Missing dependencies Across multiple packages
jraykin
Registration: June 28, 2021 - 3:53 PM
June 28, 2021 - 3:59 PM
I am facing a problem that I don't understand.
I'm trying to install the following package: apt-esa_snap-8.0.0, here is its setup.py file:
uninstallstring = ['"C:\Program Files\snap\bin\uninstall.exe" -q']
    print('installing esa snap 8.0')
	install_exe_if_needed('esa-snap_all_windows-x64_8_0.exe', '-q',accept_returncodes=[0],timeout=300)
Nothing unusual, but I'm getting this error message:
  File "C:\Program Files (x86)\wapt\waptservice\service.py", line 1706, in run
    self.running_task.run()
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 551, in run
    self._run()
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 1009, in _run
Exception: Erreur lors de l'installation de [u'4C4C4544-004B-4810-8050-C3C04F395832(=16)']: erreurs dans les paquets [[PackageRequest(package=u'Afrique',architectures=[u'x64'],locales=['fr'],maturities=[u'PROD'],min_os_version=Version('10.0.19041'),max_os_version=Version('10.0.19041')), PackageEntry(u'Afrique',u'27' ), u'Traceback (most recent call last):\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4850, in install\n    force=force\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 3929, in install_wapt\n    raise e\nEWaptUnavailablePackage: Missing dependencies: apt-esa_snap\n'], [PackageRequest(package=u'4C4C4544-004B-4810-8050-C3C04F395832',version=(Version('16.0.0.0'), None),architectures=[u'x64'],locales=['fr'],maturities=[u'PROD'],min_os_version=Version('10.0.19041'),max_os_version=Version('10.0.19041')), PackageEntry(u'4C4C4544-004B-4810-8050-C3C04F395832',u'16' ), u'Traceback (most recent call last):\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4850, in install\n    force=force\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 3929, in install_wapt\n    raise e\nEWaptUnavailablePackage: Missing dependencies: Afrique,apt-esa_snap-8.0\n']]
The only thing I can see is:
And the park's windows are in 19042.
But I never imposed any restrictions on the versions, so I don't understand...
Do you have any idea?
Thanks in advance,
jraykin
June 28, 2021 - 4:49 PM
Control file if needed:
package           : apt-esa_snap-8.0
version           : 8.0-0
architecture      : all
section           : base
priority          : optional
name              :
categories        :
maintainer        : admin.verrier
description       : Package for ESA SNAP (European Space Agency)
depends           :
conflicts         :
maturity          :
locale            :
target_os         :
min_os_version    :
max_os_version    :
min_wapt_version  :
sources           :
installed_size    :
impacted_process  :
description_fr    :
description_pl    :
description_de    :
description_es    :
description_pt    :
description_it    :
description_nl    :
description_ru    :
audit_schedule    :
editor            :
keywords          :
licence           :
homepage          :
package_uuid      : ce4a0cd3-e24a-49e5-a80f-96836391b477
valid_from        :
valid_until       :
forced_install_on :
changelog         :
signer            : apt
signer_fingerprint: 4436b0451faaf4e7aa700b3995c01ba8592839bace38a2c57eb3378939f06028
signature         : 0DP4nUbUiHEBve5IhKPsulp4O+uaAeZz99RrfRioMqSHjrZDgZ9EGSDHeI5/APnrxATW+sJ5ety48RjuJaWeuf4bVDR0aNIBzLlHXMeju8s383EgIjf6sc6BP/xu12qf3oZrepR9UHo+EH3Y2hjagjP0AdYmqZ08NqxxkRhmAbUKKf9mRBTqaaUwKam/tbgCNMx8IL+mAI9oJOnCF026pSqg+R5t/fw50epYAxGHx+XnZtgXYxiA5/BwIgTj1eWw08sICvXu9KpCzdxV0pVLTtv2/W7eyywCpPp57fLJY3YnTdHqBKbTeRqxJ8sEIvsJg4B0gM9rSADeuyjd2FjNCA==
signature_date    : 2021-06-28T14:34:04.100000
signed_attributes : package,version,architecture,section,priority,name,categories,maintainer,description,depends,conflicts,maturity,locale,target_os,min_os_version,max_os_version,min_wapt_version,sources,installed_size,impacted_process,description_fr,description_pl,description_de,description_es,description_pt,description_it,description_nl,description_ru,audit_schedule,editor,keywords,licence,homepage,package_uuid,valid_from,valid_until,forced_install_on,changelog,signer,signer_fingerprint,signature_date,signed_attributes
July 7, 2021 - 5:18 PM
Please see the forum rules above.
The error message also refers to a missing "Africa" ​​dependency. The package is not from the Tranquil it store, and there isn't enough information to identify the problem...
