[SOLVED] Deploying PowerShell Core on an Ubuntu client
Flafleur
Registration: May 28, 2021 - 09:17
May 28, 2021 - 09:32
Hello everyone!
As part of my internship, I'm testing deployment solutions for heterogeneous IT environments, including WAPT. Deploying packages on Windows and Debian works perfectly, but I've been trying unsuccessfully for several days to deploy the powershell-core package. According to the console, everything is fine, but PowerShell isn't installed on the target machine. Does
anyone have any ideas? Could it be a permissions issue?
2021-05-28 09_25_37-Parameters.png (159.72 KiB) Viewed 2834 times
2021-05-28 08_50_36-Parameters.png (121.87 KiB) Viewed 2834 times
Flafleur
May 28, 2021 - 09:48
Thanks to the technical support team, I was able to find the answer: the package is intended for Debian only.
Thank you team! :)
June 1, 2021 - 6:03 PM
You can adapt the package quite easily for Ubuntu. Simply edit it by modifying the .deb file inside and the control file.
