To ensure a smooth migration between WAPT 1.8 and 2.0, I would like to install a new server running version 2.0 alongside the existing 1.8 server.
Technically, is it possible for client workstations to have two different versions of the WAPT agent?
Given the package migration issues, this seems like the best solution.
Regards
[SOLVED] wapt 1.8 and 2.0 in parallel
- WAPT Expert
Hello nliaudat,
it is possible to install agent 2.0 on a client machine connected to a 1.8.2 server. Afterwards, you import all the packages and then check which ones install correctly and which ones don't.
Regards,
Regards,
