[SOLVED] Message when re-editing a package from PyScripter
tsille
Registration: June 4, 2021 - 10:30
June 4, 2021 - 10:45
When re-editing an existing package from PyScripter v4.0.0.5 and upgrading to WAPT 2.0, two messages appear when using the WATP:build-upload, install, etc. commands.
These messages do not seem to appear when creating a new, empty package.
These messages do not appear to prevent WAPT from functioning normally, but they are more of a nuisance than anything else.
pyscripter error 2.png (10.08 KB) Viewed 9612 times
pyscripter error 1.png (14.44 KB) Viewed 9612 times
- Installed WAPT version: 2.1.0.10534
- Server OS: Linux Debian 10.10
Gaetan
Registration: August 8, 2019 - 10:16
June 4, 2021 - 11:21
was the file previously edited with the previous version or with another software?
June 15, 2021 - 2:52 PM
Hi tsille,
when you run `build-upload -i`, the control file is incremented (the number after the hyphen in the version number). It seems that PyScripter is now displaying the warning message, whereas it wasn't before... You can tell PyScripter to take the change on disk into account.
Regards,
mviale
Registration: Apr 4, 2019 - 11:03
July 19, 2021 - 11:47
where is the option "You can tell PyScripter to take disk changes into account"?
I tried the option "Tools->Options->IDE Options->File Explorer -> File Change Notification -> fcnDisabled" but I still get the messages on the control page every time there's a version increment. :(
