when trying to deploy MS-OFFICE 2013, the software status report indicates: "Installing Office 2013
CalledProcessError: Command '('"setup.exe" /adminfile "silent.msp" ',)' returned non-zero exit status 1" .
The OS used is 64-bit.
I can't determine if the problem comes from my package or the setup.py script I'm using.
Should I create one package per processor?
Or
should I test the deployment on a 32-bit machine?
Thank you for your help.
Best regards,
Francis
MS Office 2013 deployment - error
