Add a 32-bit filter
ryoken95
February 29, 2016 - 2:23 PM
in my network we have both 32-bit and 64-bit machines, and I want to deploy a package only to the 32-bit machines.
Do you have a solution to select only the 32-bit machines in the console?
Regards,
Ryo
February 29, 2016 - 3:04 PM
In the hardware inventory tab (poorly named...), in the filter area, type win64.
You should see
host
|-->win64 (true or false).
You can drag and drop the win64 row to the machine table on the left to add this information to a column.
Then sort by this. This allows you to multi-select machines. win64 = false
ryoken95
March 1, 2016 - 09:37
Thank you for your reply and for your help
