currently using samba Version 4.10.17-Debian Stretch, I wish to switch to the latest Release (4.14.4).
I am encountering this problem:
#cat /etc/apt/sources.list.d/tissamba.list
deb https://samba.tranquil.it/debian/samba-4.14.4/ stretch mainCode: Select all
Err:10 https://samba.tranquil.it/debian/samba-4.14.4 stretch/main amd64 Packages
404 Not Found
Reading package lists... Done
W: The repository 'https://samba.tranquil.it/debian/samba-4.14.4 stretch Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: Failed to fetch https://samba.tranquil.it/debian/samba-4.14.4/dists/stretch/main/binary-amd64/Packages 404 Not Found
E: Some index files failed to download. They have been ignored, or old ones used instead.Is there a problem with your deposits?
I've tested all the versions, it's the same.
THANKS
