[SOLVED] Help creating registry key, thank you
basstien
Registration: June 1, 2021 - 3:34 PM
June 8, 2021 - 11:50
I want to merge a registry key during the ultravnc deployment.
I tried with
THIS SCRIPT
registry_setstring( HKEY_LOCAL_MACHINE,"SOFTWARE\ORL\WinVNC3",'ACL','06,25,50,00,02,00,00,00,00,00,27,00,03,00,00,00,01,07,00,10,00,00,00,\
  78,15,00,00,00,7f,46,02,50,18,3f,d5,03,b4,08,ba,43,8e,54,00,00,00,00,24,00,\
  07,00,01,00,01,05,00,00,04,00,00,05,15,00,48,00,8f,46,02,50,78,3f,d5,03,b4,\
  02,ba,43,00,02,00,00', type=0x00000003)
But this is causing me a problem with the creation of the registry because the values ​​do not appear in the correct order at the registry key level.
Do you have a solution?
So I thought about automating the installation using the command prompt, but I don't have the necessary knowledge.
PS: For type 0x00000003, this is equivalent to reg_binary; it's the only way I was able to implement it
DO YOU HAVE A SOLUTION?
Thanks in advance
June 16, 2021 - 08:39
See forum rules above.
Binary key registration should work without any problems in WAPT 2.0.
June 16, 2021 - 09:20
The binary blob is represented in your code in hexadecimal form.
The binascii module must be used to transform it into 'true' binary
If the value is of binary type, registry_setstring stores it in the registry with the type REG_BINARY
import binascii
    r"SOFTWARE\ORL\WinVNC3",
    'ACL',
    binascii.a2b_hex('06,25,50,00,02,00,00,00,00,00,27,00,03,00,00,00,01,07,00,10,00,00,00,78,15,00,00,00,7f,46,02,50,18,3f,d5,03,b4,08,ba,43,8e,54,00,00,00,00,24,00,07,00,01,00,01,05,00,00,04,00,00,05,15,00,48,00,8f,46,02,50,78,3f,d5,03,b4,02,ba,43,00,02,00,00'.replace(',','')))
