uses the system account to perform its actions.
Therefore, we need to use the session_setup component to interact with the user session, but apparently, there are no logs of the actions performed within the session_setup component. Can you confirm this?
- WAPT Expert
Given what you want to do, there's no need to perform a session_setup:
use the audit:
use the audit:
list_error = []
for p in get_local_profiles():
print('Test for %s' % p['user'])
if not isdir(makepath(p['profile_path'],'Desktop','foldertest')) :
list_error.append( 'Error for %s folder not found' % p['user'] )
if list_error:
print(list_error)
return "ERROR"
return "OK"
